Author Topic: Which Stabilizer do you like the best and why?  (Read 14558 times)
Offline Kamen Rider Blade
« on: Fri, 24 January 2014, 19:58:20 »
Personally I don't have enough experience to say I've tried all the major variants.
From what I can tell Cherry Stabilizers are very nice because if you bust the plastic tabs, you can always buy replacements and insert them
Any stabilizer system that is easily and cheapily user fixable is a thumbs up IMO.
No clue about Costar Stabilizers.
Some of the cheapo rubber dome keyboards have ok stabilizers, but I don't like how the clip for the wire is built into the frame of some keyboards, if you bust the clip, you have nothing to mount the wire.
Any thoughts from those who have more experience?
Offline The_Beast
  • I like wood ಠ_๏
Re: Which Stabilizer do you like the best and why?
« Reply #1 on: Fri, 24 January 2014, 19:59:42 »
Like everything keyboard, everything is preference
layouts, stabilizer type, switch type.......
« Reply #2 on: Fri, 24 January 2014, 20:00:15 »
WRONG. Ask TP for the correct answers.
Offline Pacifist
  • on hiatus
« Reply #3 on: Fri, 24 January 2014, 20:01:51 »
Hasn't this kind of thread been made multiple times?
« Reply #4 on: Fri, 24 January 2014, 20:08:39 »
Why I'd never....
Offline Grim Fandango
« Reply #5 on: Fri, 24 January 2014, 20:41:47 »
It is all preference. I tried both, I like Costar stabilizers better. But I can understand both sides to the argument. The Costar stabilizer are a little more hassle if you want to replace the keycaps, and they are kind of loose and kind of rattle a little (at least they do on the boards I have used). However, they do sort of have that more "snappy" feel that is more consistent with the rest of the keyboard. Cherry stabilizers on the other hand are in comparison not quite as snappy (some call them "mushy" which is not entirely fair) but they have a more solid feel when pressed.
Offline HPE1000
  • Keycap Paparazzo
« Reply #6 on: Fri, 24 January 2014, 20:48:56 »
Why are you starting all these discussion threads that have been done over and over and over again?  :-X
Google or search the website first :confused:
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Fri, 24 January 2014, 20:51:29 »
Best is costar, no questions asked
Offline HPE1000
  • Keycap Paparazzo
« Reply #8 on: Fri, 24 January 2014, 20:59:26 »
Quite an ignorant statement to make if you aren't just messing around.
Both have their ins and outs...
« Reply #9 on: Fri, 24 January 2014, 21:03:08 »
The only real advantage to Cherry-style is ease of removal...
In terms of function... Coaster is just smoother.. less surface area to grind against each other.
Offline HPE1000
  • Keycap Paparazzo
« Reply #10 on: Fri, 24 January 2014, 21:06:38 »
It also makes less noise and doesn't wobble nearly as much. I am very neutral on which I prefer.
« Reply #11 on: Fri, 24 January 2014, 21:10:20 »
the wobble is good, it means less friction
noise... that's probably cuz less downward energy / momentum is lost with Costar stabilizers.. vs Cherry where because more energy is lost to friction....
« Reply #12 on: Fri, 24 January 2014, 21:18:14 »
I dislike costar because of those evil little inserts.
« Reply #13 on: Fri, 24 January 2014, 21:18:29 »
NO STABILIZERS
« Reply #14 on: Fri, 24 January 2014, 21:19:58 »
I think of them as minicons  and when combined, they power up my spacebars..
---yea... I went there.....
« Reply #15 on: Fri, 24 January 2014, 23:52:31 »
I find Cherry slightly more mushy than Costar, but not so much that it bothers me.
Cherry are easier to swap keycaps, provided the longer keycaps (especially space and right Shift) are perfectly straight.  Cherry are not very forgiving for bent keycaps.
Costar are more forgiving of misaligned keycaps, but are a lot more fiddly to swap keycaps, especially if the inserts are really tight.  I've nearly lost a couple of finger nails trying to get them out.
Offline phoenix1234
« Reply #16 on: Sat, 25 January 2014, 00:13:06 »
Costa:
Pros: high level of responsiveness, smooth
Cons: harder to maintain, replace keycaps, easy to get stuck with incompatible keycaps
Cherry:
Pros: easy to replace keycap, easier to maintain
Cons: lower level of responsiveness
How to overcome the weaknesses of both Costa and Cherry?
