Author Topic: Please Help! Razer Blackwidow Keys Malfunctioning  (Read 30997 times)
Offline ArceusO
« on: Mon, 30 September 2013, 09:56:40 »
Hello, this is my first post on geekhack. I don't know if this is the place to post this kind of thread but I couldn't find a help zone or something so I am posting it here. I need some help with my Razer Blackwidow. I thought the best place to post this message was geekhack.
Anyways, getting into the problem:
I bought a Razer Blackwidow 2 months ago and it was functioning perfectly until today. I got out from shower with my hair wet and sat in front of my computer. Then, 3-4 drops of water fell down from my hair and got on the keyboard. I immediately picked up a tissue to clean it but while I was cleaning it the computer started doing crazy things. Several applications launched just by themselves and there was a crazy scene on my computer. The computer was selecting different shortcuts from my desktop for like 10-20 times just in a second. Clearly some of the keys got stuck for some reason but what I don't understand is that the other half of the keyboard (the half that didn't get the water drops) seems stuck too. After cleaning the key caps and whats inside it calmed down a bit (I still sometimes get crazy things) however now when I press "D" key my computer returns to desktop. I can't do anything except alt-tabbing which sometimes doesn't work too. When I press "A" it writes æææææ. I cleaned it up so many times, tried blowing into the keys while holding the keyboard upside down and shaking it but none of them worked. I tried the keyboard on another computer and that computer got the same thing as mine. I'm assuming that the windows key is stuck now because pressing D gets me to desktop immediately. Also the windows key does not work when I press it on the keyboard. What is more interesting is that when I disconnect the keyboard from my laptop, my laptop continues to do crazy things and I still get to my desktop when I press "D" (from my laptop's original keyboard) or get "ææææ" when I press A until I press the windows key to reset its malfunctioning. However, sometimes this does not work too so I need to restart my computer to be able to get it to normal again. I don't understand why it is happening even though the keyboard is not connected and there is no problem with my laptop's original keyboard. Lastly, I tried "gaming mode" which disables the windows key through the razer synapse engine but it didn't work either. I also uninstalled the razer synapse engine and it is still the same thing.
What should I do or is there anything I can possibly do?
« Last Edit: Mon, 30 September 2013, 10:04:19 by ArceusO »
Re: Please Help! Razer Blackwidow Keys Malfunctioning
« Reply #1 on: Mon, 30 September 2013, 10:05:21 »
Throw it out..
Buy an Ergodox.
This is standard advice when it comes to Razer Keyboards on this forum.
It's NOT worth fixing.  At best, you use a razer board to salvage its remaining functional keyswitches.
Oh it also seems like you fried the controller...
THAT.... or it's not dry.. stop using it for a week and see if it still does this.
Offline ArceusO
« Reply #2 on: Mon, 30 September 2013, 10:11:41 »
Throw it out..
Buy an Ergodox.
LOL, yes I was thinking of waiting for about a week before sending it back to Razer guarantee. Thanks for the advice.
« Reply #3 on: Mon, 30 September 2013, 10:16:33 »
Sounds like you shorted something. You can try taking it apart and drying/wiping everything down then trying it again when it's dried.
Offline mauri
« Reply #4 on: Mon, 30 September 2013, 10:17:18 »
Don't use it for a couple of days, perhaps try to wipe it a bit, mine did that too when I spilled dr pepper on it
I AM BABAR KING OF THE ELEPHANTS
Offline ArceusO
« Reply #5 on: Mon, 30 September 2013, 10:38:48 »
Yeah I pulled out all the keys and put the keyboard face-down. Gonna wait 2-3 days and give it a try again. Thanks for your advices.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Mon, 30 September 2013, 10:45:03 »
anyway you could set it out in the sun for a couple hours?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline ynrozturk
« Reply #7 on: Mon, 30 September 2013, 10:54:11 »
Dude gets a few drops of water on his keyboard, comes here asking for advice, and the first thing he's told is to buy a $400 keyboard which he will have to put together himself.
That's just very lame, and not funny.
Like the other sensible members have said, just let it dry out for a few days and see what happens. Hopefully it'll be okay. Good luck.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
« Reply #8 on: Mon, 30 September 2013, 10:57:17 »
ah what? it's $275 assembled... + whatever shipping / tax..
and considering it's the "LAST" keyboard anyone ever needs to buy... that's better than stocking up on the garbage that most people have in their sigs...
like a bunch of pokers and more crap-tastic widows.
