Author Topic: SUPER excited about humidifier  (Read 2111 times)
« on: Wed, 20 February 2013, 20:28:23 »
The design of the evaporation mechanism is so simple...... almost elegant.....  :D
Water flows across a UV lit channel that kills germs.
Goes into a "Wick// evaporative surface"
The fan, "very quiet" draws air through the wick, moistening it..
wick-filter replacement once a month, bout $14.. relatively inexpensive
My room is now a nice 45% up from 28% with the heater on...
The wick design is great because this will also pull dust and debris out of the air..
so you get a filtering effect....
Water tank has a BIG hole that you can stick your WHOLE HAND in to clean....  :D
All the surfaces "inside" the machine is completely easy to clean, no little nooks that you need to get at...  ^-^
Freaking... I love this thing........  :D :D
