Author Topic: looking for a 75% cherry MX red without backlit or can be turned off  (Read 1830 times)
Offline eosgreen
Been looking around and the only boards i can find are the noppo choc (not a fan) and the KBT race which have backlit keys. I gota be able to turn off the backlighting or have it be nonexistent since i take certain keys off and i find it distracting
would love some other potential board ideas
Offline Leslieann
Re: looking for a 75% cherry MX red without backlit or can be turned off
« Reply #1 on: Sat, 02 February 2013, 04:09:11 »
The Race has the ability to turn off the lights, but can also be found non-backlit with PBT keys and reds.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline eosgreen
« Reply #2 on: Sat, 02 February 2013, 04:15:35 »
oic it said 3 modes none of which looked like they could be turned off
TYVM!
« Last Edit: Sat, 02 February 2013, 04:25:53 by eosgreen »
Offline jabar
« Reply #4 on: Sat, 02 February 2013, 10:32:54 »
If you're not going to use backlighting, don't bother with a backlit board since they use ABS keycaps which are prone to shine.
(with the exception of Deck but I they don't come in MX Red)
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Sat, 02 February 2013, 12:12:14 »
Keycool 84
Offline Leslieann
« Reply #6 on: Sat, 02 February 2013, 16:16:10 »
I would worry less about shine and more about wearing through the top color coat.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
