Author Topic: Coke Spillage, pls help  (Read 2331 times)
Offline Ewanhen
« on: Sat, 19 October 2013, 19:53:33 »
So, uh
I spilled coke on my keyboard and the "w" "2" "3" and "4" keys are all mushy and sticky, can I fix this or will I have to buy another board?
Offline terran5992
  • One With The Cup Rubber
Re: Coke Spillage, pls help
« Reply #1 on: Sat, 19 October 2013, 20:10:10 »
Do the keys still reigster?
Unplug the keyboard , flip the keyboard around and let it dry out for 2-3 days
Offline Ewanhen
« Reply #2 on: Sat, 19 October 2013, 20:11:05 »
ok
The keys still register so ill make sure to do that and I'll post my updates on wednesday
« Reply #3 on: Sat, 19 October 2013, 20:12:11 »
The only way to be sure is to replace those switches (assuming some sort of Cherry MX switch).
You can try rinsing with diluted water and/or rubbing alcohol and allowing to completely dry before plugging it in again, but if they are MX blues you might lose the click.
Offline Ewanhen
« Reply #4 on: Sat, 19 October 2013, 20:14:44 »
They are browns so I can probably just get them replaced since there are only five that are damaged
If anyone knows where I can buy could you please link it.
And thanks everyone for helping
« Last Edit: Sat, 19 October 2013, 20:16:41 by Ewanhen »
« Reply #5 on: Sat, 19 October 2013, 20:46:55 »
Your best bet for cheap switches is to provide 50 more valuable contributive posts to the community, and then start a WTB thread in classifieds.
Otherwise for such a small quantity you will be playing top money.
Plus you will need to be handy with a soldering iron to swap them.
But switch swappage is definitely the only way to be 100% sure that they will not seize up again in the future.
Offline LaugeGregers
« Reply #6 on: Mon, 21 October 2013, 04:27:17 »
It is possible to buy switches from 7Bit on Deskthority.
http://deskthority.net/marketplace-f11/cherry-mx-taking-pre-orders-t2760.html
« Reply #7 on: Mon, 21 October 2013, 04:31:17 »
If you're sure it's only   5x keys..
It MAY be cheaper and much faster to fix this yourself.
Desolder the keys..  open up the keys, drop all parts into a glass of alcohol... lightly stir or shake...
Wait for them to dry... Rub off residue on the slider and leaf spring carefully.
then resolder them back.
But yea.. you can buy 5 switches from WASDkeyboards
Offline genkidama
« Reply #8 on: Mon, 21 October 2013, 08:54:07 »
Not trying to make fun about this matter, but is it me or are more and more people starting to spill something on their beloved keyboard? I see an upward tendency ^^
My finger training is over 9000!!!!
Offline laffindude
« Reply #9 on: Tue, 22 October 2013, 03:58:42 »
I used to think only Razer owners need sippy cups.
« Reply #10 on: Tue, 22 October 2013, 04:26:08 »
It goes in phases.
A year or so ago there was a rush of people who spilled something in their keyboard.
Then it all went quiet.
Now people have started spilling again.
I wonder if it is seasonal?
Offline genkidama
« Reply #11 on: Tue, 22 October 2013, 05:54:26 »
It goes in phases.
With your information I think it's seasonal. Definately  :cool:
