Author Topic: Cherry MX Red vs Cherry MX Brown  (Read 27738 times)
Offline ike2030
« on: Sat, 03 August 2013, 09:30:46 »
Thanks to geekhack and many other forums I've narrowed down which type of keyboard I want. I play a game that needs a lot of rapid key presses and slides from one key to another. I know red and brown have about the same actuation force, but i tried the logitech g710+ in a store and i couldn't feel the tactile bump. All i could feel was mushiness from the O-rings. For the game i play i have to do movements like this:
I've been looking at the CM storm quickfire pro because it only has backlighting where i need it and it offers nkro over USB. So which one should i get, red or brown??
Re: Cherry MX Red vs Cherry MX Brown
« Reply #1 on: Sat, 03 August 2013, 09:32:13 »
if you want SERIOUS tactile, buckling is good.
all tactile mx are subtle when you're typing fast.
Sadly the ultimate layout of the Ergodox is only available in CHERRY mx.
And Layout trumps the switch type when it comes to actually USING a keyboard.
The people who love to TALK about keyboards will tell you differently.
But all avid USERS agree. EDx ftw. :thumb:
Offline ike2030
« Reply #2 on: Sat, 03 August 2013, 09:36:26 »
i think the tactile bump will just slow me down since i wont even feel it and its just extra force. IDK how to embed a video in here but if you go to the link in the original post you will see the keyboard movements i do.
« Reply #3 on: Sat, 03 August 2013, 09:40:04 »
Youtube links should look like: http://www.youtube.com/watch?v=5qm8PH4xAss
If you want a lot of switch reviews, check out this link.
« Reply #4 on: Sat, 03 August 2013, 09:40:07 »
Ta DA................... :p
also, Looking at this game,,  You would definately be served well with an ergodox.. and it is available with any MX switch..
Imagine playing that game, such that you can place the right and left hand anywhere, and you don't have to turn your wrist to match your keyboard, you can just turn the whole half of the keyboard.
Offline ike2030
« Reply #5 on: Sat, 03 August 2013, 09:56:00 »
When im gaming i just treat my keyboard like a piece of paper. SInce im right handed i slant the keyboard to my left so ergonomics stuff isn't really neccessary unless its substantially cheaper and actually works well.
Offline PointyFox
« Reply #6 on: Sat, 03 August 2013, 10:26:16 »
You'll want MX black switches and contoured keys like DCS.  MX red will also work too, but may result in some ergonomic issues due to harder bottoming out.
Offline ike2030
« Reply #7 on: Fri, 25 October 2013, 05:30:07 »
O-rings would help lessen the impact of bottoming out on the reds, right?
Offline Polymer
« Reply #8 on: Fri, 25 October 2013, 08:54:54 »
Browns have a very light tactile bump..you'll feel it when you type (it'll feel normal).  Pushing the key individually makes them feel weird and probably isn't a good way to test it.
You might not notice it but if you haven't used reds, you'll definitely see a difference...the reds will be a LOT smoother, actually quite a bit lighter as well...
Offline Linkbane
« Reply #9 on: Fri, 25 October 2013, 10:26:52 »
It's not extra force, it's still 45g to actuation. For gaming, I prefer Reds, but Browns, when I tried them, were much better for typing.
Also, there aren't any O-rings on the keyboards. Thought you should know that O-rings are aftermarket.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #10 on: Fri, 25 October 2013, 10:40:40 »
I prefer MX brown.
Offline Polymer
« Reply #11 on: Fri, 25 October 2013, 10:49:24 »
It is extra force...look at the force diagrams...same spring but the tactile bump adds to the resistance...It isn't a huge difference but enough to where you can feel it..using them side by side you can feel the difference...
Offline Linkbane
« Reply #12 on: Fri, 25 October 2013, 10:55:31 »
There's a bump; it's still 45g. The amount of pressure required to go past the bump hardly exists.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #13 on: Fri, 25 October 2013, 10:56:28 »
On the G710+ the bump is almost non existent. On my shine 3 I can feel a large difference.
Offline Polymer
« Reply #14 on: Fri, 25 October 2013, 10:59:35 »
See the force graph...compare the two...it most definitely exists..
