Author Topic: New Vortex Pure Pro Keyboard  (Read 11446 times)
Offline missalaire
  • Great Finder of Great Finds
« on: Wed, 20 February 2013, 11:59:00 »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: New Vortex Pure Pro Keyboard
« Reply #1 on: Wed, 20 February 2013, 12:06:34 »
Heh, in French even.
Offline Jocelyn
  • 조셀린
Offline Michael
  • Formerly Bro Caps
« Reply #3 on: Wed, 20 February 2013, 12:12:14 »
Offline Mainian
« Reply #4 on: Wed, 20 February 2013, 12:22:52 »
So either they copied Filco, or vice versa:
New Pure:
http://img03.taobaocdn.com/imgextra/i3/225676161/T2UjzkXfNXXXXXXXXX_!!225676161.jpg
New Filco Minila:
http://www.diatec.co.jp/en/det.php?prod_c=1323
It is at least better than the ficlo's... DAT SPACEBAR
Offline calavera
« Reply #5 on: Wed, 20 February 2013, 12:33:18 »
New Pure:
New Filco Minila:
Copy what, the layout? I don't see any hints of copying between those two going on seriously.
« Reply #6 on: Wed, 20 February 2013, 12:35:28 »
New Pure:
New Filco Minila:
I'd say the vortex is superior because it doesn't have the stupid top bezel...
Offline sordna
« Reply #7 on: Wed, 20 February 2013, 12:42:37 »
Yep, it's better laid out than the MINILA, although I still would prefer a bigger spacebar.
Is this thing programmable after all?
Offline Michael
  • Formerly Bro Caps
« Reply #8 on: Wed, 20 February 2013, 14:17:02 »
That may be true, but I think the filco is most likely built better, judging from their previous products.
Offline Michael
  • Formerly Bro Caps
« Reply #9 on: Wed, 20 February 2013, 14:19:42 »
They are almost similar, that's the comparison I was making. It just struck me as odd that they came out at almost the same time, with almost the same layout.
Offline SmallFry
« Reply #10 on: Wed, 20 February 2013, 14:22:18 »
You do know you can multi-quote right?
Like so.
heh.
Offline Michael
  • Formerly Bro Caps
« Reply #11 on: Wed, 20 February 2013, 14:25:42 »
I don't have the time or patience to be doing that on a mobile device, but thanks for sharing...
Offline SmallFry
« Reply #12 on: Wed, 20 February 2013, 14:27:03 »
Copy-pasta? :P
Offline Michael
  • Formerly Bro Caps
« Reply #13 on: Wed, 20 February 2013, 14:28:55 »
Copy-pasta? :P
It's a real pain in the ass on an iPad, honestly. At least for that many quotes. More work than I care to do
Offline SmallFry
« Reply #14 on: Wed, 20 February 2013, 14:30:33 »
Two? heh. Ok bro. :P
Offline BucklingSpring
« Reply #15 on: Wed, 20 February 2013, 20:45:48 »
. oups - where the post delete button?
« Last Edit: Wed, 20 February 2013, 20:47:51 by BucklingSpring »
Boards I own, click ->
Offline Sinzz
« Reply #16 on: Wed, 20 February 2013, 21:00:50 »
It's also being discussed in this thread: http://geekhack.org/index.php?topic=37444.0
The Pure Pro is also going to be known as the Poker Pro, difference being the layouts, ANSI and ISO. There is also rumored to be other versions of the Pure/Poker, eg No LED's and PBT.
Keycool 84 MX Blue | Pure Pro | HHKB Pro 2
Offline laffindude
« Reply #17 on: Thu, 21 February 2013, 01:44:36 »
There is a video of the 67key ISO Pure here: http://geekhack.org/index.php?topic=37444.msg794528#msg794528 No comprende. Feel free to summarize.
That's something different. RCtrl is where grave/tilde used to be. Also note the crappy illumination on the enter key. Switch location and where they made the legend is incompatible.
Both of them are not using their previous manufacturer. So quality on both will be subpar.
Offline daerid
    • Rossipedia
« Reply #18 on: Thu, 21 February 2013, 12:11:39 »
Damnit.. didn't see this. Sorry for the double post.
Offline ARod
« Reply #19 on: Wed, 11 December 2013, 10:35:52 »
Necro Update.....here stateside, Mechanical Keyboards just got a load in some time ago, good stock.
http://www.mechanicalkeyboards.com/arrived.php
Offline Pacifist
  • on hiatus
« Reply #20 on: Wed, 11 December 2013, 11:00:13 »
no white led tho....
