Author Topic: my computer is too ugly for my keyboards...  (Read 9268 times)
Offline acantha
  • Aure Entuluva
« on: Mon, 12 August 2013, 16:24:12 »
i'm not a hardcore gamer, so i don't go in for the neon fans and other gamer case flash, but i really wish there were pc cases with half as much style as some of the keyboards i own. i've got an ugly old case with my linux server in it and a macbook pro. the macbook is nice but aesthetically kind of clashes.
anyone else feel this way? what cases are people using that go with their keyboards?
(full disclosure: i'm on a gibson/cyberpunk tear right now, so this complaint is at least partially inspired by a frustration that my gear doesn't look like a cyberspace deck)
All the Happy Hacking Things
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: my computer is too ugly for my keyboards...
« Reply #1 on: Mon, 12 August 2013, 16:25:12 »
hide it under the table and buy more keyboard stuff!
Offline baldgye
  • Will Smith Disciple
« Reply #2 on: Mon, 12 August 2013, 16:25:22 »
the plain looking Lian-Li cases are probably the best looking PC cases IMO
« Reply #3 on: Mon, 12 August 2013, 16:28:54 »
You should really go caseless.
Something like this:
« Reply #4 on: Mon, 12 August 2013, 16:29:40 »
Whoa!! Watch your fingers.....and cats.....;)
Offline acantha
  • Aure Entuluva
« Reply #5 on: Mon, 12 August 2013, 16:41:46 »
yeah thats actually kinda awesome. except for the aforementioned danger to digits and pets.... pretty easy to cool i bet.
Offline ekw808
  • Ekw
« Reply #6 on: Mon, 12 August 2013, 16:47:04 »
Corsair has a good pretty line of plain cases, depending on what you need to house, I'm sure their cases would be sufficient.
http://www.corsair.com/en/pc-cases/carbide-series-pc-case.html
[One Keyboard at a time]
Offline Flyersfan1
  • Hi!
« Reply #7 on: Mon, 12 August 2013, 16:54:20 »
If you're interested in a case that provides good bang for your buck, I'd recommend a Fractal Design R4.  It has a really nice minimal/sleek look to it and provides great cable management options along with great airflow.  It's also whisper quiet too.  Only con might be that it's pretty gigantic.
« Last Edit: Mon, 12 August 2013, 16:56:02 by Flyersfan1 »
Quote from: Photekq
Offline Badwrench
  • ummmm.....I forgot
« Reply #8 on: Mon, 12 August 2013, 17:20:12 »
This.  I had an old PC-65B, and went to a Corsiar 650T in white.  Too big and heavy.  Went back to Lian Li (PC-A05F- modded to inversed A05).  Much better and smaller.  I don't tinker near as much as I used to, so no need for a giant case.
Offline phoenix1234
« Reply #9 on: Mon, 12 August 2013, 17:35:37 »
First, I think it depends on form factor: micro ATX, mini ATX, ATX...
Second, it depends on how much you gonna spend.
Third, it depends on how convenience the case is: fans, usb3.0 ...
If you prefer something small, you can take a look at these brands :
- Zotac Silver Stone
- Factal
- Lian Li
If you prefer something huge, you can take a look at these brands :
- Cooler Master
- Factal
- NZTX
- Corsair
- Thermaltake
So, to choose a right case, actually it is a very hard decision. :))
For example, Case CM - N200:
http://www.coolermaster.com/product/Detail/case/mini-tower/n200.html
could be a very good choice for someone who needs usb 3.0, cheap, small form factor but can support big graphic card, SSD, 3 fans...
I like linear switches
« Reply #10 on: Mon, 12 August 2013, 18:26:51 »
No do not leave it horizontal like that.
Dust will settle in the small grooves, and if the humidity is just right.. some small shorts can occur.
Use a regular case, and just open the side door, so the setup is vertical, and the dust will not settle directly on the pcb
« Reply #11 on: Mon, 12 August 2013, 19:08:56 »
Anyone have a fishtank submerged computer they wanna post up?
« Reply #12 on: Mon, 12 August 2013, 20:54:14 »
What about one mounted in a mini refrigerator?
Offline Thimplum
  • Master of all Ponies
« Reply #13 on: Mon, 12 August 2013, 21:02:24 »
I've ALWAYS wanted to do this.
TP4 FOR ADMIN 2013
« Reply #14 on: Mon, 12 August 2013, 21:13:46 »
Bad idea. mini-frig cannot pull heat away fast enough to make it worth your while.
