Author Topic: Which Filco?  (Read 2426 times)
Offline balaga
Which Filco?
« on: Sun, 20 January 2013, 01:21:05 »
i decided to buy my first mechanical keyboard
it comes down to:
-CM Storm QFR
or Filco
which Filco should i buy?
FILCO Majestouch NINJA
FILCO Majestouch 2
or FILCO Majestouch 2 Camouflage
Offline jabar
Re: Which Filco?
« Reply #1 on: Sun, 20 January 2013, 01:27:56 »
Well, what do you want out of your keyboard? Are you comfortable going semi-otaku (the Ninja keycaps)? Nice thing about front-printed legends is that they never wear off, but in the long run front-printed PBT will be preferable. I think switch choice is more important than selecting keycaps that are better off replaced anyway.
Tenkeyless is nicer for gaming. Most computer users will unlikely need the keypad.
Also, hello, welcome to geekhack!
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline balaga
Re: Which Filco?
« Reply #2 on: Sun, 20 January 2013, 01:35:02 »
:D thanks for the welcome
i already decide to use mx blue switch, want to improve my typing :D
i see, so it came down to ninja or majestouch 2 . thanks
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
Re: Which Filco?
« Reply #3 on: Sun, 20 January 2013, 02:08:02 »
I personally like all these boards mentioned. Filco build quality is outstanding, but the CM storm QFR is a good board if you're working on a budget :).
Having a bad day?
Offline verbhal
    • twitch.tv/verbhal
Re: Which Filco?
« Reply #4 on: Sun, 20 January 2013, 02:11:25 »
I use a camo Majestouch 2 with blues quite a bit.  Great keyboard.
Offline balaga
Re: Which Filco?
« Reply #5 on: Sun, 20 January 2013, 02:17:11 »
yups, i've been thinking about budget too..
mech keyboard is a bit pricey for me  , so for a long use maybe i should go with filco
Re: Which Filco?
« Reply #6 on: Sun, 20 January 2013, 03:12:31 »
Welcome to Geekhack!
Nothing wrong with the QFR - pretty much everyone who has one (including me) thinks they are great!  There are probably as many problems reports with QFR as there are with Filco, but remember that they are many, many less problems than reported with other keyboards.
If you do want to go Filco, Then get camo if you like the camouflage colouring.  Go ninja if you prefer otaku (more or less).
Remember that whatever one you get you can customise the keycaps later on.
Re: Which Filco?
« Reply #7 on: Sun, 20 January 2013, 08:13:49 »
They are not pricey... around $60-70 bux to start... At most $300-800 to finish..
Currently using a quickfire blue in vortex aluminum case with blank white pbt... That only set me back a mere $270..
I ordered that damn aluminum space bar, hopefully Feng gets well soon, so he could begin shipping again.. He got sick on an airplane.
So in the end, this whole keyboard is $304.00, as you see, not a whole lot at all...
People spend that much on groceries.
  • HHKB Pro
  • ʕ•ᴥ•ʔ
Re: Which Filco?
« Reply #8 on: Thu, 24 January 2013, 01:00:09 »
Having a bad day?
Re: Which Filco?
« Reply #9 on: Thu, 24 January 2013, 13:46:23 »
Filco Majestouch Ninja!
I just bought one of these and I'm loving it. Although they have that amazing blue one as well.
Re: Which Filco?
« Reply #10 on: Thu, 24 January 2013, 13:49:18 »
not to mention there was that $55 dollar for quickfire rapid blue on amazon... Super deal man, super deals.
Offline Dgsbllx
Re: Which Filco?
« Reply #11 on: Thu, 24 January 2013, 13:51:56 »
You really can't go wrong with any of those boards to be honest. + 1 tp4tissue, at $55 for a QFR w/ blues that would be my choice!
