Author Topic: HHKB Pro 2 Love  (Read 577516 times)
Offline Awful
  • Don't Topre.
Re: HHKB Pro 2 Love
« Reply #400 on: Fri, 06 December 2013, 15:10:15 »
Guys I can has join? I wanted to wait until this HO CC came in. :)
(It's on the left, because I swapped the ESC and the Tilde in keytweak)
I hate everything.
Re: HHKB Pro 2 Love
« Reply #401 on: Fri, 06 December 2013, 21:49:04 »
Those are both very beautiful HHKBs! I put my new photo in the topre and keyboard threads.  :thumb:
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: HHKB Pro 2 Love
« Reply #402 on: Fri, 06 December 2013, 22:19:30 »
I'm getting my black HHKB this month. And once i get a chance i will be getting a Rf blank white set. And i will have a couple (At least) Bro bots to put on it :D
Do you guys think i should buy a Cherry mx board after i get my HHKb just to test the waters on the other side?
« Last Edit: Fri, 06 December 2013, 22:22:29 by Air tree »
Re: HHKB Pro 2 Love
« Reply #403 on: Fri, 06 December 2013, 22:30:27 »
I would! I'm getting a Poker X built. :) try to get a tester from someone so you can try what switch you like. I'm getting clears!
Ps: the HHKB blanks are light gray but I think the realforce are actual white blanks. :)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: HHKB Pro 2 Love
« Reply #404 on: Fri, 06 December 2013, 22:34:28 »
And where would you be obtaining a set of white blank RF caps? I couldn't find any lol.
Offline Air tree
Re: HHKB Pro 2 Love
« Reply #405 on: Fri, 06 December 2013, 22:34:47 »
I think if i get clears they will have to be ergos.
And I wanted Plain white blanks since they are just so sexy on a black HHKB.
Offline Air tree
Re: HHKB Pro 2 Love
« Reply #406 on: Fri, 06 December 2013, 22:35:42 »
Try to get lucky on the Classifieds.
Ps. Sorry for the double post.
Offline Belfong
Re: HHKB Pro 2 Love
« Reply #407 on: Fri, 20 December 2013, 03:18:14 »
So one of the best thing I also like about the HHKB is the legs. It actually has two different legs allowing the ability to have two different angles. I like the lower one which elevate the keyboard just slightly above. So I could put the keyboard against the MacBook and have the protruding USB cable just above the trackpad. Without the legs, the mini USB would have scrape against the trackpad and I can't put the keyboard as near as I would have liked <3
Re: HHKB Pro 2 Love
« Reply #408 on: Fri, 20 December 2013, 04:23:02 »
I never really thought about HHKB having legs.
Mine just sits flat on the desk.
Offline Belfong
Re: HHKB Pro 2 Love
« Reply #409 on: Fri, 20 December 2013, 06:23:26 »
It's the best, rowdy - THE BEST XP!
Offline terran5992
  • One With The Cup Rubber
Re: HHKB Pro 2 Love
« Reply #410 on: Fri, 20 December 2013, 06:35:02 »
It has legs but the feet are terrible
Offline ctbear
Re: HHKB Pro 2 Love
« Reply #411 on: Fri, 20 December 2013, 13:34:51 »
I have been using my HHKB for a few months now and I can't go back to my other keyboards (layout and switch difference, mostly). But one thing that is less than ideal was the weight on the keyboard - just too light and doesn't feel solid enough for me.
Then I saw a post somewhere suggesting putting something soft under the keyboard. I put my old gaming mousepad under it and OMG the difference is dramatic. I haven't tried a RF before but this is how I imagine a 60% RF would be.
Offline Wildcard
  • When caffeine isn't enough
Re: HHKB Pro 2 Love
« Reply #412 on: Fri, 20 December 2013, 14:47:54 »
Awful that HO is looking pretty nice there   :)
Enjoy it!
Offline trax
Re: HHKB Pro 2 Love
« Reply #413 on: Fri, 20 December 2013, 18:23:04 »
Why isn't there an aluminium kit for the HHKB yet?
Switches tried so far
Cherry MX Red Blue Black Clear
ALPS White Black (fake)Blue
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: HHKB Pro 2 Love
« Reply #414 on: Fri, 20 December 2013, 18:30:50 »
If you're talking about a case, it's near impossible because the whole thing is case-mounted... having an aluminum case would mean pretty much having an entire new keyboard, which is what the HG pretty much was. Other than the PCB and rubber cups, the rest of the keyboard is the case, which includes the switch/plunger.
Offline trax
Re: HHKB Pro 2 Love
« Reply #415 on: Fri, 20 December 2013, 18:33:07 »
Why is it near impossible? Can't we just take a scan of the current plastic case and base ourselves from that? I don't know anything about this kind of thing but I'd really like an alu (or even heavier) case (or an HG, lol).
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline spiceBar
    • ChessTiger.com
Re: HHKB Pro 2 Love
« Reply #416 on: Fri, 20 December 2013, 19:18:27 »
The shape of the top part of the case is very complex because it includes the shape of every switch housing. On other Topre boards, the switch housings are separate little pieces of plastic, all identical (almost) and they are mounted on a metal plate in which holes have been drilled. The HHKB is unique in the fact that the top of the case has all the switch housings molded in just one piece of plastic. I think it would be quite a lot of work to replicate that on a CNC machine. I'm not even sure it is possible. But I'm not an expert.
Offline terran5992
Re: HHKB Pro 2 Love
« Reply #417 on: Fri, 20 December 2013, 21:27:01 »
If it exists . Thats where my money will be going
Offline ctbear
Re: HHKB Pro 2 Love
« Reply #418 on: Fri, 20 December 2013, 22:02:37 »
Something like this?
http://www.pfu.fujitsu.com/hhkeyboard/hhkbprohg/externals.html#no
Re: HHKB Pro 2 Love
« Reply #419 on: Fri, 20 December 2013, 22:40:00 »
Is that a F****** aluminum HHKB Case!? I want one ;o
I put Bluelounge Rubber on the bottom of my HHKB I love them.
Offline adhoc
Re: HHKB Pro 2 Love
« Reply #420 on: Sat, 21 December 2013, 04:40:53 »
That aluminum case is called HG series of HHKB and it costs so much you really do not want it. Also, it's a limited edition so you can't buy it anymore anyway.
>spamming the forums just so I can type something with my HHKB <3
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: HHKB Pro 2 Love
« Reply #421 on: Mon, 23 December 2013, 21:18:03 »
I'll be out of town during Christmas so I'll post now :)
http://geekhack.org/index.php?topic=40658.msg1170170#msg1170170
Offline fourzeropooh
Re: HHKB Pro 2 Love
« Reply #422 on: Mon, 23 December 2013, 21:19:10 »
HHKB has USB ports on the back?  :eek:
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: HHKB Pro 2 Love
« Reply #423 on: Mon, 23 December 2013, 21:21:01 »
Yeah there's two USB 2.0 ports on the back.
Offline MJ45
  • HHKB Pro
Re: HHKB Pro 2 Love
« Reply #424 on: Mon, 23 December 2013, 21:26:33 »
Most of the HHKB owners know the feeling. I think its the best typing experience you can get!
Offline tuxsavvy
  • 白HHKBの魔法使い
Re: HHKB Pro 2 Love
« Reply #425 on: Mon, 23 December 2013, 21:35:50 »
HHKB has USB ports on the back?  :o
Only HHKB Pro2, HG, and Lite2. USB ports are not available on the backs of HHKB Pro or HHKB Pro JP for instance.
Source (Japanese only and only a portion of the keyboards are covered): http://www.pfu.fujitsu.com/hhkeyboard/leaflet/hhkb_backview.html
« Last Edit: Mon, 23 December 2013, 21:43:55 by tuxsavvy »
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline terran5992
Re: HHKB Pro 2 Love
« Reply #426 on: Mon, 23 December 2013, 21:36:09 »
Damn too bad that aluminium case is discontinued
Offline Belfong
Re: HHKB Pro 2 Love
« Reply #427 on: Mon, 23 December 2013, 21:39:14 »
The USB port is so low-powered it is practically useless, IMO.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: HHKB Pro 2 Love
« Reply #428 on: Mon, 23 December 2013, 21:41:05 »
Pretty great for numpads tho :)
Offline terran5992
Re: HHKB Pro 2 Love
« Reply #429 on: Mon, 23 December 2013, 21:43:35 »
For the people who have a numberpad
Re: HHKB Pro 2 Love
« Reply #430 on: Mon, 23 December 2013, 21:59:32 »
I haven't even been able to get a USB memory stick working in mine.
Offline Belfong
Re: HHKB Pro 2 Love
« Reply #431 on: Mon, 23 December 2013, 22:36:48 »
Anyone tried it with a Logitech Wireless Controller? If it works, that would be great!
Offline ctbear
Re: HHKB Pro 2 Love
« Reply #432 on: Mon, 23 December 2013, 23:16:17 »
I just use it for my Fitbit receiver. Pretty good place for it since I carry my HHKB to/from work, that way I can have the receiver with me most of the time.