Offline ynrozturk
« Reply #9 on: Mon, 30 September 2013, 11:03:22 »
The point is that he wasn't asking about his "last" keyboard to buy. He was asking about a malfunction and your constant Ergodox suggestions (for everything, it seems) are just lame.
« Reply #10 on: Mon, 30 September 2013, 12:24:50 »
The point is, fixing a black-widow is the same as beating a dead horse....  whatever satisfaction there is to be had is at the very best "unhealthy".
The purchase of a black widow was the "first-mistake",  why perpetuate this further..
We have the SOLUTION.....  and if anything, in terms of Feature set and custom-izability the Ergodox is bar none "the most keyboard you can own, while maintaining a low-low price tag"
Offline ynrozturk
« Reply #11 on: Mon, 30 September 2013, 12:28:38 »
I know where you're coming from, and that's cool. But you should also factor in that a lot of people here just may not have the money to just flat out buy a new board, let alone an Ergodox.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Mon, 30 September 2013, 13:03:24 »
just give it a couple days as others have said to try and maybe dry out.
black widow's are not cheap regardless who may or may not like them, so do not throw in the towel on your investment.
also..............i would not suggest that you try to take apart as these things are pretty difficult to pop open with all the hidden screws, snaps in weird places and so on.
my bwu regardless of what others think has been a good solid board, however knowing better now you can sure get a whole lot better board for the money- but unless one has been here a while you would not know that.
if it does not dry out and maybe other than shipping-- if it is still under warranty then send that sucker back
any board and just not a bwu does not luike getting wet :'(
Offline Mountain Man
« Reply #13 on: Mon, 30 September 2013, 13:38:40 »
I learned the hard way that Razer sells overpriced junk. My recommendation is to throw your keyboard in the garbage where it belongs and get a quality board from WASD.
Offline saturnotaku
« Reply #14 on: Mon, 30 September 2013, 13:44:04 »
It's highly unlikely that you'd get any kind of warranty coverage/support from Razer because of the way the keyboard was damaged. To be fair, you wouldn't likely get any sympathy from another company if the same thing happened. However, another keyboard likely will not die because it got a drop or two of water on it.
I have given Razer the benefit of the doubt many, many times over the years and have almost always been burned. The only products of theirs that are worth anything are the mouse pads. Their paper-thin Sphex and the mobile Kabuto are the best I've ever used. They can keep everything else, especially the mice and keyboards.
« Reply #15 on: Mon, 30 September 2013, 13:48:14 »
You can also try putting the components in rice. Don't eat the rice after if you do this though since solder has lead and you don't wan't to expose yourself to anymore lead then necessary. Supposedly rice draws moisture out so it helps to dry things. Just a thought. Good luck :D
Offline whiteduck
« Reply #16 on: Mon, 30 September 2013, 13:48:45 »
I second this man of the mountain's recommendation and grab a nice board from WASD (bare bones preferably so you can source an epic group buy key set).
-wd
Offline esoomenona
  • Gnillort?
« Reply #17 on: Mon, 30 September 2013, 13:52:08 »
Shiiiet... I use to eat lead by the bottle. I turned out just fine.
« Reply #18 on: Mon, 30 September 2013, 13:53:51 »
Is that what you want to call it? "Fine"? :P
« Reply #19 on: Mon, 30 September 2013, 14:04:23 »
That's impossible.... If they can afford internet to get on GH, they can afford an Ergodox... It may come down to budget cuts in other areas of their life, but $275 is well within reach of everyone.
Expensive Macro-nutrients is the best place to start, because your body doesn't care where you get carbs from.
Offline do_Og@n
« Reply #20 on: Mon, 30 September 2013, 14:06:48 »
If you can get the board working again I would highly suggest selling it and getting a Cooler Master QFR. Better built and easier to customize. Plus it has standard size keycaps so you can switch them out without a tsangan kit.
I had a Razer Blackwidow Ultimate as my second board and after buying a QFR I sold the BWU nearly immediately and haven't looked back.
Offline mapple
« Reply #21 on: Mon, 30 September 2013, 15:09:14 »
Throw it out..
Buy an Ergodox.
this.
u have correct answer, let it dry as other guy wrote before me leave on sun for few days and send to razer support saying that there's sth wrong with ur keyboard.......... easiest way to get new one....... at least that's how support works for ppl which bought thru their page.
