Author Topic: Dell UltraSharp U2412M $260 @ Newegg  (Read 3060 times)
Offline hungryfingers
« on: Sat, 11 January 2014, 19:46:21 »
Short-term promo. I like this monitor a lot.
IPS, LED backlit, 8ms refresh, and a kind of weird resolution at 1920x1200 (16:10) that never bothered me.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824260047
Re: Dell UltraSharp U2412M $260 @ Newegg
« Reply #1 on: Sat, 11 January 2014, 20:12:33 »
Good deal for people (like me) who prefer 16:10 to 16:9.
« Reply #2 on: Sat, 11 January 2014, 20:18:23 »
Don't like these as much as the older model but I've been using then for a while.
And 1920x1200 ftw!
I despise 1080 resolution.
Offline tobr1an
« Reply #3 on: Sat, 11 January 2014, 20:46:39 »
I thought this been 229? Like yesterday.
« Reply #5 on: Sun, 12 January 2014, 14:01:23 »
this is the dithering panel correct?
the 6bit.
I thought IPS panels were 8bit, and if they used dithering you could get 10bit.
and TN panels are 6bit that can get up to 8bit with dithering.
Online tp4tissue
« Reply #6 on: Sun, 12 January 2014, 14:29:21 »
the 6bit.
no, there are 6bit ips-es  i recall this is one of them.
Offline missalaire
  • Great Finder of Great Finds
« Reply #7 on: Sun, 12 January 2014, 15:31:12 »
Yes, it was lower recently.
« Reply #8 on: Sun, 12 January 2014, 17:20:14 »
the 6bit.
According to an article I found, it's an e-IPS panel and is indeed 6bit native.
TFTcentral says the panel is a LG LM240WU8-SLA2
Online tp4tissue
« Reply #9 on: Mon, 13 January 2014, 01:21:10 »
the 6bit.
dithering makes the screen just a tad blurry... not the end of the world though.. for this price... it's pretty solid.
