Author Topic: Desk lamps  (Read 12085 times)
Offline Creizai
Desk lamps
« on: Tue, 22 October 2013, 04:58:06 »
I'm looking for something that looks good, functional, isn't hot and doesn't blind me.
Offline longweight
  • philanthropist
Re: Desk lamps
« Reply #1 on: Tue, 22 October 2013, 05:00:09 »
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: Desk lamps
« Reply #2 on: Tue, 22 October 2013, 05:03:53 »
Offline longweight
  • philanthropist
Re: Desk lamps
« Reply #3 on: Tue, 22 October 2013, 05:12:21 »
OP didn't state a budget.
LEDs do get hot but nothing like halogen.
Offline ynrozturk
Re: Desk lamps
« Reply #4 on: Tue, 22 October 2013, 07:37:35 »
That is very nice though.
I just use 2 from Ikea, one a small light clamped to my monitor for an extra burst of light if I need it.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline buni
Re: Desk lamps
« Reply #5 on: Tue, 12 November 2013, 19:20:46 »
http://www.amazon.com/Swing-Desk-Lamp-Satin-Nickel/dp/B002ZKHZC4/ref=sr_1_3?ie=UTF8&qid=1384305098&sr=8-3&keywords=boston+harbor+lamp
this lamp from amazon is seriously the best lamp EVER!!! the pic looks really crappy though so I'll post mine.
Blue switches are my favorite... I've only tried blue switches...
Offline Lastpilot
  • Power stance
Re: Desk lamps
« Reply #7 on: Tue, 12 November 2013, 23:55:58 »
u guys are crazy for spending more than $8 on this sort of thing... it'z a lamp..... sans genie
Offline ynrozturk
Re: Desk lamps
« Reply #8 on: Wed, 13 November 2013, 10:12:50 »
Not all lamps are equal.
Offline Neal
  • Skype: iNewbcake
Re: Desk lamps
« Reply #9 on: Wed, 13 November 2013, 10:50:13 »
Mine was like $100 :/ No regrets though.
Can't find any pics of it on the internet ;-:
  • Live long and prosper
Re: Desk lamps
« Reply #10 on: Wed, 13 November 2013, 10:56:20 »
Some people say the same about keyboards...
tp thread is tp thread
Offline paicrai
  • mindblank
Re: Desk lamps
« Reply #11 on: Wed, 13 November 2013, 11:11:04 »
You can find this at Ikea. It is not hot. You can put your hand on this after at least 6 hours and feel no heat. It is also very flexible and functional. The light brightness on mine is amazing, but that may vary from different Ikea stores, and most likely countries as well. Also it's super pretty.
As it stands (pun intended) it's a super good perfect lamp.  :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
« Last Edit: Wed, 13 November 2013, 12:07:43 by paicrai »
THE FEMINIST ILLUMINATI
Offline davkol
  •  Post Editing Timeout
Re: Desk lamps
« Reply #12 on: Wed, 13 November 2013, 12:47:16 »
If you put an 100W lightbulb there, it will obviously get quite hot. I'm not really impressed by its quality either.
My favorite lamp is Lival Shuttle Plus. Excellent one except non-standard proprietary socket.
Offline paicrai
  • mindblank
Re: Desk lamps
« Reply #13 on: Wed, 13 November 2013, 14:24:27 »
You don't need a 100W bulb for it though, because the one that (I assume) comes with it is just bright enough for a medium-large room, and is a lot less accident prone. And I think the quality is just fine, the joints are smooth, it is well balanced, which means I can bend it over the edge of my desk and under it without it falling and so on. I don't actually see the problem with it.
Offline davkol
Re: Desk lamps
« Reply #14 on: Wed, 13 November 2013, 15:01:02 »
The arm isn't strong enough. I'd like to put my portable headphones (HD 25) on it, but it moves then.
Mine didn't come with any kind of bulb IIRC. I strongly prefer halogen anyway.
Offline Malphas
Re: Desk lamps
« Reply #15 on: Wed, 13 November 2013, 15:06:04 »
http://www.anglepoise.com/Type75LED.aspx
That is *very* expensive!
