Author Topic: Best keyboard to harvest MX Clears from?  (Read 5139 times)
Offline Reckthor
    • PC Stuff
« on: Thu, 19 September 2013, 05:01:33 »
So I have been looking around on ebay for a keyboard o harvest some clear switches from. Any models I should look out for?
Thank you for any help.
Re: Best keyboard to harvest MX Clears from?
« Reply #1 on: Thu, 19 September 2013, 06:26:47 »
I'm not the best with keyboard model names on eBay but have you tried looking at Mouser.com or OnlineComponents.com?
« Reply #2 on: Thu, 19 September 2013, 06:33:41 »
You can get a Chyron maxine for fairly cheap on eBay.
There's also this one that's not awful bad but they had some similar ones cheaper a few weeks ago
http://www.ebay.com/itm/Cherry-G80-8200L-Keyboard-W-MSR-120-Keys-Beige-TDX265-/370868138851?pt=LH_DefaultDomain_0&hash=item565976b363
Otherwise if you want new switches you might try and get in on 7bit's group buy at deskthority.
http://deskthority.net/marketplace-f11/cherry-mx-taking-pre-orders-t2760.html
I'm sure Ivan will chime in, he is the expert  ;D
« Last Edit: Thu, 19 September 2013, 06:49:21 by SpAmRaY »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Thu, 19 September 2013, 07:27:59 »
There are also these bad boys which I think have most switches per board. Also there is WEY and Cherry G80-****HQ* if you also might want to take care of some nice doubleshots at the same time, but those chances are not so frequent.
« Reply #4 on: Thu, 19 September 2013, 07:31:17 »
I forgot about that one, it's been in my watch list haha.
Offline Kagusaki Wolf
« Reply #5 on: Thu, 19 September 2013, 13:53:07 »
Just stopped by on this thread and saw that Deko keyboard.  Do they work with PCs and do they have them in cherry blues?  I would love to find a clicky one :)
SIIG Suntouch K101 | Northgate Omnikey Ultra T | NMB RT8255C+ | Cherry G84-4100 | Cherry G84-4420 X2 | IBM Model M | Laser Brand Keyboard | Monterey K 108 X2 |
« Reply #6 on: Thu, 19 September 2013, 14:06:34 »
I'm not sure how much difficulty you would face attempting to get that to work but I believe they all have clears.
Offline Hellmark
« Reply #7 on: Fri, 20 September 2013, 11:56:19 »
I actually, think I'd like to type with one of those Dekos. Even if we have to make a new controller, that'd be cool.
Offline Tarzan
  • formerly known as Greystoke
« Reply #8 on: Fri, 20 September 2013, 12:13:13 »
There are a ton of character generator keyboards showing up for sale, I suspect everyone is switching over to digital and this stuff is just obsolete.  Pretty cheap, too, but shipping is what kills - best bet is to see if you can find a local electronics recycler that handles odd lots of video processing equipment.
http://www.ebay.com/itm/Chyron-Maxine-NTSC-Character-Generator-with-Keaboard-/121097148807
« Reply #9 on: Fri, 20 September 2013, 16:43:40 »
I don't really know anything about the Deko in use. It seems to have some kind of 7pin connector similar to PS/2 and I don't know what it speaks. The only reason I bought one was for parting it out since it was a cheap deal. Whenever I finally receive it I might be able to tell more about them once I open it up.
Offline 0100010
  • Not Sure
« Reply #10 on: Sat, 21 September 2013, 10:09:15 »
They have a PS2 port and support the normal 101 keyset by default.  To get any of the macro keys to work, outside of the Deko software - you may need a different controller, as the software comes with the driver for those extra keys - that as far as I know only function in Deko.  If you do buy one, make sure it comes with the power supply.  Limited KVM support as well.
« Reply #11 on: Wed, 25 September 2013, 19:24:29 »
Just an update so I got a chyron maxine had some weird oddball keytronics switches not even MX, and I got the deko a few minutes ago and sadly it has blacks. But at least it is mx. oh well no more ebay adventures hoping to get clears for me.
At least the deko looks brand new and I thin it has cherry stabs also.
« Reply #12 on: Wed, 25 September 2013, 19:43:46 »
once you harvest the switch it is best to use just the clear stems instead of the whole switch..
The housing doesn't stand up to soldering
the internals may warp
Offline Photoelectric
« Reply #13 on: Wed, 25 September 2013, 19:51:37 »
I've not had that happen yet...  Housing stands up to soldering just fine.  Why would the internals magically warp?  You only heat the pin ends for a fairly short time.  Disassembling switches has a higher probability of warping the metal inside the bottom housing, but that's about it.
« Reply #14 on: Wed, 25 September 2013, 20:39:05 »
TP's probably just trolling :P
« Reply #15 on: Wed, 25 September 2013, 20:39:41 »
I think he actually believes some of the stuff he says :)
« Reply #16 on: Wed, 25 September 2013, 20:43:15 »
yeah who knows, although I would have settled for clear stems haha.
so just to be clear for anyone else who finds this thread, NOT all chyron maxine's have clears, neither do all avid deko boards. your mileage may vary.
« Reply #17 on: Wed, 25 September 2013, 21:46:55 »
I stand firmly on all stuff said by I, TP4.
I am open to corrections.
I have had the switches wharp due to heat, "before" I got a soldering pump.
It's not that easy to get the switch off if you only have a thin tip on hand.
« Reply #18 on: Wed, 25 September 2013, 21:53:04 »
Yeah, I can see that.  Desoldering braid without enough flux is a slow and painful method to remove switches.
« Reply #19 on: Wed, 25 September 2013, 22:22:04 »
So my hakko 808 should be good then?
