Author Topic: Can't decide..  (Read 4815 times)
Offline Linkbane
Can't decide..
« on: Wed, 23 October 2013, 23:07:59 »
I am very conflicted about what keyboard I should get next.
I really would like a board with MX Clear switches, but I have been hitherto unable to find any economical ones besides the Leopold which qtan sells at a very reasonable $120.
However, after seeing the Ducky YOTS and its lighting modes, I have been hopelessly entranced.
So, trying to decide whether i should get a Ducky S3 with Browns, which I'd like to try as I only have click and linear switches, or the Leopold with Clears.
Very sad. Especially considering that the TKL Shine 3 is coming in a matter of weeks.
Right now I'm somewhat leaning in the Ducky's direction, because I tried Browns once and they were pretty good, but I've never tried clears and they haven't had the chance to convert me yet.
What do I do, geekhack?  :confused:
EDIT: Shine 2 has reactive also! Now, any chance that someone could point me to a place that still has them in stock?
« Last Edit: Wed, 23 October 2013, 23:20:00 by Linkbane »
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline swill
  • builder & enabler
    • swillkb.com
Re: Can't decide..
« Reply #1 on: Wed, 23 October 2013, 23:14:46 »
Buy both and then make your decision.  Oh, right...  Thats why I am broke...   :eek:
Offline Linkbane
Re: Can't decide..
« Reply #2 on: Wed, 23 October 2013, 23:19:33 »
Heh, I was going to put "in before buy both".
You know, I actually found that the Shine 2 has the reactive mode also and apparently some had MX Clears on them.
Now if they were in stock anywhere..
Help?
Offline Reomero
  • Manual breather
Re: Can't decide..
« Reply #3 on: Wed, 23 October 2013, 23:26:32 »
Well, the Shine 2 is now discontinued, so it'll be hard finding one new. Unless maybe you have some contacts in Asia.
Or... be prepared to do some soldering.
Offline Dreamre
    • kbdlife
Re: Can't decide..
« Reply #4 on: Wed, 23 October 2013, 23:31:32 »
Bought a DS2 with purple LEDs and MX Red switches about a month ago and I'm in the process of converting it to white LEDs with ergo clear switches :).
Offline Linkbane
Re: Can't decide..
« Reply #5 on: Wed, 23 October 2013, 23:38:51 »
I'll put up a listing in the classifieds, hopefully I can find something.
Offline swill
  • builder & enabler
    • swillkb.com
Re: Can't decide..
« Reply #6 on: Wed, 23 October 2013, 23:42:58 »
Since I am in Canada, I often buy from: http://ncix.ca/search/?categoryid=0&q=ducky
They have the Shine with browns with a couple LED choices still.  They also allow you to preorder other versions.  Nothing with clears though.
Offline Linkbane
Re: Can't decide..
« Reply #7 on: Thu, 24 October 2013, 02:25:34 »
I really would like to get the Shine 2 with Clears, it seems that it's limited edition and only a few people have them, though.
I suppose that I could get a Shine 3 TKL with Browns, but that's really my second choice, and it's a pretty far second.
Offline Tony
Re: Can't decide..
« Reply #8 on: Thu, 24 October 2013, 02:42:31 »
Sooner or later you will get both of them, so which first does not matter.
Save your mind and indecision for other things.
Offline Linkbane
Re: Can't decide..
« Reply #9 on: Thu, 24 October 2013, 02:56:25 »
Problem is not that I want just Clear or just Shine, I would like a Shine with Clears. But given that desoldering LED's is difficult, it might be impossible to get a non-original one.
Re: Can't decide..
« Reply #10 on: Thu, 24 October 2013, 03:06:00 »
desoldering led is easy because the pins are close together..  so you can do them both at the same time.
Offline Dreamre
    • kbdlife
Re: Can't decide..
« Reply #11 on: Thu, 24 October 2013, 10:36:50 »
Trust me, after some practice, it isn't too hard! I already removed all my LEDs. I'm just waiting for my other parts to be shipped :D. Mechanical Keyboards has MX Clear switches for $49 for a pack of 100. Convert one!
Offline Linkbane
Re: Can't decide..
« Reply #12 on: Thu, 24 October 2013, 10:55:53 »
So, would soldering in keys with LED's be difficult?
I found someone in the services section who would be willing to do it for me for a mere $20, but it is important that the LED's on the switches be changed.
« Last Edit: Thu, 24 October 2013, 11:01:29 by Linkbane »
Re: Can't decide..
« Reply #13 on: Thu, 24 October 2013, 10:57:35 »
I found someone in the services section who would be willing to do it for me for a mere $20, but it is important that the LED's on the switches changed.
If the board if backlit and you want to swap switches yes all LED's and swithches would have to be desoldered on an OEM board.
Offline Linkbane
Re: Can't decide..
« Reply #14 on: Thu, 24 October 2013, 11:01:15 »
Cool, it hopefully won't be too difficult for him to do.
But what about adding new LED's?
Offline Dreamre
    • kbdlife
Re: Can't decide..
« Reply #15 on: Thu, 24 October 2013, 22:38:41 »
You can reuse the LEDs after they have been desoldered.
Attached are some pictures of my mini project. Sorry for the horrible pictures, took it off my cellphone :P.
Offline Linkbane
Re: Can't decide..
« Reply #16 on: Thu, 24 October 2013, 23:11:33 »
Ahh, I didn't know that. Do the switches require modification before an LED can fit in them?
Re: Can't decide..
« Reply #17 on: Fri, 25 October 2013, 07:35:04 »
No, there's a set of holes where the LEDs can fit into in the switches.
Offline Linkbane
Re: Can't decide..
« Reply #18 on: Fri, 25 October 2013, 08:15:48 »
Great, that makes things quite convenient for the LED modding I'm hoping to get done, then.