In God We Trust
Offline saturnotaku
« Reply #22 on: Mon, 30 September 2013, 15:12:56 »
this.
Except that would be fraud if you're trying to claim something is a manufacturing defect when the problem was created by accidental damage.
Offline Linkbane
« Reply #23 on: Mon, 30 September 2013, 20:57:48 »
Just stop. The ErgoXYZ elitism is severely reducing the quality of posts, and you're being completely unhelpful. This man wants a fix to his keyboard which he spent a decent money on, don't come in and shove your opinion down his throat.
OT: As others have suggested, waiting for it to dry would make sense. If it doesn't work, an RMA from Razer would be in order. If that doesn't work, you'd probably just want to buy a new keyboard, as the switches might not be worth salvaging.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #24 on: Mon, 30 September 2013, 21:32:12 »
Oh I thought rice attracted Asians to fix the electronic... Lol.
Yeah, put it in some rice and leave it there for 4-5 days. I've saved many iPhones like that lol.
Offline saturnotaku
« Reply #25 on: Tue, 01 October 2013, 07:56:10 »
I wish this board had a rep/like system.
Offline mauri
« Reply #26 on: Tue, 01 October 2013, 08:06:28 »
But but.. ergodox?
Offline C5Allroad
« Reply #27 on: Tue, 01 October 2013, 09:00:01 »
Why ergodox? He wants to fix his damn board. He spent over $120 on it and want it working.
I know if I bought a board I'd want it to work perfectly.
Offline Hellmark
« Reply #28 on: Tue, 01 October 2013, 12:02:55 »
If he bugs you, as he does many other members, why not just drop him into your killfile.
http://geekhack.org/index.php?action=profile;area=lists;sa=ignore;
Go there, add his name, and never see his posts again.
« Reply #29 on: Tue, 01 October 2013, 18:00:53 »
And miss all the fun?
Offline ynrozturk
« Reply #30 on: Tue, 01 October 2013, 18:50:16 »
No one bothers me enough to care to make the effort to do all that.
« Reply #31 on: Tue, 01 October 2013, 18:59:54 »
But but.. ergodox?
Exactly.
Ergodox is the solution to all your keyboarding problems..
Anything that's wrong with your keyboard can be solved by buying an assembled Ergodox....
And just because you spent "good money"  doesn't make the razer any less of a LEMON....
If you bought a lemon vehicle,
should you,
A,  keep throwing money + time at it in repairs,
or
B,  sell it/ scrap it and buy a toyota camry...
The answer is clear...
« Reply #32 on: Tue, 01 October 2013, 19:06:50 »
The phrase "throwing good money after bad" comes to mind.  Consider it an expensive mistake.  Trust me, I had a love affair with Razer for about a year until their products started failing on me one after the other.  Never again will I buy or recommend that someone buy Razer.
Offline C5Allroad
« Reply #33 on: Tue, 01 October 2013, 19:10:54 »
I learned something as I joined GeekHack... There are some people who post on my issue with a keyboard and will immediately say ERGODOX NOAW!!!
« Reply #34 on: Tue, 01 October 2013, 19:15:35 »
Say what you will...
Razer only wish it could suck donkey c0*k
Whatever it's currently sucking, is even worse....
Offline C5Allroad
« Reply #35 on: Tue, 01 October 2013, 20:01:16 »
I understand that they are not the best. But why keep typing that in all the threads? It's more like spam to me. Maybe he doesn't have the money for a new board, maybe that's why he has come here to the glorious website known as GeekHack.org where keyboard enthusiasts can all get along. So maybe just for me or even the whole website stop posting ooh buy an ergodox.
Offline Linkbane
« Reply #36 on: Tue, 01 October 2013, 21:25:28 »
Ergodox is trash. It's un-ergonomic garbage and makes the N64 controller look like the Kinesis. Honestly, who in their right minds would lug around such a big piece of worthless scrap metal so that they can demonstrate to others their massive e-pen*s. You can't even type with correct grammar, with all this supposed 'ergonomics' that you receive. Five periods after a sentence? Some word that has a number and a censor in it? Pathetic. The ErgoDox is a ****ty ripoff of Maltron and the users are the rudest, most unhelpful people on GH.
