Author Topic: Need help finding a keyboard  (Read 4985 times)
Offline Misterorjoe
« on: Fri, 27 December 2013, 23:15:12 »
I have searched far and wide for what I want, but so far, to no avail  :(
My non-negotiables:
Additional nice features:
  • Bluetooth compatible
  • Programmable LED's
  • <$200
  • Waterproof
  • USB passthrough
  • audio passthrough
I currently use a type-matrix, but am dissatisfied with its lack of cherry, thumb keys, etc. Any help would be much appreciated.
Offline fourzeropooh
Re: Need help finding a keyboard
« Reply #1 on: Fri, 27 December 2013, 23:17:18 »
buy tipro wire a teensy on there
« Reply #2 on: Fri, 27 December 2013, 23:21:11 »
/headscratch... mmm
The type matrix is "m0re" ergonomic than a standard qwerty for sure...
But..... it's still not a very ergonomic compared to say a Kinesis or Egdx
The matrix layout if "not" angled and tented requires the wrist to turn inwards while twisting outwards..
I'd recommend the Egdx, but the Kinesis/maltron is more/less the same and you wouldn't have to build it.
Offline Misterorjoe
« Reply #3 on: Sat, 28 December 2013, 11:56:53 »
Why would I need to wire a Teensy?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sat, 28 December 2013, 12:18:17 »
How about an Access IS? Not sure how large you need, heres another model with more keys.
Offline Misterorjoe
« Reply #5 on: Sat, 28 December 2013, 12:24:01 »
Those would be perfect if they were bigger. I need 15x7 minimum.
« Reply #6 on: Sat, 28 December 2013, 12:57:39 »
I'm pretty sure they make larger models. Perhaps you will just have to keep your eye out and do some more hunting than my quick look. You could always buy 2 smaller models as well as it would still be under your budget. Since they are fully user programmable, they wouldn't conflict with each other if you went that way.
Some others to look out for, Cherry G80-1950 (though it is a pain to program, it's long been out of production and requires DOS/Win 9x to program it), there is a newer model that replaces it but it is actually made my Tipro and the Cherry rebrand model number escapes me, Tipro as already suggested and they do make some BIG ones, Accuratus has a couple of models and I think also same thing under HengYu brand. I've also ran across a few randomly while searching under point of sale keyboards that I can't recall the make and model of.
« Last Edit: Sat, 28 December 2013, 13:16:23 by IvanIvanovich »
Offline Misterorjoe
« Reply #7 on: Sat, 28 December 2013, 13:56:31 »
They are exactly what I am looking for, but the price is more than I can handle. Are there any bare matrix boards I could buy and program myself? Or would that not me cheaper?
« Reply #8 on: Sat, 28 December 2013, 18:42:11 »
Keep an eye on ebay, you can find them cheap. It's a bit unusual... but after a good clean up it would probably be fine.
Offline Misterorjoe
« Reply #9 on: Sat, 28 December 2013, 19:15:25 »
I'll look around. I'm really interested in the ErgoDox though. Thanks!
Offline terran5992
  • One With The Cup Rubber
« Reply #10 on: Sat, 28 December 2013, 20:25:17 »
Keycaps would be a bit hard to find
Offline Misterorjoe
« Reply #11 on: Sat, 28 December 2013, 22:27:09 »
Are they not standard key caps?
« Reply #12 on: Sat, 28 December 2013, 23:36:28 »
Most people use blank DSA from Signature Plastics on EDox. Other type of keycap may indeed be much more challenging, especially sculpted keycaps that are different shape on each letter row like most keyboard have. Also depending on desired layout, legended keys may be improbable to impossible. For the most part, you can always work around limitations if you are a little flexible.
« Reply #13 on: Sat, 28 December 2013, 23:46:46 »
We don't know "for sure" what most people use on Egdx.. because it was designed to be a highly adaptive platform..
But..... I don't use DSA myself for the main keys.. I use the imsto blank pbt. The stem is smoother than the original kbc pbts.
DSA surface area is 40% less than DCS/CHERRY/OEM
with DCS it's much easier to hit the keys.
IDK why any Egdx owners would want printed caps on the ergodox.. it's just silly...
The Egdx allows 0 jump/lift key access, there's absolutely NEVER a need to look down..
Everything is accessible by single finger pivot.
Higher accuracy is much more achievable on the Egdx.
Now, if you're after the aesthetic factor of label caps... yea.. i get it... but... the EGDX will change the way you look at keyboards forever..
You will see it as a sharp tool... pretty be damned...
Offline jabar
« Reply #14 on: Sun, 29 December 2013, 00:05:44 »
This is the case for everyone, especially considering the list you provided. No mech keyboard is going to be waterproof (BL82 "splash guard" doesn't count), and since keyboards are low-power you won't be able to use a USB passthrough for anything beyond a mouse. The only programmable keys/LEDs are strictly custom stuff.
ErgoDox is likely the best candidate but without backlighting.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Misterorjoe
« Reply #15 on: Sun, 29 December 2013, 01:17:25 »
All I want is uniform, simple, black keycaps. What do I need to look for?
I actually read somewhere that ErgoDox can/will have backlighting. It does seem to be everything I was searching for other than that though.
« Reply #16 on: Sun, 29 December 2013, 01:45:56 »
get the blank black thick pbt on order from the Group buy.
Then order some 2x and 1.5x pbt dsa keys from Signature plastics.
Offline BucklingSpring
« Reply #17 on: Sun, 29 December 2013, 10:39:06 »
@Misterorjoe - It seams that you know exactly what you are looking for (the solution)
But what is the purpose?
I often work with "solution architects" man these guys can be annoying. But they have a valid point.
You go there and take a lot of time to explain in great details what you want. Then ask if such thing exists.
For which they usually respond. Sorry I was not listening and what you want is irrelevant. Tell me your goal and your constraints and let the pros figure out the way to get there.
Boards I own, click ->
Offline Misterorjoe
« Reply #18 on: Sun, 29 December 2013, 11:50:46 »
The Ergodox is really everything I am looking for in a keyboard. All I wish it had is either entirely impossible (waterproof, a display on every key, made of gold and platinum, can make me food) or is possible with a bit of hacking (wireless, backlighting, usb hub built in).
