Author Topic: Why are clear stems so thick?  (Read 8823 times)
Offline Pacifist
  • on hiatus
« on: Mon, 06 January 2014, 17:37:12 »
I was swapping keycaps on my 11900 modded partially with clears from mk.com.
They were a PITA to pull out, I even pulled one cap out with the stem and top still attached.
My stock blacks on the other hand were effortless to pull out.
So why did cherry make clear stems thicker now? An error or are they doing it on purpose?
Offline sth
  • 2 girls 1 cuprubber
Re: Why are clear stems so thick?
« Reply #1 on: Mon, 06 January 2014, 17:38:40 »
clear plastic is bigger than black plastic
Offline stancato9
« Reply #2 on: Mon, 06 January 2014, 17:39:46 »
I haven't soldered my clears yet but I have the exact same problem. It is very frustrating and seems it could do some damage to the caps or switch if you aren't careful.
Poker 2 - MX Red
« Reply #3 on: Mon, 06 January 2014, 17:40:43 »
See: SP DCS stems being so tight
probably something to do with their intention of the use of clears.
« Reply #4 on: Mon, 06 January 2014, 17:43:36 »
Yea, it's really weird.... they're very hard to put on and dislodge....
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #5 on: Mon, 06 January 2014, 17:43:59 »
That's what Cherry want you to think.
Offline Alessandro
« Reply #7 on: Mon, 06 January 2014, 17:47:19 »
Cherry conspiracy thread #5
That's what the Ergodox wants you to think.
« Reply #8 on: Mon, 06 January 2014, 17:49:58 »
I only have clears in the periphery keys on my Egdx, the rest are blacks..  Coincidence or Conspiracy thread #6 ???
Offline 1pq
  • Hipster Doofus
« Reply #9 on: Mon, 06 January 2014, 17:54:06 »
Why that combo?
I could have sworn you said somewhere you had blues...
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline Pacifist
  • on hiatus
« Reply #10 on: Mon, 06 January 2014, 18:01:22 »
But I put cherry clears on a cherry board with cherry keys....
Offline tbc
« Reply #11 on: Mon, 06 January 2014, 18:03:56 »
Anyone done clears with DSA?  Sounds scary tight.
Offline Alessandro
« Reply #12 on: Mon, 06 January 2014, 18:07:14 »
But that's what they want you to think! Why don't you get this man!? D:
« Reply #13 on: Mon, 06 January 2014, 18:11:43 »
Why that combo?
No, I said, cherry Blue is the most advanced, least perceptible friction switch..
My Egdx came with clears, and I put in blacks after, because I didn't feel like I need the tactile response. And I prioritized for low noise because my room became way more quiet after I turned off the harddrives.
Offline Grendel
« Reply #14 on: Mon, 06 January 2014, 21:03:55 »
Looks like it's on purpose, the clear stem mold is different -- if you look very closely at the stem of the clears you'll see little "bumps" (for the lack of a better word. Maybe "ridges" would work tho) on it that are most likely the cause for the clears to grab on to the caps. I have not found them on blue, red, brown, black, or green stems of the switches available to me. I tried to get a picture of one (there are four on a stem), hard to see but gives you an idea what and where to look for.
My clears from mk.com, in the CM Storm Switch Demo, and in a Deck Legend Frost all have them.
- I'm game !
« Reply #15 on: Mon, 06 January 2014, 21:17:48 »
Clears aren't any thicker.  I've taken calipers to them and they're the same thickness as other stems.  They have a different cutout on the front side and do have that little nub on the sides that Grendel mentioned though.
« Reply #16 on: Mon, 06 January 2014, 21:20:08 »
I didn't have any issue with DSA....
GMK keys have been a very tight fit however.
Offline daerid
    • Rossipedia
« Reply #17 on: Mon, 06 January 2014, 23:28:17 »
Clears were manufactured to be used in high-traffic and industrial applications, so the caps fit on tighter to avoid accidental removal.
Offline MJ45
  • HHKB Pro
« Reply #18 on: Tue, 07 January 2014, 09:26:50 »
I have measured them and found that they are thicker. But not by much like a half a thousandth (0.0005) or so. On the latest Phantom I built with new MX Clear switches when I tried removing also new GMK caps for some spring tuning, I pulled several switch tops off. After that I used some older looser caps until I found my spring choice (65g). The difference in the stem bumps and slightly thicker stems add up to some extremely tight cap fits. It would easy to damage switches if your not careful changing keycaps, especially the tight ones.
Offline damorgue
    • Personal portfolio
« Reply #19 on: Tue, 07 January 2014, 09:30:44 »
Those notches exist on other switches as well, but on different sides. Some stems have them facing the cherry logo while others have them facing the LED hole. I never got why this is. The only reason I ca think of is that some of the switches are designed to be used upside down, so that the LED is located at the upper end of the cap under the legend rather than at the lower part.
« Reply #20 on: Tue, 07 January 2014, 09:31:33 »
Mine were just as thick as either Blacks or Browns (it was a while ago, so I forgot) and a hair thicker than Blues.  They all fell within the normal thickness range for Cherry MX stems though.  The stem really isn't any thicker than any other Cherry MX stem aside from that little bump on the front.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #21 on: Tue, 07 January 2014, 09:32:51 »
Have you tried flipping the stem around? OuO
Offline Wildcard
  • When caffeine isn't enough
« Reply #22 on: Tue, 07 January 2014, 09:42:29 »
They keep saying it's length that matters, but it's really width.
Offline Grendel
« Reply #23 on: Tue, 07 January 2014, 13:33:02 »
Tactile Grey's have the same bumps, easier to see on those.
- I'm game !
Offline damorgue
« Reply #24 on: Tue, 07 January 2014, 14:36:27 »
You heard it here first folks.
Kmiller8's Insta-linear mod TM
So linear, there isn't even any actuation at all.
Offline Pacifist
  • on hiatus
« Reply #25 on: Wed, 26 February 2014, 17:50:56 »
Could we file them down?
Offline phoenix1234
« Reply #26 on: Wed, 26 February 2014, 18:25:39 »
Confirmed, at least on what I have.
Maybe it is an error or it is just production coefficient?
As far as I know and test, different Cherry MX stem has slightly different tightness with keycap :
Clear >> Blue ~ Brown ~ Black ~ Green >> Red
*Clear is very tight on OEM keycap sets
*Red is very loose on imsto side printed keycap set
It's just my personal test on 4 keycap sets:
+ 2 Cherry imsto Keycap sets (side printed and dye-sub)
+ 1 Cherry original set
+ 1 OEM WASD keycap set
+ 2 OEM Filco stock set
However, don't quote me on this because maybe Cherry has many different production lines and molds.
« Last Edit: Wed, 26 February 2014, 18:27:10 by phoenix1234 »
I like linear switches
« Reply #27 on: Thu, 27 February 2014, 05:25:40 »
I have tested a PBT DSA key on a Cherry clear switch ... and then decided to NOT use it for my keyboard build. It is scary tight.