They both actuate at 45g..but 45g actuation on brown is after the bump (after it drops off from the bump)...on reds it is linear...to actually get over the tactile bump on brown you're over 50g.
« Last Edit: Fri, 25 October 2013, 11:08:44 by Polymer »
Offline Linkbane
« Reply #15 on: Fri, 25 October 2013, 11:09:09 »
They both actuate at 45g..but 45g actuation on brown is after the bump...on reds it is linear...to actually get over the tactile bump on brown you're over 50g.
Two things: first of all, periods do not act as commas, no matter how many you use.
Second, I have seen the force graph. I've also tried the switch and listened to the opinions of many users; about all of us agree that the tactility is very light, hardly noticeable. It might be higher, but it's again still low enough that it's not noticeable.
Offline ynrozturk
« Reply #16 on: Fri, 25 October 2013, 11:09:46 »
I just like the feeling of Browns so much more. I never really liked any of the linear switches.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Polymer
« Reply #17 on: Fri, 25 October 2013, 11:11:33 »
And people shouldn't make comments about stuff they haven't used but that hasn't stopped you.  Attack my ... all you want...does it help your argument?
No.
Why?  Cause you're wrong.  It requires more force.  That is a fact.  It is an actual objective fact.  You're wrong.  Move on.
Changing your argument now to "it is more but it doesn't feel like it" should have been your original argument...but you quoted how they're both 45g..which means you completely ignored the fact that the bump requires MORE force than the actuation point...probably because you didn't know....
Game.  Set.  Match.
« Last Edit: Fri, 25 October 2013, 11:28:09 by Polymer »
Offline Linkbane
« Reply #18 on: Fri, 25 October 2013, 11:27:18 »
Funny guy polymer. Offended when I point out something unrelated and completely separate it, telling everyone that it has nothing to do with the argument.
Have fun convincing everyone that the tactility is significant. I'm sure that they'll agree with you.
Really it's pretty sad watching you take some self-righteous opinion on and making it seem even more wrong than it is. Continue arguing with yourself. //thread
« Reply #19 on: Fri, 25 October 2013, 11:30:20 »
No.
Game.  Set.  Match.
wo wo wo.......   I am the master of the................ ... ................../ disapprove................................................
I've even got that emoticon for it....
Offline Polymer
« Reply #20 on: Fri, 25 October 2013, 11:30:28 »
I'm not offended at all...I just think it is a pathetic attempt to deflect your mistake.
The bump requires more force.  It isn't an argument, it is a fact.  You argued they're both 45g so therefore it doesn't require more force..but that doesn't make any sense since the 45g is after bump which is a drop off in force from the actual bump.
Continue to make your bad argument..hide the fact that you made a mistake....why not just man up and say you didn't realize they were different?
BOOM.  HEADSHOT.
« Reply #21 on: Fri, 25 October 2013, 11:32:05 »
The bump requires more force.  It isn't an argument, it is a fact.  You argued they're both 45g so therefore it doesn't require more force..but that doesn't make any sense since the 45g is after bump and after the drop off.
BOOM.  HEADSHOT.
Polymer... you can chill dude... I think the point is that when typing fast... the bump on browns is below the just-noticeable threshold... It's just too small.
Offline Polymer
« Reply #22 on: Fri, 25 October 2013, 11:38:12 »
BOOM.  HEADSHOT.
I agree..the bump is really small..not disagreeing with that at all...as I type this with MX browns...But I think the point is, it does require slightly more force..it is noticeable..and unlike what's his face, I'm actually comparing the two right now...it isn't a huge difference but it is slight...
But he goes out of his way to actually convince people he's right when factually he's absolutely wrong...he's even mixing up his facts quoting they're both 45g actuation so therefore they require the same force....which is absolutely false because while both have 45g actuation..they both don't require the same amount of force...And you know what?  All someone would need to say is.....oh..yeah, I made a mistake.  That ends it right there.  But that won't happen.  He's faced with actual facts and it still won't happen...Instead he's now making up some silly excuses...it is actually pretty pathetic.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #23 on: Fri, 25 October 2013, 11:42:58 »
Reds and Browns have the same actuation force and travel distance. Only difference is the tactile bump in the brownies, either switch is great, just preference. Try them both, you eventually will :).
