Author Topic: Advice for a Noob.  (Read 4387 times)
Offline Lodestar
Advice for a Noob.
« on: Wed, 25 December 2013, 07:00:55 »
Hi
I'm just looking for advice about mechanical keyboards. I was originally going to get a Corsair K70 but when I went on the linus tech tips forum every said ducky shine was better. So I looked around and decided I really liked the Year of the snake. An online retailer in Australia was selling them but just on the day I decided that I wanted to buy it, It was sold out. After doing a bit of research and deciding that having a custom keyboard would be pretty cool, I'd just like to ask a few questions regarding keyboards.
1. PS/2 vs USB, PS/2 has lower response time but is it worth it?
2. What mechanical keyboard would you recommend for a beginner? I'd like to be able to change the switch type and modify it by putting say an aluminium faceplate on it.
Btw I mainly game and code so I'm thinking of cherry MX brown switches.
Thanks
Offline inteli722
Re: Advice for a Noob.
« Reply #1 on: Wed, 25 December 2013, 07:04:41 »
Hi
Thanks
1. PS/2 if you have it. No reason not to use it if you have it.
2. Any MX keyboard can have its switches changed given enough time, though most have plates already installed. If you really want to install the plate yourself, then you could cut your own plate for a Cherry Board or a Poker X. Aside from that, I would recommend a QuickFire Rapid for a beginner. Many switch types, basic, and cheap (but not cheaply made). Very good keyboard for the price.
Waiting for: Phantom Plate
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #2 on: Wed, 25 December 2013, 07:06:00 »
Welcome to Geekhack!
1) PS/2 is worth it if certain conditions are met. I am not going to paste them out here but it has been thorougly discussed (and I don't want to start another huge debate on the said subject as well). http://geekhack.org/index.php?topic=51821.msg1162570#msg1162570
2) Most people here would recommend QFR for first mechanical keyboard. Though I am not sure on changing the switch type. I mean it is still doable with soldering station/setup/workspace/area/etc for instance.
Good luck with your quest on mechanical keyboards!
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Wed, 25 December 2013, 07:23:38 »
1) PS2
2)Cherry mx Blue board
Offline Lodestar
« Reply #4 on: Wed, 25 December 2013, 07:26:33 »
Thank you for your reply however I can't find the Quickfire Rapid in Australia, It does seem like a very reliable keyboard. Do you have any other suggestions?
And thank you for the quick replies.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #5 on: Wed, 25 December 2013, 07:31:51 »
Example: http://www.staticice.com.au/cgi-bin/search.cgi?q=CoolerMaster%20QuickFire%20TK
Offline Lodestar
« Reply #6 on: Wed, 25 December 2013, 07:39:05 »
That is the Quickfire TK however. Is it alright? I read somewhere on these forums that the rapid is made in the same factory as DAS but the TK is made differently.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #7 on: Wed, 25 December 2013, 07:49:45 »
That's why I wrote as "Example"  ;D Quickfire Pro: http://www.staticice.com.au/cgi-bin/search.cgi?q=QUICKFIRE&spos=1 (of course there are TK mixed in it but staticice is like google search engine for local electronic (computer related usually) retailers (though this one is Australia only). One can go through the list and refine the searches more to states, etc.
Offline Lodestar
« Reply #8 on: Wed, 25 December 2013, 08:04:47 »
So the Pro or the TK?
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #9 on: Wed, 25 December 2013, 08:38:04 »
The Pro lacks numpad (basically a TKL from a photo that I saw). TK from what I saw last does not have arrow keys for instance but has numpad.
I guess according to this:
I don't know if I would buy a Ducky Zero. They are made in China, not Taiwan.
But there are better choices than the Steelseries. CM Quickfire XT, Ducky, Filco, maybe Leopold. You want something with a standard key caps layout.
You may as well get QFR XT:
http://www.mwave.com.au/product/cooler-master-cm-storm-quickfire-xt-cherry-mx-blue-keyboard-ab50908
Offline Lodestar
« Reply #10 on: Wed, 25 December 2013, 08:48:06 »
Okay Thank you very much for your help I will probably get this keyboard.
« Reply #11 on: Wed, 25 December 2013, 16:20:02 »
QFS == QFR in Australia: http://www.mechkb.com/products/mechanical-keyboards/cooler-master/cooler-master-cm-storm-quickfire-stealth-mechanical-keyboard
There are also a few Ducky YotS still available, not sure you'd want to pay $350 + shipping though :eek:
Offline Lodestar
« Reply #12 on: Wed, 25 December 2013, 23:22:21 »
Quickfire Stealth vs Das Ultimate? (Both with brown switches) They both have PS/2 which gives better latency if I am correct? The Das has better stabilisers or something that makes it feel more like a mechanical keyboard.
Online tp4tissue
« Reply #13 on: Wed, 25 December 2013, 23:25:05 »
How old are ya Lode
Offline Lodestar
« Reply #14 on: Wed, 25 December 2013, 23:28:00 »
Why?
Online tp4tissue
« Reply #15 on: Wed, 25 December 2013, 23:29:06 »
Why?
i have to adjust my recommendation based on your competence with electronics and objective-judgement.
Offline Lodestar
« Reply #16 on: Wed, 25 December 2013, 23:31:56 »
I'm 15 if you need that to help answer.
