Author Topic: THOCK-THOCK-THOCK!  (Read 109319 times)
Offline o2dazone
Re: THOCK-THOCK-THOCK!
« Reply #150 on: Thu, 21 February 2013, 18:17:06 »
I have a serious question about Topre switches, that maybe someone here can answer. I know the mechanism for actuation is capacitive, but what causes the capacitance? The metal spring coming in close proximity to the pad?
Without the spring, the switch would not work
edit: this forum is far too pedantic - when i say "work" i mean the capacitive "jump" would never happen, and the key would never "fire". It will still move up and down like it should though
« Last Edit: Thu, 21 February 2013, 18:18:54 by o2dazone »
Offline daerid
    • Rossipedia
« Reply #151 on: Thu, 21 February 2013, 18:41:11 »
AFAIK it's due to the fact that a conical spring in the shape as those used by Topres increases in capacitance as it gets depressed and the spring coils move closer to each other.
The circuit detects when the capacitance reaches a certain threshold and then closes.
Offline daerid
    • Rossipedia
« Reply #152 on: Thu, 21 February 2013, 18:51:10 »
Wow... just caught up. People in here are getting way too uppity. Some like Topre (like me), some don't. Whatever.
For me, I love the combination of high quality rubber dome over a steel plate/PCB, which most keyboards that we label "rubber dome" don't have. Those are usually rubber dome over plastic membranes. Much more of a mushy feel. Some prefer that, most don't.
And there are some RD over membrane boards that feel crisp and buttery smooth. Probably my favorite was this bad boy right here:
That had a firm bottom-out feel due to the caps hitting the plastic base. Great board there, lasted me many years before I found mechanicals.
People are so touchy... it's obvious that iri isn't that big a fan of the bottom out feel of Topres, and that's fine. He doesn't have to. Nobody has to. I enjoy my Topre switch boards, and I don't have to tell myself that I do in order to "justify" it. I spent a lot on them, and I don't regret the purchase. There are those who might. And that's ok too. At the end of the day, we're all just fans of fine typing devices here, right?
Offline Michael
  • Formerly Bro Caps
« Reply #153 on: Thu, 21 February 2013, 19:32:40 »
Topre = Rubber Cup, not a rubber dome :)
Offline SmallFry
« Reply #154 on: Thu, 21 February 2013, 19:58:45 »
This thread is crazy guise.
Offline fuzzybaffy
« Reply #155 on: Thu, 21 February 2013, 20:48:34 »
How was I being uppity? I was just saying, I ****ing love my Topre.
Offline Michael
  • Formerly Bro Caps
« Reply #156 on: Thu, 21 February 2013, 21:10:09 »
You should make that your permanent sig in big fat bold letters for the angry anti-topre crowd....
« Reply #157 on: Thu, 21 February 2013, 21:23:33 »
Dome, sorry they're identical with the exception of actuation distance...
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #158 on: Thu, 21 February 2013, 21:33:27 »
My coworker has like 20 of these things stock piled. They're his favorites.
Offline daerid
    • Rossipedia
« Reply #159 on: Thu, 21 February 2013, 22:25:54 »
By immediately assuming I was referring to you ;) (which I wasn't, actually).
Topres are rubber domes. They're just exceptionally good ones (IMO).
Offline Michael
  • Formerly Bro Caps
« Reply #160 on: Thu, 21 February 2013, 22:31:35 »
But they aren't identical. That exception is the major difference, not to mention the quality and thickness/durability of the rubber.
Topre: Cup
Rubber DOME:
« Last Edit: Thu, 21 February 2013, 22:33:33 by Bro Caps »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #161 on: Thu, 21 February 2013, 22:35:52 »
You're having a disagreement with tp and trying to use words and pictures to show him that he's wrong.  You'd have better luck convincing the bro bot in your avatar that it was a new girldc Gundam cap...
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #162 on: Thu, 21 February 2013, 22:41:23 »
Enough, guys.  Can't we all just get along and discuss the Klaxon set in peace?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #163 on: Thu, 21 February 2013, 22:42:29 »
I'm much too angry for that.
Grr and stuff.
Buy moar klaxon?
Offline Michael
  • Formerly Bro Caps
« Reply #164 on: Thu, 21 February 2013, 22:43:08 »
Offline daerid
    • Rossipedia
« Reply #165 on: Thu, 21 February 2013, 23:03:22 »
Offline iri
« Reply #166 on: Fri, 22 February 2013, 01:33:34 »
hmm, don't you like hhkb more than realforce?
Also, a related question, is it possible, while typing normally, to actuate the switch without bottoming out?
i asked the same question here once, and got a reply "no, that's not possible, but that's okay, as bottoming out on topre is nice".
« Last Edit: Fri, 22 February 2013, 01:35:24 by iri »
-Ray Bradbury
Offline daerid
    • Rossipedia
« Reply #167 on: Fri, 22 February 2013, 14:49:11 »
Yes, actually. I was more making a generic comparison between standard rubber domes and the RealForce breed of Topre. I still love RF's more than everything except the HHKB. Apologies.
Offline sth
  • 2 girls 1 cuprubber
« Reply #168 on: Wed, 06 March 2013, 16:38:42 »
i can't wait to the moment when people start using the word MEMBRANE to distinguish conventional rubber dome keyboards from capacitive rubber dome topre.
uh actually iMav came up with the initialism RDOMS probably years before you were aware of topre... rubber dome over membrane switch.
the rest of you are cracking me up with how defensive you get about rubber... yes, topre is rubber dome. it feels nice. use it if you like it.  ¯\_(ツ)_/¯
« Reply #169 on: Wed, 06 March 2013, 17:15:52 »
This is degenerating into the newbie thread like:
"Just Tell Me What is the Best Keyboard So I Can Buy It"
My wife loves Apple's flat scissor keys with minimal travel, so "there is just no accounting for taste" right?
Give me a heavily-modded Model F, but that's just me.
- Franklin Roosevelt 1933
Offline Michael
  • Formerly Bro Caps
« Reply #170 on: Wed, 06 March 2013, 17:35:47 »
yes, topre is rubber CUP. it feels nice. use it if you like it.  ¯\_(ツ)_/¯
FTFY
-Oneness with cup rubber
Offline sth
« Reply #171 on: Wed, 06 March 2013, 17:36:34 »
yes, topre is CUP rubber. it feels nice. use it if you like it.  ¯\_(ツ)_/¯
FTFY
ftfyftfm (fixed that for you fixing that for me).
oneness!!
Offline iri
« Reply #172 on: Thu, 07 March 2013, 02:46:41 »
enough of this
-Ray Bradbury