For Costa stabilizers:
Step 1: Buy a bunch of backup stabilizers inserts, clips ... from WASD to backup just in case you lose them
http://www.wasdkeyboards.com/
Step 2: Lube the stabilizers with High Viscosity lube like Mechlube 1 from Elitekeyboard
http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
Step 3: Use Teflon tape to buffer when you have incompatible keycap stems (like SP DSA spacebar) but don't forget to put the inserts as close as possible to the keycap
For Cherry stabilizers:
Step 1: Lube the stabilizers with Low Viscosity lube like Mechlube 2 from Elitekeyboard
http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube_2
Step 2: Use Teflon tape to buffer when you have loose keycap stems
Step 3 (optional): Clip the stabilizer
I like linear switches
Offline PolaBurrr
« Reply #17 on: Sun, 26 January 2014, 15:57:48 »
I have used primarily costar stabilizers on all my keyboards, but I do get kind of annoyed at how often the larger keys rattle. Even after lubing them. I had to resort to the tape trick on my spacebar, but have yet to do it on the other keys. For those who use cherry stabilizer boards on a daily basis, do you find any high pitched rattling after long periods of use?
Offline moonexe
« Reply #18 on: Sun, 26 January 2014, 16:48:30 »
So the little feet or whatever that you cut off... What is their purpose to begin with?
G80-3000, MX brown           -           Filco Majestouch 2 HAKUA TKL+TK, MX brown, JIS Layout
Offline Pacifist
  • on hiatus
« Reply #19 on: Sun, 26 January 2014, 16:49:01 »
so it doesn't hit the pcb at full force and dampens it
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #20 on: Sun, 26 January 2014, 16:52:07 »
Cherry PCB mount iz da best!!  :thumb: Don't have to mess with those silly plastic inserts and they feel right.
« Reply #21 on: Sun, 26 January 2014, 16:55:58 »
Am I the only one around here who doesn't feel any difference between stabilizer brands?
Offline moonexe
« Reply #22 on: Sun, 26 January 2014, 16:59:53 »
Well, my cherry stabilizers do feel a little different from the other keys, but nothing that would bother me during use... And I use shift for caps. :p
I have nothing to compare, though. I accept donations. :rolleyes:
« Reply #23 on: Sun, 26 January 2014, 17:13:18 »
I use costar for spacebar (partly because getting wires is like impossible. I think every custom bent wire I've ever tried has not worked at all) and cherry for the rest of the modifiers.
But it's really just a matter of perference. They both have their plusses and minuses.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #24 on: Sun, 26 January 2014, 17:20:42 »
Costar feels a bit better, but I really don't think the difference is very significant - both works perfectly fine for me.
« Reply #25 on: Sun, 26 January 2014, 17:24:55 »
I find the whole "Costar is more work to replace the keycaps" a bit of a non-issue for me personally.
While they are a little more  hassle, I do not think it is that annoying or that much more work. I also do not often take them off and put them back on. Maybe once every 6 months to clean the keyboard or something.
« Last Edit: Sun, 26 January 2014, 17:27:25 by Grim Fandango »
Offline moonexe
« Reply #26 on: Sun, 26 January 2014, 17:30:28 »
But a lot of people here seems to be cycling through keycap sets every hour or so. :p
« Reply #27 on: Sun, 26 January 2014, 19:41:47 »
I don't feel that much difference, not enough to make me prefer one over the other based on feel.
In fact on a blindfold test I probably would not be able to feel the difference between a good Cherry and a poor Costar.
Offline PolaBurrr
« Reply #28 on: Sun, 26 January 2014, 21:32:36 »
except for the rattle/wobble! lol
« Reply #29 on: Sun, 26 January 2014, 21:56:47 »
Maybe.