Offline dante
« Reply #24 on: Fri, 25 October 2013, 11:59:45 »
BOOM.  HEADSHOT.
For me it's noticeable enough for a +15 wpm gain.
Offline Linkbane
« Reply #25 on: Fri, 25 October 2013, 12:49:46 »
I typed on it and I feel as if I could type about as fast as blues. It's there, miniscule perhaps, but it's there.
I doubt that it would give me 15 wpm, perhaps 10 wpm is a better estimate. Not a fan of Reds, I can't get higher than a bit over 130 on those.
« Reply #26 on: Fri, 25 October 2013, 13:01:56 »
BOOM.  HEADSHOT.
Polymer I know too well the RAGE that you feel...
In fact, After the mods banned me for the 5th/6th lost count time... I finally took to reflecting... We may be people with "too much passion" for facts.....  And this coupled with an unchecked ego over the web, results in the heated discourse that often transpires.
We could all be much happier in co-existence if we took the step back to ameliorate our tone of engagement.
I am not above admitting that in the past I may have been overly rambunctious...
Offline ynrozturk
« Reply #27 on: Fri, 25 October 2013, 13:09:00 »
You're actually a very decent guy when you're not rambling about the Ergodox every two minutes.
« Reply #28 on: Fri, 25 October 2013, 13:09:30 »
i believe there was a speed discussion a while back.. and some conclusions were that it comes down to how fast you can "mentally" parse what you are reading..   The influence from the keyboard itself is minimal.
This is relative to ULTIMATE achievable transcription speed... it comes down to memorizing "finger rolls" n-graphs... like t-ion, tre-e, poin-t.. upp-er , those are trigraph, trigraph, quadrigrph, and digraphs
When you memorize the finger rolls of common n-graphs, they can be executed with far greater speed during mental parsing.
VS
I don't really remember how to spell gundanium until I sound it out... which is significantly slower.
Offline Oobly
« Reply #29 on: Fri, 25 October 2013, 13:10:11 »
Let me just throw in my 2 cents: I use browns and that little tactile bump makes a HUGE difference to the feel for me and how I type & game. For me, it's a good thing, for others, it depends how they use their keyboard.
Semi-related info: The shock from bottoming out all the time if you really mash the keys can be detrimental to your fingers' long term health, just in case you didn't know.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline ynrozturk
« Reply #30 on: Fri, 25 October 2013, 13:13:23 »
VS
That is very true. Speaking for myself, my brain can't keep up with my fingers all the time. I need to work on what you just said - to sync the two together.
« Reply #31 on: Fri, 25 October 2013, 13:14:25 »
Haha.. there was the thing in the bible warning us about "idols".. The deep-end of such envelopment had beco-meth me at times regarding the Egdx...
But.. sigh.. please do not let my rough-conduct deter any of you towards the impeccable merits of the Egdx.
« Reply #32 on: Fri, 25 October 2013, 13:19:39 »
I believe this is why they use dampeners in pianos.. because for certain crescendos in charged-pieces, you literally have to get out of your seat and cast ragnarok the keys..
I've also noticed many OLD OLD players having to wear these rubber tip things on their fingers because they've damaged the nerve endings in their hand from too-much-ragnorok...
Offline C5Allroad
« Reply #33 on: Fri, 25 October 2013, 15:15:00 »
The bump is almost non existent. Doesn't require a HUGE amount of force to pass it. It's very subtle though.
Offline Linkbane
« Reply #34 on: Fri, 25 October 2013, 15:30:05 »
VS
It is true that mental speed determines speed, but that's only a maximum; the keyboard can get in the way of your speed. I need to confirm that I've done a word before I move on to the next one, and using a linear switch or membrane makes me do too way too much rather than the click of a Blue. Also, reds are sometimes light and my fingers tend to make errors because the fingers must move across very quickly and errors can happen when it brushes a key with enough force; this happens less on tactile and stiffer switches.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #35 on: Fri, 25 October 2013, 16:11:19 »
Here are my two cents on the topic.  I have used both switches and this is my experience.
