Author Topic: Where to get stabilizers/will they fit?  (Read 3461 times)
Offline xSpartanCx
« on: Thu, 02 January 2014, 17:20:54 »
I'm building a phantom and would like to make sure I'm buying the right thing. I want costar stabilizers, and have (I think) a 6.25x spacebar (It's an ANSI 1.25x set). I wanted to know if the costar stabilizers and cherry springs would work together, and if it would fit a 6.25x space bar.
http://www.wasdkeyboards.com/index.php/cherry-mx-stabilizer-spring-for-spacebar.html#ad-image-0
http://www.wasdkeyboards.com/index.php/cherry-mx-stabilizer-spring-for-2x-keycaps.html#ad-image-0
http://www.wasdkeyboards.com/index.php/cherry-mx-plate-mounted-stabilizer-clips-2pcs.html#ad-image-0
Offline xSpartanCx
Re: Where to get stabilizers/will they fit?
« Reply #1 on: Mon, 06 January 2014, 18:09:26 »
Basically, I want to know whether the spacebar spring is 7x or 6.25x and if I need anything more than just clips and a spring.
Offline Wildcard
  • When caffeine isn't enough
« Reply #2 on: Mon, 06 January 2014, 18:14:37 »
There's no spring. The MX switch under the space bar is what pushes it back up. People usually use a stiffer spring for the switch under the space bar to compensate for the weight.
The WASD site is a great place for costar stabs.
Regarding the space bar wire you can either buy one or some people bend them, if you search the threads you'll find this.
« Reply #3 on: Mon, 06 January 2014, 18:18:47 »
If your plate is ANSI 1.25, the spacebar is definitely 6.25 units wide.
In addition to 10 clips, 4 of the 2x springs, and a spacebar spring, you'll need 10 inserts, these:
http://www.wasdkeyboards.com/index.php/products/keyboard-parts/cherry-mx-keycap-stabilizer-insert-2pcs.html#ad-image-0
« Reply #4 on: Mon, 06 January 2014, 18:19:47 »
WASD calls the stabilizer wires "springs."
« Reply #5 on: Mon, 06 January 2014, 18:22:37 »
they should really change that
maybe....  " Down-force equilibrium conduit "...
oh yea.. pretty sexy.
Offline Wildcard
« Reply #6 on: Mon, 06 January 2014, 18:31:34 »
Well that's just confusing isn't it.
I'm going to continue bending my springs by hand....
Doesn't even sound right :)
Offline xSpartanCx
« Reply #7 on: Tue, 07 January 2014, 16:47:01 »
So the space bar wire/spring/whatever will fit 6.25x?
