Author Topic: "Ghetto" Topre?  (Read 4511 times)
"Ghetto" Topre?
« on: Thu, 13 June 2013, 20:35:25 »
This is something I've been thinking about for a little bit.  It seems you can get a keyboard or POS system like the Wincor-Nixdorf for cheap.  Looking at some internals from some of them, it looks like they use a thicker rubber overlay over a PCB or membrane.  It seems like you could get some cheap conical springs, toss them under the domes, and get a "ghetto" Topre keyboard.
Of course, this could just be the ramblings of a mad man.
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: "Ghetto" Topre?
« Reply #1 on: Thu, 13 June 2013, 20:38:43 »
The springs in Topre do not add to the feel of the switch they are only for the capacitince mechanism
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: "Ghetto" Topre?
« Reply #2 on: Thu, 13 June 2013, 20:40:11 »
they do add 5g according to one keyboard "expert"
Re: "Ghetto" Topre?
« Reply #3 on: Thu, 13 June 2013, 21:03:01 »
the work involved, you might as well just buy a topre... :D
Offline daerid
    • Rossipedia
Re: "Ghetto" Topre?
« Reply #4 on: Thu, 13 June 2013, 23:25:38 »
A typical rubber dome board doesn't even have a PCB, and the switching mechanism in a Topre board is pretty unique. I'm pretty much positive that this wouldn't work at all.
Offline Rule16
  • R.I.P. SmallFry
Re: "Ghetto" Topre?
« Reply #5 on: Fri, 14 June 2013, 10:02:55 »
Whats this? tp4 telling someone to buy a topre?! Well this is going in my signature.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
Re: "Ghetto" Topre?
« Reply #6 on: Fri, 14 June 2013, 12:06:40 »
Thought he'd say for sure:
Quote from: tp4issue
Screw that ****! Buy an ergodox and join the master race!
If you can mod a ****ty keyboard, why not create an awesome one instead?
« Last Edit: Fri, 14 June 2013, 12:08:43 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline fateswarm
Re: "Ghetto" Topre?
« Reply #7 on: Fri, 14 June 2013, 15:21:55 »
I'd rather properly lubricate MX browns and call it "ghetto topre". They are pretty good but the friction is immense (and I don't think it's only a problem when pressing them slowly, that's only the easiest way to consciously detect it). So any oiling that does remove the tactile event I think is an improvement.
I heard of issues of dust getting into them. It sounds easily fixable with blowing compressed air into them. It pushes out anything and it seems to not damage the mechanism.