Offline adhoc
Re: HHKB Pro 2 Love
« Reply #433 on: Tue, 24 December 2013, 01:40:37 »
Yeah I basically wanted a USB hub so I bought a HHKB, but I got a keyboard instead...can you imagine the basta***!
Offline Belfong
Re: HHKB Pro 2 Love
« Reply #434 on: Tue, 24 December 2013, 01:59:54 »
:eek: $450 USB hub? :D
Offline adhoc
Re: HHKB Pro 2 Love
« Reply #435 on: Tue, 24 December 2013, 02:10:44 »
Yeah and it also sucks (the usb hub)! ;D
Offline atlas3686
  • HHKB Elite
Re: HHKB Pro 2 Love
« Reply #436 on: Tue, 24 December 2013, 03:25:06 »
Wish they would just scrap the USB hub then it would work on an iPad too.
Offline MJ45
  • HHKB Pro
Re: HHKB Pro 2 Love
« Reply #437 on: Tue, 24 December 2013, 08:03:58 »
I have a lot of USB flash drives some even work on the HHKB most do not, no wired mice work (none I have). But surprisingly all the DSLR Nikon cameras I own work thru the hub I think because they are self powered.
Offline eth0s
  • Peace & Love
Re: HHKB Pro 2 Love
« Reply #438 on: Wed, 25 December 2013, 00:45:51 »
Hey, I just found this pic.  That looks friggin' awesomes.  Not just for x-mas.  That is a year-round winning combo to me.  :thumb:  [why thumbs up no werk?]
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: HHKB Pro 2 Love
« Reply #439 on: Wed, 25 December 2013, 01:01:44 »
Thank you, eth0s! I put heart into it hehe. Glad to see it is appreciated. I'm constantly working to create new and unique themes for the HHKB :thumb: [not working for me either huehue]. It's too bad I'll be away from it for a week :'(
Re: HHKB Pro 2 Love
« Reply #440 on: Wed, 25 December 2013, 04:20:58 »
There is a problem with emoticons if you quote a message that contains a picture.
Offline adhoc
Re: HHKB Pro 2 Love
« Reply #441 on: Wed, 25 December 2013, 05:23:14 »
I flipped my space bar and now I love this keyboard even more. God darn it.
Do you guys have the spring under space or did you remove it?
Offline terran5992
Re: HHKB Pro 2 Love
« Reply #442 on: Wed, 25 December 2013, 06:20:18 »
I left the spring there. Makes the spacebar more 'stabalized'
Offline adhoc
Re: HHKB Pro 2 Love
« Reply #443 on: Wed, 25 December 2013, 06:23:12 »
Hmmm are you sure? I don't think the spring is there for stabilization, but more for actuation force? I'm not sure though.
Offline terran5992
Re: HHKB Pro 2 Love
« Reply #444 on: Wed, 25 December 2013, 06:36:59 »
It feels kinda squeaky without the spring
Offline neunelfer
  • HHKB Pro
Re: HHKB Pro 2 Love
« Reply #445 on: Wed, 25 December 2013, 14:43:04 »
So I got my Christmas HHKB today....   :eek:
Re: HHKB Pro 2 Love
« Reply #446 on: Wed, 25 December 2013, 14:56:59 »
It works with the G80-3700.
Re: HHKB Pro 2 Love
« Reply #447 on: Wed, 25 December 2013, 16:36:05 »
Nice :)
Welcome to the fold.
Offline neunelfer
  • HHKB Pro
Re: HHKB Pro 2 Love
« Reply #448 on: Wed, 25 December 2013, 16:41:12 »
Nice :)
Thanks! Here's a bad picture that I posted elsewhere:
One of my concerns was the lack of grip that the feet provide - they seem fine to me. Over time, I'm assuming they worsen. This is the same thing that happens to the feet on my Filco. A simple fix that I use is to dampen a Q-tip and wipe the dust off of the bottom of the feet, which restores their grip. I'm assuming the same would work on the HHKB feet, so just a tip in case people didn't know.
Offline adhoc
Re: HHKB Pro 2 Love
« Reply #449 on: Wed, 25 December 2013, 17:06:24 »
Honestly I do not find feet bad at all. I have no idea why people complain about this. My advice is you turn the space bar around - it's seriously a lot better that way. Other than that, looking good!
BTW - anybody has a blank red esc key for sale? Please guys...come on, surely somebody ordered 1 too many :(
