Author Topic: Key spacing on blackwidow  (Read 2139 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Sun, 08 September 2013, 12:27:32 »
Is the spacing on the blackwidow a standard key spacing? Is is wider?
Offline Obakemono
Re: Key spacing on blackwidow
« Reply #1 on: Sun, 08 September 2013, 12:29:34 »
I think is 6.25x
Ooook, spacing, not space bar xDD
« Last Edit: Sun, 08 September 2013, 12:41:51 by Obakemono »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Sun, 08 September 2013, 12:30:51 »
bottom row is 1.5x and 1x
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #3 on: Sun, 08 September 2013, 12:34:43 »
bottom row is diff.
everything else is standard.
« Reply #4 on: Sun, 08 September 2013, 14:16:12 »
Key spacing is 3/4" as on any other keyboard. You can use standard Cherry MX keycaps for most keys.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Sun, 08 September 2013, 15:54:38 »
It's standard spacing as far as I know.  BUT I don't know why every time I type on it my hand feels crammed.  Maybe it has a slightly narrower key top surface I'm not too sure.
But according to science it's suppose to be the same.
Offline Leslieann
« Reply #6 on: Sun, 08 September 2013, 16:28:46 »
The key shape is unusual, the spacing is not.
This was part of their problem, the keys would rub each other, catch a corner and stick.
On the one I parted out, the molds for the keys, were off a bit. If I remember right, the left ALT would rub the spacebar and get stuck, as would the left shift against the A key. A little scraping with a razor blade along the bottom edges sorted them out.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline C5Allroad
« Reply #7 on: Sun, 08 September 2013, 16:47:13 »
Oh ok because I typed on my friends board and it's really weird for me to type on.
Offline Leslieann
« Reply #8 on: Sun, 08 September 2013, 19:19:57 »
I think their "hand picked" means they are picking matched, odd spring rates or something.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
