Author Topic: Chinese Translation Needed  (Read 2146 times)
Offline Emmiya
« on: Fri, 19 April 2013, 11:32:58 »
Hello, I recently placed an order, and it's been 20 days since I heard absolutely anything and no English tracking information is available. To cut a long story short, I contacted the seller(71% positive feedback with multiple claims of scams against him) and they assured me that the item is on the way, and linked me an image* of what appears to be tracking info, however it is completely in Chinese so I have no idea what it says.
I was just wondering if anyone would mind taking 2-3 minutes to translate it, I would greatly appreciate it if anyone is able to.
*I would have been happy Googletranslating it, but with it being an image, and not having a clue which symbol is which, or if it's even traditional/Mandarin it would probably take me years to decipher it. I attempted to use an app which supposedly translates text on images to your language, however with the completely different syntax/grammatical styles It has no clue what the image is even trying to say.
As far as I can tell, there's no distinguishing information about me there, I hope.
« Last Edit: Fri, 19 April 2013, 15:43:01 by Emmiya »
Offline Aranair
  • Software Engineer @ PocketMath
    • Tech blog
Re: Chinese Translation Needed
« Reply #1 on: Fri, 19 April 2013, 11:50:03 »
From the 5th column, it does say that its on the way :P
(1st column is item ID )
I think it was sent out on the 4-17, direct from this place called Hang Zhou to Britain.
Present  : HHKB Pro 2 Type-S White | HHKB Pro 2 White Blank | Ergodox EZ
Past      :  Poker 2 Brown | Black Widow Ultimate Blue | Filco TKL Brown
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #2 on: Fri, 19 April 2013, 11:51:09 »
It says its posted, from the HangZhou post office, on the 17th of Apr, usually when they accept a tracked parcel at the PO. (Means it was accepted at the PO as a registered parcel on that day)
Wait another 2 or 3 days and it might updated to be sorted and ready to exit China.....
Patience, young padawan, the seller just posted it, for whatever reasons.
« Last Edit: Fri, 19 April 2013, 11:53:59 by Shadovved »
Offline Emmiya
« Reply #3 on: Fri, 19 April 2013, 15:42:43 »
Aha thank you very much :P was simply curious. Just with the history of scams on their profile I didn't know whether he just copypasted someone elses order info to me.
Offline gracy123
« Reply #5 on: Sun, 28 April 2013, 08:46:58 »
« Last Edit: Thu, 02 May 2013, 08:21:46 by gracy123 »
