Author Topic: What is the weighting on the average laptop scissor switch keyboard?  (Read 3137 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Well i was wondering what the weighting was on these type of keyboards, I'm typing on one right now and i just want to gauge on how heavy of Switches i am typing on right now so i can decide on 55g or 45 topre.
I was under the impression that they go from 62g-65g, But then i was recently told that they where alot lighter than that. could someone clear the air for me and give me an answer on how heavy the average scissor switch is? I'm using a Toshiba satellite if that helps.
Re: What is the weighting on the average laptop scissor switch keyboard?
« Reply #1 on: Sun, 08 December 2013, 05:48:40 »
Test it for yourself
Just stack nickles or dimes or pennies with known weights ontop of your key until it just about goes down..  then count them and multiply.. done..
Every laptop will be different..  the age of the keyboard, and the usage statistic of the key being tested (e- key ) vs (tilda-key ~)
Offline Air tree
« Reply #2 on: Sun, 08 December 2013, 06:07:42 »
I will try that then.
One more thing, Where the hell do you get those amazing .gif/cute things?!?!
« Reply #3 on: Sun, 08 December 2013, 06:31:37 »
wouldn't you like to know
I tried to get everyone on GH to adopt it... but they're too lazy to set it up...
You need emoticonverter addon and toolbar autohide addon for firefox.
This is the only known way to use it effectively...
Once you install those addons,, use emoticonverter and LOAD the xml file I've attached, it will have all the rabbit and the cat ones.
Offline Air tree
« Reply #4 on: Sun, 08 December 2013, 08:22:31 »
You are amazing!
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #5 on: Sun, 08 December 2013, 09:24:13 »
it varies by manufacturer. iirc its in the typically 50-60g range.
here is a link to a list of measurements
http://www.reddit.com/r/MechanicalKeyboards/wiki/ripometer#wiki_scissor_switches
« Last Edit: Sun, 08 December 2013, 09:27:34 by kolonelkadat »
"Obviously, windows are central to Windows. But what is a window?"
Offline yasuo
  • spanengan puyeng newbie
« Reply #6 on: Sun, 08 December 2013, 09:26:53 »
:eek: you collector emoticon
Logitech MK220 Colemak DH
« Reply #7 on: Sun, 08 December 2013, 11:25:07 »
You are amazing!
Every time u use that emoticon.. it requires "no-homo"...   Otherwise people might get the wrong idea...
Offline yasuo
« Reply #8 on: Sun, 08 December 2013, 11:33:14 »
You are amazing!
« Reply #9 on: Sun, 08 December 2013, 11:48:31 »
You are amazing!
Offline Linkbane
« Reply #10 on: Sun, 08 December 2013, 12:54:07 »
I always just went to cute-factor and pasted the forum image link.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