If you ALWAYS bottom out the keys, then you probably will not notice much of a difference between the two.
When I type quickly I don't always bottom out the keys.  Because of this, I find on reds that sometimes I have to actually check to see if a letter was typed when I do not bottom out.  That is the main reason why I prefer browns.  When I type, my fingers know if the key pressed.  There is not much of a bump when you are looking for it, but when you are just typing and not paying attention, it is enough of a bump that your fingers know you hit it.
I can type much faster on browns than reds simply because I know whether or not the key was pressed without having the check.
Hope that is helpful for someone...
« Reply #36 on: Fri, 25 October 2013, 16:35:59 »
for that game, you'll likely be bottoming out whatever switch you get. I recommend O rings or soft landing pads to give your fingers a bit of a rest.
Reds don't give any indication when the switch actuates, so you have to learn to "float" your fingers and not bottom out. Once you get this down, typing can be a real breeze. I don't think it'll help your gameplay at all, unless you plan to ride the actuation point on the switches.
Oh, and I recommend a sturdy plate mount keyboard, which should well handle the abuse you'll no doubt put into it :p
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #37 on: Fri, 25 October 2013, 16:52:13 »
I also put o-rings on both my reds and my browns.  I like the way o-rings make the bottom out feel and it also shortens the keystroke distance.
I game on browns with no problems at all...
« Reply #38 on: Fri, 25 October 2013, 20:47:50 »
I don't believe hit-confirming would make typing faster.. if anything it would slow it down.
because fast typing relys on rolling the n-graph... it doesn't matter if you're @ 100% accuracy...
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #39 on: Fri, 25 October 2013, 21:00:36 »
If I understand you correctly, I think you and I are saying the same thing...
- On browns, I never have to check what happened cause my brain already knows.
- On reds, I have to look at the screen to know if the keystroke registered when I am typing fast and don't bottom out the key.  I find that slows me down.
I am more comfortable on browns.
Offline Tony
« Reply #40 on: Fri, 25 October 2013, 21:09:35 »
Red is good for FPS where you press the same keys repeatedly with all your strength. (Duck, fire, headshot, then duck again!)
Brown is good for typing and RTS where you press multiple keys but in different orders each time, and you need to know for sure you have pressed the right keys. (Get gold, build some buildings, then build some archers and fighters, then gather to attack, while continuing to mine golds and stones)
« Last Edit: Fri, 25 October 2013, 21:12:37 by Tony »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #41 on: Fri, 25 October 2013, 21:29:20 »
Offline soleusrex
« Reply #42 on: Fri, 25 October 2013, 21:35:42 »
For some reason I find this description of RTS gameplay really funny. Mine golds and stones!
« Reply #43 on: Sat, 26 October 2013, 10:19:18 »
All the talk in this thread is so cheap.  It's just a matter of what you prefer.  WAY overanalyzed.
« Reply #44 on: Sat, 26 October 2013, 11:56:20 »
why cheap
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #45 on: Sat, 26 October 2013, 12:39:25 »
I agree, but if someone does not have the chance to try the switchs before buying, these types of threads are helpful.
Offline Linkbane
« Reply #46 on: Sat, 26 October 2013, 16:18:18 »
Fast typing relies also on your ability to recognize when you've hit a key and press the next one. At very high speeds, the speed in which you type your word is extremely important, and confirming definitely does help. The whole point about a mechanical is not bottoming out.
But I mean, it's no different if you're on an MX Red or Blue if you never bottom out. It's just much easier to not do it on the Blues.
« Reply #47 on: Sat, 26 October 2013, 16:33:30 »
but superstar sean wrona bottoms out.
Offline Linkbane
« Reply #48 on: Sat, 26 October 2013, 16:35:15 »
He only seems to do it partially to me. But Sean Wrona's mind and ability is so advanced beyond most peoples', he can do whatever he wants.
« Reply #49 on: Sat, 26 October 2013, 16:35:47 »
well... i'm just trend spotting's all.
I believe his ability comes from immense concentration.. it looks as if he forgot to breath at times..
I've seen some higher-up fighting-game players that forget to breath as well.