Aren't LED lamps quite hot?
What are you guys on about? LEDs are the coolest, lowest powered bulbs you can get.
Offline longweight
  • philanthropist
Re: Desk lamps
« Reply #16 on: Wed, 13 November 2013, 15:10:21 »
That is *very* expensive!Aren't LED lamps quite hot?
OP didn't state a budget.LEDs do get hot but nothing like halogen.
What do you mean "what are you guys on about"?
Offline Malphas
Re: Desk lamps
« Reply #17 on: Wed, 13 November 2013, 15:23:21 »
I honestly don't know how to make that post any more straightforward than it already is.
Offline longweight
  • philanthropist
Re: Desk lamps
« Reply #18 on: Wed, 13 November 2013, 15:35:22 »
So what is wrong with my statement?
Offline paicrai
  • mindblank
Re: Desk lamps
« Reply #19 on: Wed, 13 November 2013, 15:45:20 »
There are screws on it, which you can tighten. Seriously, you can just use a knife. If you don't have a knife, the screws are tall and the sides textured, so you get a good grip of them. I just now picked up a little throwing knife, and tightened the arms on it.
Offline davkol
Re: Desk lamps
« Reply #20 on: Wed, 13 November 2013, 16:57:48 »
I've noticed it, of course. But they were getting loose all the time. I mean, I was used to a simple, but very solid lamp made in early 90s in Europe... I sometimes forget I can't expect this kind of quality from cheap Chinese garbage nowadays... and Ikea isn't even the worst. By far.
Offline tipo33
  • "Ski"
Re: Desk lamps
« Reply #21 on: Thu, 14 November 2013, 04:50:56 »
I've allways wanted one of these lamps mase from a G4 iMac.
KM4COL    R.I.P.  SmallFry
Offline paicrai
  • mindblank
Re: Desk lamps
« Reply #22 on: Thu, 14 November 2013, 08:39:28 »
Actually haven't used my lamp as a makeshift holder, so I don't know if the screws go loose on mine or not, but it seems pretty solid. I tried putting my headphones on it, though, and I encountered no issues. The lamp didn't even budge, it stayed as it stood.
Everything seems perfect on my end, it doesn't seem cheap or especially "made in China"-ish either. You could've gotten some spin-off or something. Since our lamps seem so different, I guess we'll have to label it "Be careful where you buy this", I suppose.
Offline davkol
Re: Desk lamps
« Reply #23 on: Thu, 14 November 2013, 09:12:14 »
Well, in Ikea, obviously.
Maybe yours is older... Things have been going downhill with Ikea. For example, they replaced the True Swedish Crayfish by an ordinary Chinese one in their restaurants few years ago.
Re: Desk lamps
« Reply #24 on: Thu, 14 November 2013, 09:14:02 »
Offline MJ45
  • HHKB Pro
Re: Desk lamps
« Reply #25 on: Thu, 14 November 2013, 09:27:42 »
The best desk lighting that I have seen is Koncept http://www.koncept.com/home.php I have the Z-Bar its the most adjustable led desk available and has lots of mounting options
Offline paicrai
  • mindblank
Re: Desk lamps
« Reply #26 on: Thu, 14 November 2013, 09:52:31 »
They didn't actually have them in stock when I was buying it, I had to wait for a few weeks.
Re: Desk lamps
« Reply #27 on: Thu, 14 November 2013, 15:56:43 »
Although I haven't got a Koncept, I have a vaguely similar USB multi-LED lamp.
The shadows it casts are freaky! :)
Offline olivier.nyc
Re: Desk lamps
« Reply #28 on: Fri, 15 November 2013, 00:33:26 »
i have this Artemide Itis at home in white.
It has a clean contemporary look and super functional with a dimmer
http://www.artemide.us/?page=main/flypage&product_id=2176
Simplicity is a great virtue but requires hard work to achieve and education to appreciate.
And to make matters worse: complexity sells better. (EWD896)
Offline trentva
Re: Desk lamps
« Reply #29 on: Tue, 26 November 2013, 16:34:01 »
check out www.ottlite.com they make really nice desk lamps