Online tp4tissue
« Reply #17 on: Wed, 25 December 2013, 23:40:37 »
Yea, go fur the quickfire Rapid.. best board for the price.. and mechkeyboard site is pretty solid. responsible sellers..
The only advantage to more expensive boards is generally - "bling" factor..
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #18 on: Thu, 26 December 2013, 00:00:08 »
1) It boils down to taste, I think most people on the board here would recommend Quickfire (in general) for first mechanical keyboard. Das keyboard may look nice but that is more or less it. I read Das keyboard uses ABS (common as hell) plastic and am not exactly sure on Quickfire's keycap material.
2) PS/2 gives lower latency yes but that does not necessarily mean that it is superior completely to USB. If you have read through the link that I posted on PS/2 and USB you would have noticed there was a big talk about it. However one still needs to question at the end of the day is PS/2 really all that much worth it in their case. There are professional gamers with mechanical keyboards but are using USB. I am talking about Korean Starcraft players for instance. The funny irony is that I don't think they would be willing to contemplate on using dated PS/2 technology just for lower latency. USB protocol has much higher bandwidth than PS/2 (theoretically), provides more power than PS/2 and is more durable (in general) than PS/2.
I personally do not believe most average people would benefit that much by switching from USB to PS/2 apart from the few possible scenarios where PS/2 is definitely required. Otherwise the lag as mostly noted is only worth 1 milliseconds if speed is such an important issue.
3) Not sure on better stabilisers but I do know that within the Cherry MX realm the talk has always been on various stabilisers such as Cherry vs Costar. However the bottom is that most people still generally recommend Quickfire for beginner's board. That must also mean that when choosing Quickfire you may get better support coverage.
4) The "feel" of mechanical keyboard is often a disputed taste over switches/forms. There are up to as much as a dozen different switches floating around and there would be various people that would recommend X over Y. Ideally for any beginner is to start something that has been recommended by those who probably would have tried more than one mechanical keyboard. Unless you had a keyboard you wanted for a long time like I did and you have been firm on reasons for choosing a specific board - you are better off choosing a recommended one by others in general.
« Last Edit: Thu, 26 December 2013, 00:02:55 by tuxsavvy »
Offline domoaligato
« Reply #19 on: Thu, 26 December 2013, 00:37:03 »
I would like to add that if you can not find a qfr a filco is a little more and if available to you is another excellent choice. it is easily converted to a phantom and plates are made here from time to time for them.
custom programmable controllers also exist for them as well. also available for the qfr. personally IMHO filco build quality is better then the qfr but it might not be worth the added $$$ for you.
Offline Lodestar
« Reply #20 on: Thu, 26 December 2013, 00:59:46 »
Ok thank you very much for your help, I've decided on a CM storm quick fire stealth.
Online tp4tissue
« Reply #21 on: Thu, 26 December 2013, 01:11:08 »
It's silly to buy a filco for the xpress purpose of conversion.. That is twice the work..
Offline domoaligato
« Reply #22 on: Thu, 26 December 2013, 01:45:28 »
wtf are you talking about? the phantom was designed to replace the filco pcb... that is the purpose of the phantom.
edit: let me add more to this....
why buy something that you can not later customize if you wish? your a ergodox fanboy and you have a custom layout.
why shouldn't I suggest that this person buy a keyboard that they could later customize if they wished?
« Last Edit: Thu, 26 December 2013, 01:56:07 by domoaligato »
Online tp4tissue
« Reply #23 on: Thu, 26 December 2013, 02:20:11 »
LOL.. egdx is not a keyboard.. it's a completely different way of life..
You don't have one, I wouldn't expect you to understand..
« Reply #24 on: Thu, 26 December 2013, 03:28:16 »
Just to mention that the QFS differs from the QFR in that the stealth has front-printed keycaps.
If you are used to reading the legends on the top of the keycaps, you might also consider either buying a QFR from overseas, or sourcing a replacement keycap set.
Offline Lodestar
« Reply #25 on: Thu, 26 December 2013, 06:36:16 »
I'm fine with that, I was actually thinking that it didn't have printed keycaps on it which was something that I really wanted but I don't care about that too much.
Offline nol166
  • I type for a living.
« Reply #26 on: Thu, 26 December 2013, 06:51:44 »
If i were to recommend a keyboard for a beginner I would check out the Filco Majestouch series. They feature all flavors of Cherry switches and won't explode your wallet. It will give you a feel for cherry switches/mechanical keyboards in general ... and the quality is second to none.
I generally try to keep away from Corsair, Razor, etc. because i feel like they focus more on quantity over quality.
Also, take what Linus says with a grain of salt. He has a heavy bias (admitted or not) towards his sponsors. Amazon reviews are also helpful.
HHKB Pro 2, Majestouch Ninja TKL, Das Mac
Offline domoaligato
« Reply #27 on: Thu, 26 December 2013, 12:25:12 »
I already recommended the Filco Majestouch tenkeyless...
« Reply #28 on: Thu, 26 December 2013, 19:10:23 »
Generally Filco are more expensive than a lot of the alternatives mentioned here.
If you do happen to know somewhere to get Filco for a reasonable price - please share! :)
