Author Topic: Painting keyboard?  (Read 2256 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Painting keyboard?
« on: Mon, 30 December 2013, 16:51:22 »
Ok, so I'm interested in painting my shine 3.... I want to use http://www.lowes.com/pd_416843-61158-11219-6_4294965076__?Ntt=plasti-dip%2B&UserSearch=plasti-dip%2B&identifier=Blue&productId=3816951&rpp=32
Would it be ok to use it on a keyboard though?
Re: Painting keyboard?
« Reply #1 on: Mon, 30 December 2013, 17:06:53 »
Yea.. it'll work fine..
lay down thin coats.. plasti dip can run pretty easily because it's very heavy..  consider getting the clear coat too if you want a shine..
Offline Photoelectric
« Reply #2 on: Mon, 30 December 2013, 17:19:35 »
Check out my painting thread here:
http://geekhack.org/index.php?topic=44191.0
I'd not advise Plasti-Dip until I see more successful testing.  See this:
http://geekhack.org/index.php?topic=49622.msg1158549#msg1158549
You can try some oil enamels (RustOleum Painter's Touch at Home Depot) or vinyl dyes (those come in sprays too, by VHT or DupliColor).
Offline C5Allroad
« Reply #3 on: Mon, 30 December 2013, 23:17:44 »
I'll try next month maybe....  It works well on wheels, so I though it might work well on a keyboard.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Mon, 30 December 2013, 23:29:40 »
Be sure to post picture :)
Offline C5Allroad
« Reply #5 on: Mon, 30 December 2013, 23:46:53 »
I have to wait for a paycheck lol.
