Author Topic: MOD my CM Quick Fire Rapid Red Switch  (Read 7971 times)
Offline Jaffa
« on: Sat, 09 February 2013, 09:27:35 »
I have been MOD my new QFR the last 2 days.
First I did was sanding it, steel woll sanding, wet sanding.
The plastic under the rubber surface is actually very nice.
If u want a perfect result go use Polishing Pad. It will shine.
I'm very glad the way it's look now all the logo if gone for ever
Next white PBT maybe plasti dip®..
« Last Edit: Sat, 09 February 2013, 10:41:10 by Jaffa »
Cm Storm Quickfire Rapid Red Switch
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: MOD my CM Quick Fire Rapid Red Switch
« Reply #1 on: Sat, 09 February 2013, 09:30:16 »
Pics?
Offline Jaffa
« Reply #2 on: Sat, 09 February 2013, 09:37:07 »
Offline snoopy
  • The Flying Ace
« Reply #4 on: Sat, 09 February 2013, 10:02:09 »
DIY in good spirits but......... you could've just bought a filco case, aluminum or plastic, and be done with it..
Offline gigibecali
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline Jaffa
« Reply #6 on: Sat, 09 February 2013, 10:40:20 »
I'm very glad the way it's look now all the logo if gone for ever ;)
Offline inteli722
« Reply #7 on: Sat, 09 February 2013, 11:45:40 »
That looks good! Much better looking than the default case IMO.
Yes, he could've bought a Filco case in plastic, but this is better because he had it on hand. Also, he would have to sand/grind down the PCB standoff in the case, for it's slightly different on the QFR. While this is possible on the plastic case, it would be far less easy on the aluminum case.
Waiting for: Phantom Plate
« Reply #8 on: Sat, 09 February 2013, 11:56:35 »
the vortex aluminum case doesn't use standoffs, it contacts and sandwiches the steel plate directly, MUCH more rigid than the standoffs..
And it fits the quickfire perfectly.
I don't understand why the the OP sanded the stock QFR case, was it branded?
Offline inteli722
« Reply #9 on: Sat, 09 February 2013, 12:26:58 »
Branded or not, it has a soft-touch rubberized feel that I assume some people can't stand. I would also assume it was branded.
Offline sleepy916
« Reply #10 on: Sat, 09 February 2013, 14:15:01 »
You can't immediately tell from the picture but he sanded off the rubber layer. Now it's just the black plastic showing. When I did the same to mine it had an almost brushed metal look to it.
Offline gigibecali
« Reply #11 on: Sat, 09 February 2013, 15:02:52 »
oh I see.
The QFR may be described like that:
1. what Costar did was ok (except soldering on some batches)
2. what Cooler Master did was a complete, utter garbage. Everything they decided was plain stupid, except choosing Costar.
That happened probably by accident anyway.
Marketing: "Ma' men! What's za best mechanical keyboard? Huh!? ... Filco? Who does dat? Let's do the same!"
Marketing: "Mmm, yaah, we must be way cooler though so people buy us more. We're Cooler Master, aren't we?"
So they decided to wreck everything else:
key fonts look like crap, rubberized case will probably peel in very different flavors, cmstorm logos everywhere so your eyes would bleed, very stiff cable (nobody knows why).
So now people must do what you did. Replace the caps and cable too.
« Reply #12 on: Sat, 09 February 2013, 15:22:55 »
oh I see.
The font is FINE..... I like it plenty, though I did not like the infill they used which wore off and turned grey on me after only 3 days.. I type alot.
The rubber coating has also proven to be "very" durable in a nonsmoking house...
Offline inteli722
« Reply #13 on: Sat, 09 February 2013, 16:13:39 »
Yeah, It's branded. I remember, they removed the branding from the spacebar, so since his spacebar is branded, so was his case.
I don't like the key font, though some may, and I really don't like the rubberized feel, ESPECIALLY on the keycaps. I would probably buy the QFR, primarily because it's the cheapest quality keyboard on the market.
gigibecali, I don't think you're giving CoolerMaster enough credit. They have an amazing community presence (I mean, they have 2 REPRESENTATIVES on this forum, asking the community about what they want to see. If that's not amazing service, I don't know what is), and they do make quality keyboards, even if the latest batch has been iffy. They're the first company to bring Greens to the general public in a permanent SKU, and they have a lot of variety. They have a full size keyboard, a TKL (and a variant with side-printed keycaps), and a fully-customizable keyboard, essentially a 104 key backlit Phantom with less flexibility with the layout. They have proven themselves to be a company who really cares about their customers.
« Reply #14 on: Sat, 09 February 2013, 16:55:50 »
Given their presense on the forum, I don't know why they don't just MAKE our ultimate keyboard....
