Author Topic: Would this be useful for regular work with small components?  (Read 3455 times)
Offline balanar
« on: Wed, 08 January 2014, 20:29:01 »
Found this on Kickstarter and was curious whether those who regularly work with small components might find it useful:
http://www.kickstarter.com/projects/2065435222/pcbgrip-electronics-assembly-system
Or would any decent set of helping hands be sufficient?
Offline Input Nirvana
Re: Would this be useful for regular work with small components?
« Reply #1 on: Wed, 08 January 2014, 21:30:15 »
Very, very cool, probably somewhat specialized in use. I would definitely use it.
Seems that it may be very high quality, but my opinion is that pricing is about double what market would bear. Kick down the quality (mostly because that high degree of precision quality isn't usually needed) and get the price down to a point that more people would purchase it.
Oh wait. That's what China is for.
Wait 6 months-1 year and get similar for $29.
« Reply #2 on: Wed, 08 January 2014, 21:33:45 »
The panavise PCB holder which isn't quite that fancy was recently on sale for less than $30
Offline damorgue
    • Personal portfolio
« Reply #3 on: Wed, 08 January 2014, 22:06:32 »
Although it looks neat and kind of useful, at 130CAD for the most basic kit I would say that it is a bit over the top. I don't have enough problems soldering PCBs that I could warrant such an expense. They target diy'ers and small scale production, but ordering machine soldered boards isn't that expensive when compared to this.
« Reply #4 on: Wed, 08 January 2014, 22:38:41 »
But it IS very cool :)
Offline Oobly
« Reply #5 on: Thu, 09 January 2014, 00:57:38 »
A bit of overkill, I'd say. I'd probably use one if I had one, but I use one of these instead:
A lot cheaper and does essentially the same job, just a bit less stable. Works for me.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #6 on: Thu, 09 January 2014, 01:08:24 »
i got one of these for $2.50  at harborfreight
« Reply #7 on: Thu, 09 January 2014, 03:54:49 »
I too have one of these - it has proven invaluable many times.
Although something a bit more substantial would be nice :)
« Reply #8 on: Thu, 09 January 2014, 06:13:08 »
If you bolt it down.. it will be quite substantial.
« Reply #9 on: Thu, 09 January 2014, 08:39:01 »
A seller on flea bay has helping hands with several other holding attachments, and bolted to a ceramic board so you can solder, use a torch for jewelry…very neat setups.
« Reply #10 on: Thu, 09 January 2014, 15:37:38 »
Nowhere to bolt it.
And the alligator clips are a bit weak on mine.
« Reply #11 on: Thu, 09 January 2014, 15:55:33 »
Nowhere to bolt it.
alligator clips?
I just use duct tape
« Reply #12 on: Thu, 09 January 2014, 16:33:44 »
Nowhere to bolt it.
alligator clips?
http://simple.wikipedia.org/wiki/Alligator_clip
Maybe you call them something else.
Offline erest
« Reply #13 on: Thu, 09 January 2014, 23:02:13 »
Thats a really cool looking setup,but the price! :eek: Like some other people have noted in the thread, if they brought the cost down to something like 30 bucks i would consider getting one but not until then.
Offline damorgue
« Reply #14 on: Fri, 10 January 2014, 03:20:03 »
alligator clips?
And speaking of alligator clips and duct tape, I have always used them together. Alligator clips ahve a tendency to damage what they are holding, in particular the insulation of wires. Just put some duct tape on both of the jaws and they will still clamp down enough to hold cables and PCB's but without damaging them. Sort of trivial but I have found it useful.
« Reply #15 on: Fri, 10 January 2014, 04:38:45 »
alligator clips?
smarts.
« Reply #16 on: Fri, 10 January 2014, 04:42:26 »
alligator clips?
The springs in my alligator clips are pretty much borked - I'm lucky if they will grab onto anything.
