Author Topic: Natural Sleep Aid  (Read 13906 times)
Re: Natural Sleep Aid
« Reply #50 on: Mon, 19 August 2013, 21:02:38 »
kawa is asian, i am not.
im mexican.. so that doesnt make it any better lol.
diabetes runs in my family, and i lost both my grandparents thanks to it. so yeah, i try not to fall into it as much as possible.
mm hmm. gotta cut back on those high-carbs.
« Reply #51 on: Mon, 19 August 2013, 21:03:22 »
gotta cut back on a lot of ****.
but when you're accustomed to it, it's a little hard. but not impossible.
« Reply #52 on: Mon, 19 August 2013, 21:11:41 »
I did much homework on the subject.  the Diabetes part pretty much ONLY comes down to carbohydrate intake.
You can stuff yourself with as much Fats and Protein, it will not affect your blood sugar level anywhere near what can happen with a bag of cookies.
If diabetes is your "big-agenda"   then high-carbs is the only substance you need to regulate.
Feel free to eat 10 steaks... you'll be fine..  well you should probably also eat celery sticks with 10 steaks unless you want severe constipation.
Offline iri
« Reply #53 on: Tue, 20 August 2013, 05:39:57 »
i've cut back on ice cream. was even harder than to hop off heroine.
-Ray Bradbury
Offline TheQsanity
  • SmallFry Lovin'
« Reply #54 on: Tue, 20 August 2013, 09:13:08 »
Seraquel ****s with your sleeping. Take enough of it and you can be out for 24 hours. Its really hard to sleep without it once your on it. But yeah it knocks you out. You can fight it but 30 minutes after it kicks in, you're out.
Does melatonin promote better sleep once youre asleep? I hear that its "naturally occurring" "perfectly safe" and all but can it really **** you up?
SmallFry! <3
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #55 on: Tue, 20 August 2013, 09:18:00 »
benadryl is the classic "knock you out without any side effects". toxicity is basically negligible (you have to do like a cinnamon challenge for it to kill you). that said, it has immediate metabolic side effects and does screw with hormonal sleep structures, so don't take it habitually. it can become habit forming (like every other sleep aid) in that it becomes difficult to sleep without your sleep aid as a trigger.
the best way to regulate your sleep artificially is light exposure. look up light therapy. it is also clinically proven to help with seasonal depressive disorders.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #56 on: Tue, 20 August 2013, 09:22:46 »
I saw a YouTube video on that. Using artificial light or electronic devices at night time messes up your natural sleeping pattern, before the invention of the lightbulb.
feature=youtube_gdata_player
I know its not light therapy but I guess its in a similar realm.
SmallFry! <3
Offline mkawa
« Reply #57 on: Fri, 23 August 2013, 22:21:51 »
no need for youtube videos. the literature on it is quite readable. the basic idea is to expose yourself to as much sunlight or artificial UV-filtered light as possible in the morning within 15 minutes of waking up, and then to taper off your light exposure after noon. studies worked with about 10klm aimed downward at about a 30 degree angle to simulate sunlight. while doing this, you also need to practice superb sleep hygiene, going as far as timing meals and eating specific compositions and compounds at mealtimes. it can also help to use blue-light filtering glasses, as the eyes are particularly sensitive to light in the blue spectrum.
when performed properly, it has been empirically shown to be extremely effective at allowing one to regulate sleep structures _without medication_. however, as these things usually are, it is quite difficult to do properly, and should be guided by a professional
in studies, melatonin was shown to be effective when used in a very specific way. basically, melatonin is produced naturally with the tapering of light exposure by the pineal gland, and typical serum levels are in the 0.25mg range at peak. hence, if you find that your body is not producing melatonin on schedule DESPITE the above, very small dosages (most synthetic melatonin is just metabolized..) in the 0.5mg range about 4-5 hours before your timed bedtime have been shown to sometimes help speed up the process of recovering normal or desired hormonal rythms. Note that I specifically mentioned timed bedtime. sleep hygiene and light therapy call for timing wake-up time, bedtime, and mealtimes, _strictly_, and gradually pushing them toward your desired wake-up and sleep-time.
the summary of all this research is basically that sleep cycles in a normal healthy person are really determined by a few very important things, most importantly light exposure and meal times and compositions. you can use this information to do incredibly bizarre things to your sleep cycles, or to make it more normal. that is, IF you are a normal healthy person. there are a number of what are most likely hereditary disorders in which some people have abnormal responses to this stimuli, and for those people, this regimen can be ineffective or must be modified. hence, if you have serious problems in functioning because of sleep cycle issues, the best course of action is to see a specialist.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #58 on: Sat, 24 August 2013, 09:05:32 »
I'm doing night shift work for some weeks now, but for some reason I feel much more vital and less sleepy compared to morning shifts (have to get up at 4:30 then).
Seems sleeping all day and being up all night somehow fits my routines, habits, and natural sleep cycle much better, and getting more moneyz is another plus... :3
But, today I went up early and my eyes had serious problems getting adapted to the sun light, took like a half hour instead of some minutes, DAT GLARE! :cool:
A Ghost From The Past
Offline mkawa
« Reply #59 on: Sat, 24 August 2013, 09:17:42 »
this research was actually started in alaska/antarctica/iceland and other places really far north of the equator where there is no natural light at all for huge parts of the year and then TOO MUCH natural light for the rest. basically, they started playing around with light and discovered that you can artificially regulate sleep structures (which is what they call the hormone release and uptake patterns). so yah, you can do this same process but target it for your night shift and the cortisone will release at night instead of in the morning. when you start working day shift again, just gradually move your cycle back toward the day.
the gold standard in light boxes is the company now called "sunbox". their sunray is what was used in the clinical studies: http://sunbox.com/?products=sunray-ii
the important part of lightboxing is that the light is full spectrum (and not, oh yah it's full spectrum but tapers off by 6db at the upper and light limits of light emissivity..), uv filtered and consistent.
Offline mkawa
« Reply #60 on: Sat, 24 August 2013, 09:18:18 »
the sunrays are also bright as well get out. they will actually get 10k lux into the light receptions in your eyes (rods and cones ****)
« Reply #61 on: Sat, 24 August 2013, 10:29:49 »
you mean.. go "out side" as in afk, with the grass, and leaves thing?
Why can't I just look out the window?
Does this work if I look out the window?
Offline mkawa
« Reply #62 on: Sat, 24 August 2013, 10:32:49 »
no, you need to go outside. even on a somewhat cloudy day, you can absorb the necessary light. the most sensitive receptors w/rt light and hormonal release in your eyes are kind of at the bottom of the retina, so the most effective way to get your light exposure is to take a 15 minute walk. it HAS to be within 15 minutes of waking up though. sleep hygiene says: "when you wake up, get out of bed immediately" light therapy says "immediately go outside after you get up and absorb some damn light in the cones of your retina"
« Reply #63 on: Sat, 24 August 2013, 15:41:55 »
Ok kawa..
I'ma do this tomorrow.
Risking exposure to the elements.
