Author Topic: Is there a cure for Windows pimple caps on RFs?  (Read 2991 times)
Offline wendell
« on: Fri, 02 August 2013, 03:46:25 »
Some people find the Windows key rather obnoxious, especially the pimply ones. If I dropped the bucks required for a RF, I definitely would want to clear up that acne.
Is there a replacement cap that would match the rest on the board?
Offline Michael
  • Formerly Bro Caps
Re: Is there a cure for Windows pimple caps on RFs?
« Reply #1 on: Fri, 02 August 2013, 03:49:56 »
http://elitekeyboards.com/products.php?sub=access,toprekeys
Not really sets that you can buy for little money... but bleh.
Offline AKIMbO
  • HHKBro
« Reply #3 on: Fri, 02 August 2013, 07:21:42 »
You can buy hhkb key caps and use the 1x sized alt key caps in place of the bubbled windows keycaps on your realforce.
| KBD75 (box reds)
Offline MJ45
  • HHKB Pro
« Reply #4 on: Fri, 02 August 2013, 08:07:35 »
That is all you can do at this time, is use the HHKB alt/opt, comand/meta and fn keys which is nice for Mac users. Hopefully with more Topre keyboard models recently (Type Heaven, Leopold F660C)maybe more choices of keycaps will become available?
Offline AKIMbO
  • HHKBro
« Reply #5 on: Fri, 02 August 2013, 08:16:07 »
^Yeah....I still want my red alert set!
| KBD75 (box reds)
Offline wendell
« Reply #6 on: Fri, 02 August 2013, 11:24:14 »
...all you can do at this time, is use the HHKB alt/opt, comand/meta and fn keys...
Even that would be a big improvement. Is is possible to get some without buying a whole set?
Offline MJ45
  • HHKB Pro
« Reply #7 on: Fri, 02 August 2013, 15:44:39 »
They may be better if you call those bubble keys instead of pimple keys.
