Author Topic: I'm just going to say it....  (Read 14287 times)
Re: I'm just going to say it....
« Reply #50 on: Fri, 14 June 2013, 18:07:40 »
i like me ergodox sans stabilizers :D
LIES, you're just giving in to the lazy. :D
1.5x is maximum for un-stabilized cherry mx
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #51 on: Fri, 14 June 2013, 18:27:14 »
i tried one out like this on my right space bar, similar method to what you did but i used flush cutters and clipped them, then used some vinyl to make it fit. it wasn't really that i didn't like it it is that i didn't notice a difference, just more sound.
« Reply #52 on: Fri, 14 June 2013, 19:28:19 »
I think you may need to give it more time.
For example..  words that have higher row letters or numbers near the end ;uio7890
These would require you to move your hand UP a little.. so when you hit the bar, it'll be near the upper edges..
Conversely if you have nmy,./ near the end of a word, then you'd be on the lower edge of the space key
These are the places where it makes the greatest difference..
If you test it by just tapping it in the center, yea, it won't make much of a difference..
Also.. lots of lube takes away the rattle noise.. :D
That's the thing bout costar.. they rattle, but because of the loose contact, the action is much smoother than cherry.
Offline daerid
    • Rossipedia
« Reply #53 on: Fri, 14 June 2013, 19:46:43 »
I'll probably use some white lithium grease on the stabs just like I used to with my Filcos
Offline Larken
« Reply #54 on: Fri, 14 June 2013, 21:28:53 »
you're gonna have to do some extensive modding or use glue to secure the stabs on the ergodox. acrylic plates are too thick, and the cutouts aren't right either. imo, modding the plates for stabs are too much trouble for too little gain.
| Ergodox #1 | Ergodox #2 |
Offline knotra
  • I ­­­♥ ⌂ ♫
« Reply #55 on: Fri, 14 June 2013, 21:41:03 »
People can't imagine a keyboard outside of the rectangle...
I can, but I'm not spending 3 hours building one. If they came pre-assembled and had a return policy, I'd consider ordering.
Exactly the point. People buy funky shaped "ergonomic" keyboards all the time. Anyway, if anyone actually wants to start a business selling these, let me know and we'll see what can be done. Otherwise, don't complain.
^^ I would agree. There are a bunch of great keyboards that are self built and/or modded but the availability of them is limited. If someone were to sell them pre-assembled, I would buy it in a second.
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
Offline daerid
    • Rossipedia
« Reply #56 on: Fri, 14 June 2013, 22:15:26 »
Luckily the stabs were only $8, so if it doesn't work out no big loss
Offline Riddixk51PB
« Reply #57 on: Fri, 14 June 2013, 22:24:02 »
op is suffering from extreme buyers remorse and resorts to casting about with expletives in order to feel better about a blundering acquisition.
think outside the split, fail shaped, tenting, programmable rpg kbd box.
KBD: CM Storm QuickFire Pro, Cherry MX Brown
Mouse: Roccat Kone XTD (Avago ADNS-9800 High-Performance LaserStream™)
Offline CommunistWitchDr
  • >implying keyboards
« Reply #58 on: Fri, 14 June 2013, 23:03:39 »
If he was having remorse he could sell it for more than he paid in a second.
« Reply #59 on: Sat, 15 June 2013, 00:20:05 »
Not to mention, a keyboard previously used by me instantly gives its users Troll +999 mastery,  well worth the expense....
Offline tricheboars
  • Keyboards are Important!
« Reply #60 on: Sat, 15 June 2013, 01:26:48 »
tp4tissue what caps are you using? dsa? i hear those are the best with the ergodox.
edit: also just commited to massdrop if the ergo goes down to 199
« Last Edit: Sat, 15 June 2013, 01:40:27 by tricheboars »
« Reply #61 on: Sat, 15 June 2013, 01:58:46 »
I'm using the dsa mods.
But the rest I'm using OEM. I ordered both the DCS and the DSA.. the DCS I felt were harder to type with given the smaller verticle area, making the key-presses require more travel/ precision
The DCS worked better, but then i felt I liked to use my silicon rings which were too thick.. So I put on my old oem pbt-s
 The DCS mod is the current best for the 2x thumb keys   all dcs/oem/cherry thumb keys are not very good fits because of their slope..
I think the R4 keys would be good but alas they're too tall.
Offline libo720
« Reply #62 on: Sat, 15 June 2013, 23:29:36 »
Where can i buy one in North America?
Realforce 87U Tenkeyless 55g
Offline linziyi
  • The one with many questions
« Reply #63 on: Sat, 15 June 2013, 23:39:20 »
you mean DSA is a little difficult to type?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline Jagriff
« Reply #64 on: Sat, 15 June 2013, 23:46:06 »
I think the DSA caps are fine. Just like switches, you really have to try them before you can decide whether or not they're "for you".
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #65 on: Sun, 16 June 2013, 17:21:17 »
I'm guessing here: https://www.massdrop.com/
« Reply #66 on: Sun, 16 June 2013, 22:42:15 »
I concur it comes down to preference..
in this case i must be more specific.. I prefer the larger surface area of oem or cherry profile because it's easier to switch between rows as the distance is breached ever so slightly more than DSA.
:D
Offline Glod
    • YouTube Channel
« Reply #67 on: Sun, 16 June 2013, 22:54:13 »
i can see where you are coming from with the OEM/Cherry preference but it is indeed a personal preference and maybe the way you type as well. i seriously don't notice the difference anymore.
Offline daerid
    • Rossipedia
« Reply #68 on: Mon, 17 June 2013, 15:58:55 »
I think I'm actually going to agree with TP again: I much prefer DCS over DSA. However, for the thumb clusters and vertical buttons I still use the DSA caps. Now I just wish they had included some R3's with homing nubs (finding my way back to the home row is the biggest problem I have with the ErgoDox at the moment). Otherwise, 65g stickered clears on this thing is a dream. Gonna take a while to get used to the layout and retrain my muscle memory.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #69 on: Mon, 17 June 2013, 16:24:24 »
I made this for you tp:
« Reply #70 on: Mon, 17 June 2013, 17:22:50 »
That looks just like me..... :D
