Author Topic: My "keyboard"  (Read 9989 times)
Offline rolito223
My "keyboard"
« on: Mon, 26 August 2013, 12:24:22 »
Hello everyone! I have this... "thing" I want to know if someone have the software to program it... It's a tysso pkb-080, but I can't found anything more in the web... thanks!
Offline nappi11
  • #finnsofgeekhack
Re: My "keyboard"
« Reply #1 on: Mon, 26 August 2013, 12:42:24 »
At least it looks cool, and the switches seem to be cherry mx mounted.
Focus FK-747 A (Complicated Blue Alps) - Compaq RT 235BT (NMB Dome with slider) -  Irish Key Tronic (Rubber dome) - Ducky Mini (Cherry MX Blue) - Dell AT102W (Complicated Black Alps)
Offline tricheboars
  • Keyboards are Important!
Re: My "keyboard"
« Reply #2 on: Mon, 26 August 2013, 13:09:34 »
well the layout would be awful for typing, but if you can program it that thing could be quite useful for certain apps or even your OS.  get some cherry windowed caps and make it what you want. dont try to type normal with it though. that would be awful.
Offline rolito223
Re: My "keyboard"
« Reply #3 on: Mon, 26 August 2013, 13:12:19 »
It's something! :thumb:
what if I dissambly this? whit the eeprom's name I can do something?
Offline eth0s
  • Peace & Love
Re: My "keyboard"
« Reply #4 on: Mon, 26 August 2013, 13:15:04 »
well, as long as it has cherry MX switches, you can always get replacement keycaps.  However, you are going to need a "flat" family like DSA.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Mon, 26 August 2013, 13:17:10 »
« Last Edit: Tue, 27 October 2015, 10:09:01 by esoomenona »
Offline Obakemono
Re: My "keyboard"
« Reply #6 on: Mon, 26 August 2013, 13:20:50 »
Hi, found this page that seems to be an old fametech site, it links to files in the tysso webpage
http://www.angelfire.com/ok5/barcode_reader/#utilities
This is the driver/utilities for you, the links are in the old page but the files are hosted in the new one, where there is no reference to model 080
http://www.tysso.org/software/pkb080.zip
Offline esoomenona
  • Gnillort?
« Reply #7 on: Mon, 26 August 2013, 13:22:29 »
« Last Edit: Tue, 27 October 2015, 10:09:10 by esoomenona »
Offline rolito223
Re: My "keyboard"
« Reply #8 on: Mon, 26 August 2013, 13:23:13 »
First, those don't look like MX switches. Though they do look like they might take MX caps.
Second, if you get to programming it, maybe a layout like this might be ergonomic?
I don't know if the caps be like MX but it doesnt' worry me now... the ergonomic layout looks to be great (If I can find the way to program this, I can put 3 diferent layouts on it)
The tysso web site looks like a nigthmare, I can't get anything from anyway for this little old man...
Offline Obakemono
Re: My "keyboard"
« Reply #9 on: Mon, 26 August 2013, 13:26:10 »
Again, you just need to click in the second link, but i don't know if the drivers/utilities will work on whatever windows version you use
Offline rolito223
Re: My "keyboard"
« Reply #10 on: Mon, 26 August 2013, 13:26:33 »
wow! I did't found that website! god demmit google... thanks!!!! :thumb: :thumb:
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: My "keyboard"
« Reply #11 on: Mon, 26 August 2013, 15:30:26 »
Weird …
Definitely not Cherry MX.
They're not vintage SMK either.
They're not Marquardt either.
I don't know what those switches are — we need better pictures!
Bore Awards
Offline rolito223
Re: My "keyboard"
« Reply #12 on: Mon, 26 August 2013, 19:18:39 »
You want it, you got it. better pictures:
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: My "keyboard"
« Reply #13 on: Mon, 26 August 2013, 21:51:45 »
Marquardt switch, but it is different than those I have seen in keyboard before. This has different slider shape not the keystone shape that is usual. How do they feel like, are they a stiff or soft switch?
Offline rolito223
Re: My "keyboard"
« Reply #14 on: Tue, 27 August 2013, 13:21:39 »
there are soft
Offline Obakemono
Re: My "keyboard"
« Reply #15 on: Tue, 27 August 2013, 14:32:20 »
Give as an update if you get it to work!  :D
Offline rolito223
Re: My "keyboard"
« Reply #16 on: Tue, 27 August 2013, 17:05:48 »
don't worry about that!!  :D :D
  • RIP
    • Boring twaddle
Re: My "keyboard"
« Reply #17 on: Wed, 28 August 2013, 02:46:18 »
Bore Awards
Re: My "keyboard"
« Reply #18 on: Wed, 28 August 2013, 02:59:58 »
my smoking emoticons are cooler
  • RIP
    • Boring twaddle
Re: My "keyboard"
« Reply #19 on: Wed, 28 August 2013, 17:16:19 »
It would be interesting to see the PCB on that board, and just confirm that Marquardt didn't make it on behalf of Tysso. (i.e. what name(s) is/are on the PCB)
Bore Awards
Offline rolito223
Re: My "keyboard"
« Reply #20 on: Mon, 21 October 2013, 21:44:59 »
hello again! I have a little problem with my "keyboard", when I plug the adapter for ps2 to USB the leds turns on and I can't configure any key... someone knows where is the problem? many thanks guys!
PS: Im using a nisuta adapter! thanks
Offline Zeal
    • Zeal Generation Inc.
Re: My "keyboard"
« Reply #21 on: Mon, 21 October 2013, 23:00:59 »
Those Marquardt switches look interesting. Do the exposed spring cause any problems when dust and particles fall into it? Are Marquardt keyboards EOL?
Re: My "keyboard"
« Reply #22 on: Mon, 21 October 2013, 23:29:54 »
Generally it isn't possible to do the programming when using a PS/2 to usb converter on programmable keyboard, only after it's programmed. Also in majority of case you must use 32bit Windows for the programming utility to actually work.
Offline rolito223
Re: My "keyboard"
« Reply #23 on: Thu, 24 October 2013, 06:21:42 »
I try it, doesn't work... may be if a use DOS in an old mother whit AT conector?
I think this keybord it's "trulado"...
thanks!
