Author Topic: Another Monitor Problem - weird discolorations  (Read 4490 times)
Offline berserkfan
« on: Fri, 17 January 2014, 21:58:28 »
Hello Everyone!
Once again I come forward with a monitor problem. These things don't ever seem to stop!
My Dell monitor has suddenly become discolored, sometimes with flashing red lines, sometimes with unstable and discolored image, and sometimes it fails to power on entirely. The power button may be lighted but the screen is all black.
Would love to have anyone give advice, as I can't use it at all and it is off warranty.
Also attached pictures of what the same background (New Zealand) looks like on my good monitor. The monitors used to be exactly the same color. That way you can see that my camera isn't the one creating distorted colors.
Offline PointyFox
Re: Another Monitor Problem - weird discolorations
« Reply #1 on: Fri, 17 January 2014, 22:10:28 »
Looks like a damaged/loose cable at first, but the 4th picture with digital artifacts and mention of lines indicate that your GPU is starting to go.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Fri, 17 January 2014, 22:12:42 »
hook another monitor up and see what happens
if it does the same thing time to invest in a new video card, if not and works fine you know what else you have to buy......
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Photoelectric
« Reply #3 on: Fri, 17 January 2014, 22:13:02 »
Agreeing with PointyFox's evaluation
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Fri, 17 January 2014, 22:13:52 »
right............check your cable first
i had a loose cable do the same thing one time
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 17 January 2014, 22:22:07 »
Could also be something as simple as a jacked hue setting. I can come pretty close to the bad image by manipulating image hue in my nvidia control panel with the good image. Check that, if monitor does same thing on other GPU make sure it's not bad setting in monitor osd... check with other display on same gpu port to rule that out.
Online tp4tissue
« Reply #6 on: Fri, 17 January 2014, 22:49:21 »
lots of people have a family of bunnies in their gpu and they don't even know it..
check that first... detach and reseat the sink
Offline berserkfan
« Reply #7 on: Sat, 18 January 2014, 05:35:40 »
just wanted to say, thanks everybody! These are very workable solutions for a clumsy oaf like Gutz. I can (probably) not destroy my entire system while sucking the dust out of my computer, and I can swap cables and output slots (whatever you call that) to try different monitors on the graphics card. Hopefully my next post will be a positive one and nothing to do with "my system is dead, help!"
Online tp4tissue
« Reply #8 on: Sat, 18 January 2014, 15:08:17 »
dust can get "under the heatsink too" where the ram and resistors and stuff are.. and enough dust+ a little moisture, can cause minor shorts// capacitance..
So that's why it's advisable to always re-seat the sink once a year or once every 6 month if you got high use.
Offline berserkfan
« Reply #9 on: Sat, 18 January 2014, 20:15:34 »
Thanks for the great explanation, tp4! I opened my computer, and discovered a bunny warren complete with granddad bunny and lots of babies. I think I saw bunnylake in there as well, lurking in a corner. It's been several years since I opened this computer.
Fortunately, after a vacuuming (and no reseating of heat sink, because I really dare not mess with these things knowing I'm such a klutz), the problem vanished! THANK YOU ALL!
Online tp4tissue
« Reply #10 on: Sat, 18 January 2014, 20:40:24 »
Perhaps you could watch a few youtube videos on the subject and work up the courage...
You will need a small tube of thermal grease after you've cleaned the heatsink..
that's pretty much the only "item" that you'll need to purchase.
Offline berserkfan
« Reply #11 on: Sun, 19 January 2014, 11:15:07 »
Looks like I have something new added to my list of must-do things.
Thermal grease, heh, for someone like me with no knowledge of these things, it's something new. And grease doesn't sound good. It sounds like something that gathers bunnies like nobody's business...
