Author Topic: WASD/Code Keyboard quality vs Duscky Shine Green MX Switches  (Read 15748 times)
Offline pchatterjee
« on: Sat, 28 December 2013, 14:25:47 »
So im considering getting the WASD/Code or Ducky Shine 3 with Green MX switches.
My preferences is for as close to the feel of buckling spring M as possible in a modern keyboard design.  Does the WASD/Code keyboard have better quality than the Ducky's or are they about the same?
The WASD/Code keyboard uses a a steel backplate which I think makes a difference and hence is making me lean that way over the Ducky.
Both use ABS keycaps and case that I do not like (are there good case replacements for either, metal is preferred with numbpad space).  Help with the questions above would be much appreciated.
I am currently using a CM Stealth with greens (I have various model M -- just sold a SSK, and black label M that does have a better stiff feel than any Unicomp) that I really like but I want the ten key (and steel backplate if it makes a difference).
Offline AKIMbO
  • HHKBro
Re: WASD/Code Keyboard quality vs Duscky Shine Green MX Switches
« Reply #1 on: Sat, 28 December 2013, 15:17:22 »
Get the WASD solely to support an awesome vendor/small business.
| KBD75 (box reds)
Offline BlueMica
  • 1994 RX-7 R2 GT35R 500+AWHP 2004 Subaru STI GT45R
« Reply #2 on: Sat, 28 December 2013, 15:47:36 »
Ducky also uses plate mounting and the software included on the keyboard is pretty impressive. Ducky included a special feature called "Repeat Acceleration" which adjusts the repeating duty cycle of a key when held down, which WASD who sponsors RTS/MOBA teams lacks in the key feature that I view is very valuable to RTS/MOBA players. WASD is pretty barebones and I don't view it anymore special than a Filco released in 2008. These two brands are pretty close based on price and both are solid choices, but the Ducky beats it with its modern features. From my ownership the Ducky faults are porous cheap key cap puller, weak sidewall on spacebar (broke the non-snake version), and stiff stabilizers.
Noppoo Choc Mini Black POM Cherry MX Red | Filco MJ1 Cherry MX Blue | Realforce 87U "EK-Edition" |1989 IBM SSK | Filco Ninja Cherry MX Brown | Filco Zero TKL
Offline pchatterjee
« Reply #3 on: Sat, 28 December 2013, 15:54:51 »
Thanks this is pretty helpful.  Any good replacement caps -- that would still show the LEDs?
Also when you say plate mounted -- is it a steel plate?
« Reply #4 on: Sat, 28 December 2013, 15:58:34 »
this doesn't make sense, if you're looking for "as close to buckling spring as possible". they still "make" buckling spring..
AND  the ssk is now confirmed in the works....
Offline BlueMica
« Reply #5 on: Sat, 28 December 2013, 16:04:13 »
Yes, I would guess steel (anodized black) as aluminum is too weak at this kind of gauge. Most non Ducky keycaps will end up looking like the Ducky Yellow, so if you want blank PBT you wouldn't have a problem.
Offline Psybin
  • of Rallos Zek
« Reply #6 on: Sat, 28 December 2013, 16:25:01 »
Good luck finding a Code, those are going for stupid prices on eBay.
Offline pchatterjee
« Reply #7 on: Sat, 28 December 2013, 16:30:30 »
Already have buckling spring -- if you read my original post -- I said in a modern case/design.  Green switches come close to the feel I like -- they still make an unpleasant noise compared to buckling springs.
Also if you understood my original post -- I said I already owned an SSK which I sold (so I dont want another one really) -- i prefer to have something with the numpad.
« Last Edit: Sat, 28 December 2013, 16:32:04 by pchatterjee »
Offline moogle
« Reply #8 on: Sat, 28 December 2013, 16:31:31 »
there will be a new batch of code keyboards w/ green switches available next month according to the latest updates @ codekeyboards.com
Offline pchatterjee
« Reply #9 on: Sat, 28 December 2013, 16:33:34 »
They have new WASD v2 (almost same as code without lights) available with green switches and the Code will supposedly come out in January with MX Greens as well.  So they are basically available - I am not talking about the Clear switches.
Offline terran5992
  • One With The Cup Rubber
« Reply #10 on: Sat, 28 December 2013, 20:32:06 »
There are plenty of backlit compatible keycaps like the max keyboard keycaps
And yes it is a steel plate
Offline jabar
« Reply #11 on: Sat, 28 December 2013, 23:57:05 »
huh, so WASD does finally have MX Greens...
Basically, two options here: do you want backlighting? If yes, Ducky has the most impressive array of options (colors and switches) as well as functionality.
If no, I would recommend finding a replacement non-ABS keycap set. All WASD keycaps are ABS. Ducky does offer PBT keycaps, but PBT keycap sets for standard 104 ANSI keyboards can be found here. However, if you are seeking MX Greens, you are rather limited.
Backlit MX Green options:
Ducky Shine 3, blue or white $169
Code when it comes out (I am going to guess around $170 for MX Greens)
Normal MX Green options:
Ducky G2Pro MX Green w/ PBT: $144
WASD barebones: $120 + a keycap set
WASD w/ custom ABS keycaps: $170
Cooler Master QFR, Trigger, XT, $100 - 120 IIRC
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline 1pq
  • Hipster Doofus
« Reply #12 on: Sun, 29 December 2013, 00:52:50 »
Although they are probably the mx switch closest in feel to BS, the experience of typing on a mx green board will be very different than a model m. If you enjoy BS, you should just wait for the unicomp SSK.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
« Reply #13 on: Sun, 29 December 2013, 01:06:25 »
then why not the unicomp?
