Author Topic: Open Switch on plated mounted keyboard  (Read 2670 times)
Offline BakaPhoenix
« on: Thu, 31 October 2013, 12:19:48 »
I often read of lubing and changing stem/springs on switches...
But is possible to open the switches on a plated mounted keyboard? I read on other site/forums that is only possible with pcb mounted switches. If is true, everytime you have to disolder all the switches? O_O
Thanks for the answers :D
Offline MKULTRA
  • telling it how it is
Re: Open Switch on plated mounted keyboard
« Reply #1 on: Thu, 31 October 2013, 12:20:50 »
Please use the search function.  This has been covered a million times.  Simple Questions, Simple Answers.  Making Stuff Together Subforum.
« Reply #2 on: Thu, 31 October 2013, 12:27:20 »
Check this out.
« Reply #3 on: Thu, 31 October 2013, 12:31:05 »
The only way to open plate mounted switches is if the plate has cut outs to allow it, which currently is only possible with custom plates.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #4 on: Thu, 31 October 2013, 19:09:02 »
I will be more than willing to buy one these plates. Where can I buy one?
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Thu, 31 October 2013, 19:37:10 »
Beast and I had some made in the past, but currently you can't buy them at any stores.
Offline Pacifist
  • on hiatus
« Reply #6 on: Thu, 31 October 2013, 19:38:59 »
The ones you made were for TKL, and not any other format right?
« Reply #7 on: Thu, 31 October 2013, 19:40:32 »
tkl & 60%.
Offline Pacifist
  • on hiatus
« Reply #9 on: Thu, 31 October 2013, 20:09:39 »
tkl & 60%.
& Ergodox...
O.O
Please make more in 6 months when I get an ergodox
« Reply #10 on: Thu, 31 October 2013, 20:18:22 »
tp, i'm pretty sure that was litster.
ergodox comes stock with a plate that allows switch top removal.
Offline terran5992
  • One With The Cup Rubber
« Reply #11 on: Thu, 31 October 2013, 20:29:20 »
Wow I did. It know that