On top of that, you still have to deal with condensation.
Also, exotics such as compressor cooling is non-practical for 24/7 use unless you wire the computer to be in the basement.  WAY TOO LOUD otherwise
« Reply #16 on: Mon, 12 August 2013, 21:24:51 »
I've done that, but only while testing hardware and only for a few minutes.
I would not want to leave a PC like that - apart from fingers and pets, dust would accumulate.  Cooling would suffer.  EMI would increase.
« Reply #17 on: Mon, 12 August 2013, 21:28:44 »
Cooling is always better in open configs.
EMI may increase, but Nothing in a normal desktop is terribly sensitive to EMI..
Offline sth
  • 2 girls 1 cuprubber
« Reply #18 on: Mon, 12 August 2013, 21:30:56 »
not when you have components specifically designed to dissapate heat with outside help. airflow, dawg!!
« Reply #19 on: Mon, 12 August 2013, 21:32:32 »
Cooling in a hot humid room would be worse without fans directing airflow across the components.
I was thinking about EMI caused by the computer and affecting nearby devices.
Offline nullstring
« Reply #20 on: Mon, 12 August 2013, 21:38:17 »
I'm partial to the antec three hundred two.
That Fractal Design R4 doesn't look too bad either.
Offline Linkbane
« Reply #21 on: Thu, 15 August 2013, 04:47:42 »
Probably just because I'm a fan of their KBs, Cooler Master makes some great looking towers. I wouldn't use one, as a laptop person, but you know.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline Feign
« Reply #22 on: Thu, 15 August 2013, 05:07:37 »
I like the look of a lot of Lian Li stuff. I have a pretty beefy Lian Li PC-A76. Kinda looks like a Fractal Design R4 - also nice.
Offline lucifurburch
« Reply #23 on: Sat, 17 August 2013, 03:45:52 »
I'm a big fan of case labs they make cases with a range of customizable options most of them are more like server cases then your typical pc. i have the MAGNUM STH10 i got it because it has a lot of room for water cooling and cable management also its hidden hard drive/ssd bays are nice. Its good if you need a lot of internal space but want a professional looking gaming pc.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #24 on: Sat, 17 August 2013, 04:08:32 »
My ideal case would be a solid matte black perfectly shaped rectangular prism. The on button would be capacitive touch, and have zero visual indication to it's location. It would have to be extra tall to allow for the cd drives and the like to be on the back of the case with the ports. None of those stupid clear side panels either. I instantly hate your computer if it has a clear side panel.
Actually I would like most things to be matte black rectangular prisms. I am not one for flair.
Also it's 1/8 inch thick anodized titanium.
« Reply #25 on: Sat, 17 August 2013, 04:32:31 »
I use an 800d with no LEDs.
Offline Tym
« Reply #26 on: Sat, 17 August 2013, 05:19:06 »
Fractal Design XL R2 is wonderful!
I have a thread where people suggested alot of good cases here
http://geekhack.org/index.php?topic=46100.msg970080#msg970080
« Reply #27 on: Sat, 17 August 2013, 08:08:56 »
Accidentally drop a coin down there and witness the magic smoke. (happened to me... not fun ... :( )
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #28 on: Fri, 23 August 2013, 18:15:41 »
I JUST USE A BEIGE BOX CASE WITH MY BEIGE KEYBOARD. THEY BOTH WERE FROM THE 90'S SO THEY GO GREAT TOGETHER.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #29 on: Fri, 23 August 2013, 18:53:39 »
CaseLabs!!! I'm a bit of a fan...
« Reply #30 on: Sat, 24 August 2013, 04:07:02 »
I currently use a Model M connected to a Mac mini.
Could go either way ...
« Reply #31 on: Sat, 24 August 2013, 12:19:48 »
EEW
Offline Leslieann
« Reply #32 on: Sat, 24 August 2013, 21:30:35 »
I hate how they call anything with lights "gamer", I don't know what lighted fans have to do with gaming. It's just a lame marketing ploy.
Most of my lighted fans, I cut the leads to the lights.
I'm more a fan of the cube/refrigerator look, just a small ominous black box with decent cooling works for me.
And then I shove them in a corner of my basement. LOL
Personal favorites are the Fractal Core 1000 and the cheap Powerspec line. $25-$40 for a full mesh fronted MATX case... I've had 3 of each. With very little modding you can put a 240mm watercooler in front and with a bit of work. I even converted a Core 1000 to full ATX. All with plenty of airflow.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
