Author Topic: Help: some keys not working on a QFR  (Read 3909 times)
Offline infiniti
  • I <3 KB
  • Bob was here
« on: Tue, 12 November 2013, 03:27:30 »
My brother in law's QFR is acting up.  It's out of warranty and the following keys don't work:
Note: The Menu/FN key works but just doesn't show up in Aqua's Key Test.
F3   F7
BACKSPACE
TAB   T   Y   [{   ]}
CAPS LOCK
SHIFT (left)
WIN (left)
Things that I have tried but didn't work:
  • swapping the controller out with the controller from a QFR known to work
  • swapped out the switches that aren't working
  • inspected the PCB and everything seems to be OK
Anything else I can do?
Edit:  Added that it is out of warranty.
« Last Edit: Tue, 12 November 2013, 03:34:47 by infiniti »
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
Re: Help: some keys not working on a QFR
« Reply #1 on: Tue, 12 November 2013, 04:05:56 »
I dont know anything without looking at/probing around the circuit but im going to go out on a limb and say that a diode may have failed. or maybe a short on a pull up/down resistor.
"Obviously, windows are central to Windows. But what is a window?"
Offline phoenix1234
« Reply #2 on: Tue, 12 November 2013, 04:06:35 »
I think a picture of the PCB would be helpful.
If you did :
+ swap the switches
+ swap the controller
but it still did not work
=> the PCB could be the one we need to inspect more.
I like linear switches
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #3 on: Tue, 12 November 2013, 04:10:04 »
Thanks for the input guys!  I'll make some time to desolder the switches and see what up with the PCB.
*breaks out the soldering equipment*
    • Force Project X
« Reply #4 on: Tue, 12 November 2013, 04:15:19 »
before you start soldering, it might be useful to give the switch terminals a probe with a multimeter to see if its getting a current. If its not getting power at the switch, then the switch probably isnt an issue.
eta: you may need a multimeter with a  μamp range.
« Last Edit: Tue, 12 November 2013, 04:19:22 by kolonelkadat »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5 on: Tue, 12 November 2013, 04:29:54 »
It's not getting any current.  It's most probably the PCB. :(
Going to start in a bit...
« Reply #6 on: Tue, 12 November 2013, 05:16:28 »
F3   F7
BACKSPACE
TAB   T   Y   [{   ]}
CAPS LOCK
SHIFT (left)
WIN (left)
Um...... hmmm.. if the board looks fine.. and it's not multiple fractures..  then it's probably on the controller end..
Unfortunately the cost in "time" to fix this problem far exceed the cost of replacing the keyboard..
pull the daughter board off, check for damage..
You COULD get the qfr replacement controller board and try that.. at worst it's not the controller, and you can stick it in the NEW replacement QFR which you would've had to buy anyway... there was a GB around here some where.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #7 on: Tue, 12 November 2013, 05:59:26 »
Yeah, I've considered the cost of my time but I think there's just something shorted between the plate and the PCB.
If the PCB is dead, at least I would have harvested all the switches already haha
« Reply #8 on: Tue, 12 November 2013, 06:03:40 »
As weird as it sounds some QFR problems are caused by the screws being too tight, your issue doesn't sound so simple but you never know.
Offline terran5992
  • One With The Cup Rubber
« Reply #9 on: Tue, 12 November 2013, 06:26:48 »
0.o Does that actually happen?
« Reply #10 on: Tue, 12 November 2013, 06:58:06 »
There have been many reported instances where people loosened the case screws and the problems went away. Not saying that is the issue here but for a certain batch of QFR's it was an issue.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #11 on: Tue, 12 November 2013, 07:45:37 »
Yes, this happened to my other QFR...the screw was too tight and was causing the bottom of the PCB to scratch against the top of the USB daughter board.
It wasn't the case for this one...problem persisted even with the top cover off.
________
Anyway...
THE CULPRIT:
An extra jumper wire that shorted other jumpers
It looks like it was left over from manufacturing.
« Reply #12 on: Tue, 12 November 2013, 18:14:06 »
________
Anyway...
THE CULPRIT:
Well found!
Have to try to remember this for future reference.
