Author Topic: Help! I mixed up my keys  (Read 1749 times)
Offline aquatic
« on: Wed, 11 December 2013, 17:44:28 »
I removed the keys on my filco majestouch 2 today and cleaned it. I assumed that all square keys where the same size/shape, so mixed all the keys together. Furthermore I use blank keys. Now that I try to put them back I notice that they are all shaped slightly different, and I don't know which keys go where. I sorted all square keys into four categories: flat, slight backward tilt, backward tilt, slight forward tilt. Are there only four types of keys or are there differences I missed? Anyone know which group of keys is supposed to sit on which row?
Offline Pacifist
  • on hiatus
Re: Help! I mixed up my keys
« Reply #1 on: Wed, 11 December 2013, 17:45:13 »
look on the inside of the caps, it tells the row number
« Reply #2 on: Wed, 11 December 2013, 17:48:50 »
Offline esoomenona
  • Gnillort?
« Reply #3 on: Wed, 11 December 2013, 17:59:15 »
Take a picture of the four groups, from the side, next to each other, and I'll tell you where they go.
Offline aquatic
« Reply #4 on: Wed, 11 December 2013, 19:09:32 »
Thanks everyone. I looked on the inside of the keys and there are row numbers and then ordinary numbers (e.g R3 and underneath it 13). I saw this post which looked really helpful, but I have a different keyboard layout. I have 13 keys in row 1 of the "main area" of the keyboard, while the keyboard in the link has 12 (hope that makes sense). Anyone know if there is a similar diagrams for other layouts?
Edit: my keyboard is 105 key layout, the diagram in the link is 104 key layout.
« Last Edit: Wed, 11 December 2013, 19:14:40 by aquatic »
« Reply #5 on: Wed, 11 December 2013, 19:30:44 »
hahahaha... epic n00bness...
how did you get them on right the first time?
Offline Pacifist
  • on hiatus
« Reply #6 on: Wed, 11 December 2013, 19:45:46 »
not all keyboards come unassembled
Offline aquatic
« Reply #7 on: Wed, 11 December 2013, 19:58:00 »
Yes, epic fail. The keyboard came assembled. Anyway put on all the keys by looking at row number and it looks okay  :thumb:.
Offline reziak
  • Topre/60% Enthusiast
« Reply #8 on: Thu, 12 December 2013, 03:17:15 »
The keys of the same size in each row should be interchangeable :) Just watch out for little nubs or scoops on the F and J keys, and the numpad 5 key might have a nub or marking as well. If your keys are the same as some of my old blank sets, F, J and 5 on the numpad are Row 2.
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
