Author Topic: Seasonic X Series X-850 Gold PSU ($99.99 after $20 MIR and promo code) [Exp 5/8]  (Read 2575 times)
Offline missalaire
  • Great Finder of Great Finds
Offline SmallFry
Tell Eckse in the IRC, he just blew his PSU and is now on an OCZ PSU. :(
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
these are good
OMG... I've gotten OCZ rap3d 8+ times.
Bad PSU 2004
Bad PSU 2004 .5
Bad PSU 2006
Bad SSD vertex
Bad SSD vertex 2
Bad SSD vertex 2
Bad PSU ~ 2008
Bad SSD vertex 3
Bad SSD vertex 3
Bad SSD vertex 4, rmaed, sold replacement unit post rma
I've sworned against OCZ
Offline Jocelyn
  • 조셀린
Friends don't let friends buy OCZ.
Offline jwaz
  • * based mod
  • #geekhack on freenode
See people complaining about cap squeal but I'm oh so tempted
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
Just built my new rig with this. Excellent PSU. The only one better is Seasonic Platinum series.
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
cap squeal? I thought it was the inductors...
Lots of MLCC (Multilayer ceramic capacitors) can squal. The inductors can too, of course.
For example, I have a few PSU's that squeal a bit from the capacitors, not the inductors.
That said, this is by all accounts an excellent PSU.
Offline mkawa
usually it's inductors that squeal. often referred to as "coil whine". solid caps are highly unlikely to vibrate. between a number of the x-XXX gold rated units, i had never gotten an audible coil whine. however, recently bought and returned a 660xp2 platinum unit that had pretty bad whine. could be a change in component sourcing, contract manufacturer, or something inherent to the design. i will say that seasonic _always_ uses enclosed inductors (encapsulated with epoxy and then sealed into a metal box) when possible. there's also a possibility that it is a weird high order electrical interaction with your particular power drains and the supply.
i will say that switching power supplies have to be switched at extremely high frequencies to get this kind of efficiency, so it's not that surprising to get a little bit of coil whine (or a lot in a budget efficient unit). seasonic is one of the best OEMs, however, carries the best warranty, etc.