//half-sarcastic rant
« Reply #37 on: Tue, 01 October 2013, 21:50:12 »
^^ N00b
Offline C5Allroad
« Reply #38 on: Tue, 01 October 2013, 21:50:25 »
Exactly lol.
« Reply #39 on: Tue, 01 October 2013, 21:51:54 »
Exactly lol.
Unhelpful?
I already posted the solution to the op's problem... before ANYONE ELSE did...
I just happen to Add the fact that, it's a ****ty board that's not really worth using...
Some of you n00bs cling to your precious $100 mistake, and justify it to "yourselves" more than anyone else that the BW isn't total crap, when the entire enthusiast community deems it thus...
GTFO if you don't like sound advice.
Offline Linkbane
« Reply #40 on: Tue, 01 October 2013, 22:12:09 »
Unhelpful?
Wow, what a little ****. If only you could get your head out of your ass and help someone for real instead of attempting to make yourself seem better than others, we could have something useful. Please erase your worthless posts and cling to your pathetic excuse of a keyboard, which you likely can't even type over 60 wpm with.
« Reply #41 on: Tue, 01 October 2013, 22:46:05 »
Not everyone wants, or can afford, an ErgoDox.
It is NOT the solution to every problem.
In this case allowing the keyboard to dry might return it to a state of functionality, if not then because it is only a couple of months old it might be possible to return it.
If THAT eventuates, then maybe the OP could consider buying an alternative board.
And besides, this board did not die due to inherent manufacturing or quality problems, it died due to liquid incursion (probably).
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #42 on: Tue, 01 October 2013, 23:02:24 »
 :thumb:
Offline jonathanyu
« Reply #43 on: Tue, 01 October 2013, 23:10:25 »
you can put the whole board into a bag of rice, and wait for few days.  And then try it again, it should make the keyboard work again.  If it still not working, I think you should contact razer and ask them will they fix it.
Offline BlackWidowMan777
« Reply #44 on: Tue, 01 October 2013, 23:12:02 »
You might try uninstalling the Razer Synapse software and then trying again. If it doesn't go haywire again then it's a software problem, not the 3 drops of water. It will still function perfectly well as a keyboard; even better since you won't have any software issues that may crop up from time to time.
The same thing you described happened to me, and after reading all the negative stuff online, I was ready to throw my Blackwidow in the dumpster. I immediately packed it away and so began my downward spiral buying more and more keyboards looking for that perfect one.  :(
But after a few weeks, I decided to give it another try because I missed how great it is to type on and how amazing it sounds; however, the problems continued - mostly with particular keys spamming - so I removed the software from my computer, plugged the keyboard back in, and voila, no more problems to this day.
Offline elttaboi
« Reply #45 on: Wed, 02 October 2013, 01:35:34 »
What if Razer came out with their own branded ergodox?
OP, 3 drops of water isn't going to do much damage, unless it was more than that amount. You could try taking it apart to see if water has collected somewhere.
Either way, it's 'working' right now so as soon as it dries, it should be fine.
« Reply #46 on: Wed, 02 October 2013, 02:23:37 »
If the quality checks out, then it's fine... but they've yet to improve the BW... it's still very much bottom barrel...
« Reply #47 on: Wed, 02 October 2013, 02:30:25 »
Incorrect.
Everyone can Afford an Ergodox, it might just require a small savings period, minor cut backs to top-ramen.
It is the solution to EVERY keyboard related problem, because that was IN THE DESIGN....
---- The ergonomics
---- The modd-ability
---- The Programm-ability
---- The ease of dis-assembly and repair
Ergodox takes all of the things the keyboard community yearned for and created a product that (currently) has no equal...
All of the pitfalls of standard staggered Qwerty keyboards are addressed....
The Ergodox is the embodiment of betterment and change.
The Black Widow and the continued re-iterations of such antiquated design such as the "WASD Code" is what's holding people back..
And anyone who actually actively USES a keyboard can tell you that staggered qwerty is sub-optimal for one's shoulders/ wrists/ and fingers.
Offline saturnotaku
« Reply #48 on: Wed, 02 October 2013, 05:10:39 »
Only in your world. If it were the greatest thing since sliced bread, everyone in this community would have one and be agreeing with you. So far, you're the only one who is this vocal about it. And it's still not helpful.
« Reply #49 on: Wed, 02 October 2013, 05:43:51 »
I see more people with Topre boards than ErgoDox.
