Author Topic: Fiio E17 on Massdrop for $97  (Read 3082 times)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Re: Fiio E17 on Massdrop for $97
« Reply #1 on: Fri, 07 June 2013, 20:10:40 »
Good portable all-in-one, but does not excel in anything. I used to own one as my main dac/amp, and then as a a portable amp. Nice price once it reaches the last bracket.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Fri, 07 June 2013, 20:12:57 »
It shows already at that bracket to me.
« Reply #3 on: Fri, 07 June 2013, 20:19:19 »
Jeez that was quick haha.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Fri, 07 June 2013, 20:24:17 »
I think I'ma get one.  It's either this or build an o2/odac combo
« Reply #5 on: Sat, 08 June 2013, 06:40:34 »
ah..... well... yea... it's sorta good if you're lazy,  but these are usually marred by noise coming through the usb 5v.  Unless you have a very low power system, the noise floor will be high.. Keep that in mind..   This is especially a problem with low resistant head sets / earbuds they are very sensitive to dc noise
I personally recommend any of those ebay diy kits, which are equivalent in performance to $300 equipment on a $100 Budget. :D
« Reply #6 on: Sat, 08 June 2013, 06:47:22 »
There is a little bit of noise if you're using USB input with sensitive headphones or IEMs. Though this is solved easily by just using SPDIF coaxial or optical :D. The main appeal of the E17 is its portability and variety of functions rather than its performance.
Offline raspiguy
« Reply #7 on: Tue, 11 June 2013, 19:18:26 »
I need to up-vote gunner's response -- this unit is all about convenience, versatility, and that SPDIF/DigitalCoax input jack.  Options for that SPDIF-in at lower price points are limited, and those options don't have a built-in battery, LCD display, 24/192, EQ customization, slim profile, etc. etc.
One thing I will note, though, for anybody that misses the Massdrop and happens upon this later, is that if you're lucky you can get these for pretty cheap elsewhere without a group buy.  Got mine late last year for $105-shipped from SonicElectronix, which for some reason takes offers on this product both through their site and their eBay listing.  I'm sure the acceptance level fluctuates, but worth a look if you want to save a quick $30 or so.
Offline Tarzan
  • formerly known as Greystoke
« Reply #8 on: Wed, 03 July 2013, 07:22:07 »
The E17 was waiting on my doorstep yesterday.  Sweet unit!  Makes the HD598 headphones sound fantastic.
27179-0
