Author Topic: Just checking...  (Read 2334 times)
Just checking...
« on: Tue, 10 December 2013, 17:43:32 »
Saw this in a movie..
The guy's got a light bleed..  this guy rips up some cigarettes onto some tissue and makes a compress..
This should be BAD.. correct?
Offline 127001
Re: Just checking...
« Reply #1 on: Tue, 10 December 2013, 17:45:23 »
It's not sanitary.
Super glue works better anyway. That's what I use when I cut myself by accident. Hospitals too
Offline BlueBär
« Reply #2 on: Tue, 10 December 2013, 18:12:34 »
Wait so he puts the tobacco in the compress? Nicotine is toxic, I don't think that would be a good idea.
« Reply #3 on: Tue, 10 December 2013, 18:33:24 »
yea.. ur probably right... I was highly suspicious of this...
« Reply #4 on: Tue, 10 December 2013, 18:46:02 »
Using a tobacco compress to stop light bleeding is an old folk remedy. Strictly temporary and only if nothing better is available, of course.
- D Trump 2026-09-28
« Reply #5 on: Tue, 10 December 2013, 18:48:26 »
so there is something to this?
Offline BlueBär
« Reply #6 on: Tue, 10 December 2013, 18:56:26 »
Just googled it, apparently it really helps against light bleeding. Interesting.
« Reply #7 on: Tue, 10 December 2013, 19:03:03 »
Interesting.
Don't throw out the antibiotic ointment just yet.
« Reply #8 on: Tue, 10 December 2013, 19:04:49 »
u mean that one post on ask wiki? LOLOL
I saw this pdf.. it says the tobacco thing is a myth..
http://www.kcfirstaid.com/images/first_aid_myths_mistakes.pdf
But honestly... I think anything that works like a gauze.. that soaks up liquid and holds blood there for it to clot will work to stop light bleeding..
So maybe it's not as much a myth.. as it's just that light bleeding can be stopped by anything...
Computer paper would probably work too.
Offline BlueBär
« Reply #9 on: Tue, 10 December 2013, 19:29:00 »
Interesting != I would ever use this or recommend using this :p
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #10 on: Tue, 10 December 2013, 20:07:16 »
That and you get your fix.  :p
« Reply #11 on: Tue, 10 December 2013, 20:25:16 »
I take it packing in a bunch of dirt and covering with something would work also in a bind?