« Reply #14 on: Sun, 29 December 2013, 01:58:16 »
"Modern" mechanical keyboards tend to have either MX or Topre switches.  Some form of Alps in Matias keyboards, but I understand that they are striving towards making their keyboards silent, which is the opposite of your goal.
Topre is pretty quiet - not much like BS at all.
Of the MX switches, green is probably closest to BS in that it clicks and is fairly stiff.  But the sound is completely different.  The feel is somewhat different too.
But probably the closest you will get.
Offline pchatterjee
« Reply #15 on: Sun, 29 December 2013, 02:01:17 »
Already had a Unicomp and I still like the original Models Ms more if I had to choose..  I don't think you are getting my point.  I want something with a more modern aesthetic.  I am pretty satisfied with my array of of Model Ms,
If a company could take BS keyboards and put them in metal housing (maybe with backlights) I would be pretty happy and not have it look.  As long as Unicomp owns these patents, it doesnt seem like we will ever get a true successor to the original Ms except the cheap knockoffs from Unicomp (which actually feel even worse that the lexmark ones).  Anywho, don't want to make this about Model Ms and my wishlist about them.
Want to find a modern equivalent that has more features.
Offline pchatterjee
« Reply #16 on: Sun, 29 December 2013, 02:04:29 »
Yeah that's what I figured.  Just to let you know I have had/have both Matias' (quiet and non quiet  too) -- and I dislike them compared to the Apple AEK II (which I like quite a bit, the white/cream alps are an awesome switch).
Good to have what I have researched so far or bought confrimed.
Offline pchatterjee
« Reply #17 on: Sun, 29 December 2013, 02:07:08 »
This is the conclusion I had come to as well.  Trying to figure out if the backlight is important to me.
I would really like a metal case which neither of these offer.  So far thinking WASD greens and find some metal caps from Feng.
Didnt like the look of the keycaps on the Ducky Pro G2 even thought the keys are PBT doubleshot.
Offline bazemk1979
« Reply #18 on: Sun, 29 December 2013, 02:12:19 »
who told you that the keys are PBT doubleshots?
Offline terran5992
« Reply #19 on: Sun, 29 December 2013, 07:23:46 »
Ducky pro g2 are PBT dyesub but not doubleshot
Offline jabar
« Reply #20 on: Sun, 29 December 2013, 12:16:40 »
Metal cases are a premium. Even aftermarket ones are mostly TKL or 60% ones, unless that's what you want. The Shine 3 YOTD is a full CNC aluminum case but it doesn't come with Greens.
Phantom 7bit
Offline pchatterjee
« Reply #21 on: Sun, 29 December 2013, 13:16:54 »
Looked at these do you know where they are still available?  They are all out of stock at mech keyboards I think.
How hard is it to replace these with MX Greens ?  that would be pretty close to ideal for me.  Is there a member who can do those things?  I have not really tried soldering if that's what it involves.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #22 on: Sun, 29 December 2013, 13:18:49 »
It's not very hard, but it involves soldering and finding enough greens in the first place. Check out the Professional Service Directory for people who could do it for you.
Offline Grendel
« Reply #23 on: Sun, 29 December 2013, 23:52:47 »
[..] do you want backlighting? If yes, Ducky has the most impressive array of options (colors and switches) as well as functionality.
Unfortunately Ducky's BL sucks arse for doing actual work or even gaming w/ it. Their low frequency PWM driven LED's are annoying as hell to me, couldn't stand it longer than a few minutes. Hopefully WASD did it right, ie. the way Deck Legends are -- current limiting. Or use a PWM frequency in the 8kHz range.
Until I find out I'll stick to my CM QFXT MX Green w/ GMK caps...
« Last Edit: Sun, 29 December 2013, 23:54:21 by Grendel »
- I'm game !
Offline pchatterjee
« Reply #24 on: Mon, 30 December 2013, 00:05:46 »
I have CM Quickfire Stealth with MX Greens now that I like -- just thinking about aesthetics at this point.  I like having the 10 key so I might pick up the stealth with the tenkey unless I can find something with MX green in a metalk case like some of the limited editions from ducky -- I can't find anything for sale that is MX Green + metal case.
Going to get the zinc metal keys from feng if he still has them (he's on holiday and not answering emails).
Offline jonjonjon
« Reply #25 on: Wed, 01 January 2014, 08:18:33 »
i'm planning on getting a shine 3 and noticed their latest firmware updates say it increases the PWM frequency. not sure if you still have the keyboard but if it's a DK9087 or DK9008 and doesn't have the lastest firmware you might want to give it a shot. what causes the lower frequency LED to be annoying? can you see the LED's pulsing?
http://www.duckychannel.com.tw/en/firmware_updater.html
01. Increased LED backlight PWM frequency.
Offline Grendel
« Reply #26 on: Wed, 01 January 2014, 20:42:00 »
Thanks, last time I checked that FW wasn't there. I'll give it a shot and see if it makes a difference. Stay tuned.
I can see the lights flicker in the corner of my eyes when looking across the monitor. This is very annoying since instinctively this is interpreted as movement  in your peripheral vision and you involuntary will look at it in most cases.
- I'm game !
Offline Grendel
« Reply #27 on: Wed, 01 January 2014, 20:51:39 »
Updated it, seems a little better but still very visible flickering to me. :(
- I'm game !
Offline Grendel
« Reply #28 on: Sun, 05 January 2014, 17:28:47 »
Addendum: after updating you have to reset the board (press & hold the two windows keys for 3s+) for the changes to take. After that the frequency does go up. Not high enough to eliminate stroboscopic effects, but definitely better.
Waiting for the CODE... :)
- I'm game !
« Reply #29 on: Sun, 05 January 2014, 17:42:34 »
Duscky that's better than Thorpe.
« Reply #30 on: Sun, 05 January 2014, 22:53:42 »
I prefer Thorpe ;)
