Author Topic: Question about mx clears  (Read 11652 times)
Offline terran5992
  • One With The Cup Rubber
Re: Question about mx clears
« Reply #50 on: Sun, 29 September 2013, 00:23:55 »
Nuttin wrong with bottoming out
Offline ValerieV
« Reply #51 on: Sun, 29 September 2013, 09:00:06 »
I don't have clears so i don't know about bottoming out with those. I had mx blacks once and hate them with a passion. How anyone can type with that stiff switch is beyond me. It gave me arthritis!!  :mad:
« Reply #52 on: Sun, 29 September 2013, 10:02:54 »
carpel tunnel *
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #53 on: Sun, 29 September 2013, 16:13:41 »
See, here's the thing.
I just compared Cherry MX black to Futaba complicated linear and simplified linear, the latter being what I used for three years on the BBC Micro — vintage 1970s/1980s metal contact linear switches as were widely used at the time (Cherry M6/7/8/9, Alps linears, SMK linear etc).
Futaba linear switches are stiffer than MX black, but with significantly shorter travel. Futaba complicated linear is around 2.8 mm travel, and the simplified linear is 3 mm travel. Futaba low-profile linear, that I used for several years on the Master 128, is around 2.7 mm travel.
I bottomed them out for years, as I never noticed that it was not necessary. They never seemed too stiff, but I'm just not a fan of linear.
« Last Edit: Sun, 29 September 2013, 16:19:26 by Daniel Beardsmore »
Bore Awards
  • RIP
    • Boring twaddle
« Reply #54 on: Sun, 29 September 2013, 16:18:52 »
Where's the Delete Post button? :[
« Last Edit: Sun, 29 September 2013, 16:20:35 by Daniel Beardsmore »
Bore Awards
Offline ValerieV
« Reply #55 on: Sun, 29 September 2013, 16:43:43 »
carpel tunnel *
Either way it ****ed up my fingers!  :D
  • RIP
    • Boring twaddle
« Reply #56 on: Sun, 29 September 2013, 16:53:00 »
I guess even in the 80s you could avoid linear (in 8-bit machines anyway) if you got a machine with a rubber dome/buckling rubber sleeve keyboard. I "only" had proper mechanical keyboard with stiff linears ;-)
« Last Edit: Sun, 29 September 2013, 16:54:55 by Daniel Beardsmore »
Bore Awards
Offline PointyFox
« Reply #57 on: Sun, 29 September 2013, 17:07:16 »
At my previous job, I had linear buttons that probably took around 300g force to press and I pressed them around 7000 times a day with the same finger for over 2 years.  No problems.  I also knew someone there who did that for 17 years, also no problems.
  • RIP
    • Boring twaddle
« Reply #58 on: Sun, 29 September 2013, 17:29:18 »
What was your WPM with them? ;-)
This is my concern with these switch try bags — typing with fingers outstretched is a lot harder than stabbing things with the end of your fingers, and any switch feels good if you just stab at it :)
Of course, I was probably just stabbing at those linears at first, as it was my first computer :)
Bore Awards
Offline PointyFox
« Reply #59 on: Sun, 29 September 2013, 18:41:04 »
They operated a machine.  They made motion instead of letters.  Actually, stabbing them hurt after a while and I learned to press them orthogonally to my finger.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #60 on: Sun, 29 September 2013, 21:17:17 »
I would tend to believe that it is the impact at the bottom of the keystroke that causes RSI more than the force required for the keystroke.
Offline Moosecraft
  • HHKB Pro
« Reply #61 on: Mon, 30 September 2013, 06:24:07 »
Yes,the impact causes far more damage than actuation force.
  • RIP
    • Boring twaddle
« Reply #62 on: Mon, 30 September 2013, 15:35:19 »
Yeah, Futabas don't have the hard landing of Cherry MX.
Bore Awards
Offline gh_pp
« Reply #63 on: Mon, 30 September 2013, 23:21:03 »
I don't understand the design of those boards.  Why waste a lot of room for insert and delete keys?  Does anyone even use those?  I use home/print screen/end and function keys a lot more than I do insert and delete.
IIRC the ctrl-insert, shift-insert copy & paste combo predates ctrl-c ctrl-v (DOS turbo pascal/C++) and are more comfortable to use especially you’re a programmer and need to move code around a lot.
Ctrl insert = copy
Shift insert = paste
Shift delete = cut
Also shift arrow key to select code segment
Basically you’re using both hands and less fatigue than using ctrl-c ctrl-v
same work flow for almost every editor (emacs, notepad, intellij, eclipse, etc)
Hover your left hand on the ctrl/shift keys and right hand on the insert/delete/arrow keys cluster.
Arrows key navigate, hold down shift if you need to select text
Remove? => delete
Cut? => Hold shift then delete
Copy? => Hold ctrl then insert
Paste? => Hold shift then insert
in some terminal programs (like linux terminal or windows secureCRT) the ctrl-c default binding is to terminate a foreground job.
Newer terminal supports ctrl-shift-c or ctrl-alt-c but they are even harder to trigger.
I love the ctrl/shift-insert/delete combos.
« Last Edit: Mon, 30 September 2013, 23:29:30 by gh_pp »
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline Melvang
« Reply #64 on: Tue, 01 October 2013, 00:03:26 »
Ctrl insert = copy
Shift delete = cut
Remove? => delete
Do these combos still work in the Win 8 os natively?  Or have they been totally replace with the common knowledge ctrl+c, and ctrl+v??
Offline gh_pp
« Reply #65 on: Tue, 01 October 2013, 02:42:32 »
they sure do (notepad, wordpad, browers textfield, textarea, URL bar etc).
a lot of these shortcuts are implemented by the controls.
so if you use a rich text control in your app, the control already handled these shortcuts for you.
