Author Topic: Help!: Type Heaven or Leopold  (Read 5485 times)
Offline Metatron
« on: Sat, 14 September 2013, 05:03:28 »
Hello everyone, I am looking to buy my first real keyboard and have narrowed it down to these two but can't make a final choice on what to get. Im looking for a keyboard that will primarily be used for gaming but I don't want any of the silly extras like macro keys or backlit (I know how to touch type -_-), other then that general typing and a long loving relationship is what I need. I have been using a wireless ergonomic rubberdome microsoft keyboard for the past 6 years and honestly really do love it, that said I have used some Cherry keyboards and really would like to move up to a respectable board. From the research I have done I think I would like the MX browns most but the MX brown leopold has no ETA on restock so Ive settled on reds if I go that route. I think I will eventually get PBT caps for whatever board I do get. If you want me to answer anything else you think is important just ask.
Leopold: http://elitekeyboards.com/products.php?sub=leopold,fullsize&pid=fc500rrab total=$100
Type Heaven: http://www.elitekeyboards.com/products.php?sub=topre_keyboards,1&pid=za0100 total=$165
From how I see it its a high quality Cherry board or an entry point Topre board, what do you think I should pick up and why?
Thanks for any/all the help!
Re: Help!: Type Heaven or Leopold
« Reply #1 on: Sat, 14 September 2013, 05:28:51 »
Welcome to Geekhack!
If primarily for gaming - do you really need the numeric keypad?
If not, you can consider TKL (tenkeyless) keyboard which will open up the options a bit, and probably cost less.
For example the CM QFR - an excellent board at a very reasonable price.
Offline Metatron
« Reply #2 on: Sat, 14 September 2013, 05:35:11 »
Ah yes, I do need the TK. I do a fair amount of data entry for physics experiments and can't imagine attempting to delve into excel without it.
« Reply #3 on: Sat, 14 September 2013, 06:43:57 »
Then it pretty much depends on how much you want to spend, unless you really know you want Topre.
Also consider: http://mechanicalkeyboards.com/search.php?switch_id=ALL&size=Full+Size&keyword=&in_stock=on
Offline Mr. C
« Reply #4 on: Fri, 27 September 2013, 21:15:36 »
I don't game but I really prefer the topre feel over browns.  YMMV. Have you typed on either?
Offline MJ45
  • HHKB Pro
« Reply #5 on: Sat, 28 September 2013, 10:47:26 »
If you decide to get a Topre Type Heaven also consider getting PBT caps later are expensive. It would be cheaper in the long run to buy a Realforce 104 with PBT caps.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #6 on: Sat, 28 September 2013, 22:18:50 »
Just get a HHKB Pro 2. This is seriously the best think I have ever typed with thus far.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
« Reply #7 on: Sat, 28 September 2013, 22:24:21 »
Neither..
Ergodox, or the Topre-Dox,  they're more/less the same as far as ergo goes.
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #8 on: Sat, 28 September 2013, 22:28:03 »
Neither..
No 50 px korean gif this time?
Slippin TP4
Having a bad day?
« Reply #9 on: Sat, 28 September 2013, 22:29:24 »
Neither..
Slippin TP4
Here's 2
And the rabbit ones are of Mainland China origin, the Cat is of People's Republic of China, Taiwan.
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #10 on: Sat, 28 September 2013, 22:32:41 »
Neither..
Slippin TP4
Here's 2
Having a bad day?