Programmable, Fits standard key cap sets, aluminum case option..  Winkeyless option.. 7x spacebar option, easy access plates..
Honestly, Coolermaster should just MAKE the GH60, call it something else, I don't care.. ;D
Offline gigibecali
« Reply #15 on: Sat, 09 February 2013, 17:10:11 »
Yes, it seems they've learned a lot. You should have been here one year+ ago.
Advice from the community is free, you know. Not to mention way better than how they started.
Offline Vintage
« Reply #16 on: Sat, 09 February 2013, 17:17:37 »
Sanding = Free
Vortex Case = $150
Is it really that hard to get why he didn't do that?
BTW the QFR is great because it is cheap enough for you to get really nice caps for the same overall price as Filco or less. So who cares about the font.
CM QFR w/ MX Reds  | Logitech G900
Offline inteli722
« Reply #17 on: Sat, 09 February 2013, 17:21:28 »
Because A) from what I can tell, our ultimate keyboard is the Phantom, and B) those features appeal to a small minority (which would be us). While it would be AWESOME to get that keyboard as a retail keyboard with those features, it would probably be too expensive to do well, and though I know that everyone here would buy at least 3 of them per person, not many others would. For them, easy programming is just fine, which CM provides in the Trigger. Although, I completely agree. a Phantom from a major retailer would be awesome.
« Last Edit: Sun, 10 February 2013, 14:05:49 by inteli722 »
Offline Jaffa
« Reply #18 on: Sat, 09 February 2013, 17:45:59 »
It is exactly how it looks now. Brushed steel. It look fabulous.
« Reply #19 on: Sat, 09 February 2013, 17:57:10 »
Sanding = Free
Vortex Case = $150
sanding at minimum wage, + materials    ~$40
wouldn't you rather put that $40 towards an aluminum case?
Offline Jaffa
« Reply #20 on: Sat, 09 February 2013, 17:57:38 »
Sanding = Free
Vortex Case = $150
I'm a flyfisher man for more than 10 years.
I can ty my fly or buy them! But I ty them bcuz
it's something that I have done and it more fun
catch a fish with something u have made.
Why spend 150$ for somethings u have`?
I'd rather spend my money on my son than a piece of metal.
I have money enough to buy Filco or u name it.
I decided to get from CM bcuz of the fantastic server/communication.
They listen to everything we say and their products are just as good as a keyboard that costs as gold.
« Reply #21 on: Sat, 09 February 2013, 17:58:45 »
Because A) from what I can tell, your ultimate keyboard is the Phantom, and B) those features appeal to a small minority. While it would be AWESOME to get that keyboard as a retail keyboard with those features, it would probably be too expensive to do well, and though I know that everyone here would buy at least 3 of them per person, not many others would. For them, easy programming is just fine, which CM provides in the Trigger. Although, I completely agree. a Phantom from a major retailer would be awesome.
From that I can tell you have psychological problems... You can't help but write about "how you agree with me"   in a "disagreeing tone/ phrasing"
I sense great struggle in that last paragraph you mustered.
Offline Jaffa
« Reply #22 on: Sat, 09 February 2013, 18:03:38 »
Sanding = Free
Vortex Case = $150
I have all those thins for free? So the + is 0.
I live in Scandinavia:
The delivery + 50
Case + 140
Tax + 20
VAT + 10
Transportation + 5
« Reply #23 on: Sat, 09 February 2013, 18:06:22 »
Sanding = Free
Vortex Case = $150
The delivery + 50
Case + 140
Tax + 20
VAT + 10
Transportation + 5
well who's fault was it that you live in scandanavia... Just kidding ;D....
sigh..... even at $200.. I'd rather just work overtime somewhere for currency rather than sand the case...
No matter how great of a "sander" you are...  aluminum beats plastic, at least as far as keyboard cases go...
Offline Jaffa
« Reply #24 on: Sat, 09 February 2013, 18:17:44 »
Sanding = Free
Vortex Case = $150
The delivery + 50
Case + 140
Tax + 20
VAT + 10
Transportation + 5
Hehe it ok now u know it.
How will you remove a deep scratch on an aluminum case if it is black ;)?
I am a qualified aluminum welder for more than 15 years.
Yes maybe it looks better but plastic I can always fix scratch not with aluminum ..
So alu not better but look better.
A deeb scratch on alu u will see the shine alu.
A deeb scratch on plastic wet sanding it for 10 sec clean as new.
« Reply #25 on: Sat, 09 February 2013, 18:50:07 »
Sanding = Free
Vortex Case = $150
The delivery + 50
Case + 140
Tax + 20
VAT + 10
Transportation + 5
I am ever vigilant of potential treats to my keyboard..... It's not an item that's likely to get scratched however... ;D
I'm not one to put a whole bunch of shelves above my head with sharp display objects
