Author Topic: Best keyboard for ~$50  (Read 5684 times)
Offline BADBADNOTGOOD
« on: Tue, 14 January 2014, 15:47:29 »
I know that there are not many mechanical keyboards in this price range but I just need something cheap with nkro for occasional gaming.
I am thinking about the Sidewinder x4 or Ducky 1087 with ducky green alps.
Thoughts/suggestions?
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Best keyboard for ~$50
« Reply #1 on: Tue, 14 January 2014, 15:48:03 »
not sure if actually BBNG or just BBNG fan.
« Reply #2 on: Tue, 14 January 2014, 15:48:14 »
QFR
« Reply #3 on: Tue, 14 January 2014, 15:48:39 »
If you wait, you can get a QFR for $55-60. Definitely NOT the 1087XM. I think that is the lowest quality board I've ever owned.
« Reply #4 on: Tue, 14 January 2014, 15:51:02 »
For your sanity, avoid that ducky. I own one, it's a piece of junk, honestly. You should only buy one for switch harvesting.
Used QFR is like $50, get one of those.
Offline missalaire
  • Great Finder of Great Finds
« Reply #5 on: Tue, 14 January 2014, 15:51:39 »
You'll most likely have to wait for a good deal to come up for a Cooler Master Quickfire Rapid or one of the Rosewill keyboards if you want to go for a brand new, mechanical.
« Reply #6 on: Tue, 14 January 2014, 15:51:51 »
an old cherry g80
« Reply #7 on: Tue, 14 January 2014, 15:52:54 »
How does it compare to the Noppoo and the KeyCool that are also in that price range?
« Reply #8 on: Tue, 14 January 2014, 15:55:02 »
Never owned or typed on either one so I have no idea.
Offline johndavis33
« Reply #9 on: Tue, 14 January 2014, 16:20:29 »
Model M
Lucky find at goodwill
QFR or Rosewill sale
Something with alps on Ebay
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
« Reply #10 on: Tue, 14 January 2014, 17:10:38 »
A KeyCool 87 is fine - there are a couple of reviews of them in the Reviews section.
PBT keycaps too, at least mine has.
Offline fourzeropooh
« Reply #11 on: Tue, 14 January 2014, 17:39:52 »
TT meka spanish edition was $27 shipped new a month ago. But it had spanish letters and the super WTF layout.
Offline 1pq
  • Hipster Doofus
« Reply #12 on: Tue, 14 January 2014, 21:51:44 »
an old cherry g80
+lots. Old switches almost always feel better than new ones.
Also, it you like BS, you can pick up Model Ms pretty cheap these days--most of them go for about $60 but every once in a while they go for a bit less.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline Pac Caps
  • Its almost a pallindrome
« Reply #13 on: Tue, 14 January 2014, 22:37:22 »
an old cherry g80
I saw an IBM 122 M for $35 Free Shipping on Ebay. Add on a $5 Pro Micro and you have a keyboard.
Want to be a cap maker
« Reply #14 on: Tue, 14 January 2014, 22:47:41 »
FWIW I was able to pick up 2 Model M keyboards for under $40.
Both needed cleaning, and combined I have only one set of keycaps, but both boards work fine.
Offline gameaholic
« Reply #15 on: Tue, 14 January 2014, 23:18:11 »
an old cherry g80
Pro micro?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline Pac Caps
« Reply #16 on: Tue, 14 January 2014, 23:28:14 »
an old cherry g80
Pro micro?
$5 Chinese Teensy knockoff that uses ardunio. Works with soarers.
Offline Badwrench
  • ummmm.....I forgot
« Reply #17 on: Tue, 14 January 2014, 23:43:24 »
As stated before, the QFR for $50 to $60 is a great way to go.  If, however you want to buy new, this is not too bad of an option:  http://www.monoprice.com/Product?c_id=114&cp_id=11401&cs_id=1140102&p_id=9433&seq=1&format=2  Monoprice mechanical with MX Blues for $58.
« Reply #18 on: Tue, 14 January 2014, 23:47:54 »
for $50, you don't have a choice..
QFR....
Offline BakerMan1971
« Reply #19 on: Wed, 15 January 2014, 09:06:11 »
I can vouch for the Keycool 87, the quality is excellent (I have the 87II with purple backlighting along with 1 gaming buddy who also raves about his board).  Another friend of mine has the Keycool 87 Rainbow board and is quite giddy about the whole thing.
I came from a sidewinder x4 which was great, but nothing compared to the keycool, if that helps with the decision.
Good luck, the advice on here is second to none.
Offline AKIMbO
  • HHKBro
« Reply #20 on: Wed, 15 January 2014, 09:37:09 »
CM QFR is a very solid, quality board that you cannot go wrong with. Rosewill is good too.
| KBD75 (box reds)
Offline gameaholic
« Reply #21 on: Wed, 15 January 2014, 09:42:23 »
an old cherry g80
Pro micro?
link plz
Offline vivalarevolución
« Reply #22 on: Wed, 15 January 2014, 13:29:22 »
I would ay Model M, but you are looking for NKRO, so that is not an option.
Offline JPG
  • Model F is my new passion!
« Reply #23 on: Wed, 15 January 2014, 13:32:13 »
Best simple choice: get a cheap cherry keyboard
Other good choice but harder: Get a cheap model F, make a 10$ converter and you are set!
But the cheap cherry keyboard is probably the more convenient option.