Offline yasuo
  • spanengan puyeng newbie
« Reply #30 on: Sun, 26 January 2014, 22:01:11 »
Is Cherry clipping feel better? :)
Logitech MK220 Colemak DH
« Reply #31 on: Sun, 26 January 2014, 22:48:16 »
placebo
it's another "the koreans did it so it must be right"
Offline Dubsgalore
« Reply #32 on: Sun, 26 January 2014, 23:00:52 »
Pcb mount cherry stabs as of right now
Offline The_Beast
  • I like wood ಠ_๏
« Reply #33 on: Sun, 26 January 2014, 23:02:44 »
placebo
So wrong it's not even funny
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #34 on: Sun, 26 January 2014, 23:46:30 »
placebo
I would have to agree with the beast on this one.  Before Christmas I had my Das (costar), Filco TKL (costar), and a Ducky full size (cherry).  My wife is not really into mech boards.  She couldn't really care less either way what she typed on.  Although she does like her Filco with blacks.  I had her try the Ducky with reds and cherry stabs quick before I wrapped it up.  As soon as she hit the space bar she let out a little yelp and jerked her hands back like a big tarantula just crawled over the back of her hands.  This is zero exaggeration.  She definatly felt the difference and did not like it one bit.  Granted these weren't clipped.  She has however typed a bit on one of my WYSE boards that has cherry stabs but doesn't have the feet to clip.  Wasn't part of the mold as there is nothing on the bottom to even suggest that they had ever been clipped and she didn't mind those.
My personal feelings on this is I can't stand non clipped cherry stabs but clipped cherrys = Costar in terms of feeling.  The little bit of subtle difference between clipped cherry and costar stabs is very minimal.  I doubt I could tell the difference in a blind test.  But non clipped cherrys I could tell on the first key stroke.
Offline Wildcard
  • When caffeine isn't enough
« Reply #35 on: Mon, 27 January 2014, 00:49:21 »
Costar stabs. I think they feel the most solid of all MX stabilizers. I've been changing caps on Costar for so long I've got a good system down. I much prefer a solid stabilizer with little wiggle room.
Offline Polymer
« Reply #36 on: Mon, 27 January 2014, 01:16:55 »
Don't you have that backwards?  I don't think anyone feels Costar is more solid..they wobble and rattle a bit more.  People prefer them because they don't change the feel of the keystroke.
Offline yasuo
« Reply #37 on: Mon, 27 January 2014, 03:59:47 »
for spacebar i think both have same feel
Offline fuzzybaffy
« Reply #38 on: Mon, 27 January 2014, 05:57:32 »
Honestly... I prefer the Cherry stabilizers. People don't like them because they are "mushy", but that's exactly what I like about them. It's not that I actually want ALL my keys to be mushy, but I just like the contrast that having it on the modifiers gives, from the alpha keys.
« Last Edit: Mon, 27 January 2014, 06:58:21 by fuzzybaffy »
Offline highspeed
« Reply #39 on: Mon, 27 January 2014, 06:02:11 »
After using kbtalking race for over a year and now gone back to my noppoo choc mini(first version), i enjoy the spacebar in my noppoo better. Dont know which type it is though.
« Reply #40 on: Mon, 27 January 2014, 15:19:50 »
This really says it more than anything else - it is subjective.  What one person likes, another might loathe.  And yet another might be indifferent to.
Offline 66klaus
« Reply #41 on: Fri, 21 February 2014, 16:21:53 »
Where can i get/buy costar stabilizer for my keyboard?
I come from EU, therefore shipping three stabilizer isn`t that worth from US.
Offline yasuo
« Reply #42 on: Fri, 21 February 2014, 21:21:50 »
WASDkeyboards i think shipping is cheaper :)
Offline exitfire401
  • The Force is Re/\l
« Reply #43 on: Sat, 22 February 2014, 01:33:02 »
I prefer cherry. Costar feel a bit wobbly to me (at least in the 4-5 boards I've tried them on) compared to cherry. But hey, to each their own.
« Reply #44 on: Sat, 22 February 2014, 01:38:12 »
Lubed Costar is the way to go for me.  I have Cherry on my Pure, but Costar just feels more solid, smooth, and way less wobbly to me.  Cherry isn't bad, but it's isn't amazing either.
It's all personal preference, but the fact that there are mods to make Cherry feel more like Costar and not vice versa kind of tells you which is better in general.
« Reply #45 on: Sat, 22 February 2014, 02:07:31 »
There are also differences if you are making your own keyboard with Cherry MX switches:
PCB only: Cherry's PCB-mounted stabilisers is your only option. Two drill holes for mounting. Easy to remove and mount stabilisers and mod sliders.
Plate only: Costar-style stabilisers have simpler mounting holes than Cherry stabilisers. You could almost make the holes by hand.
If we are looking at not only Cherry MX switches but at keyboards in general, the gold standard is Topre: the stabiliser is built into the switch. Even the 1.75 keys are stabilised. Only the space bar has extra sliders.
Offline yasuo
« Reply #46 on: Sat, 22 February 2014, 02:20:47 »
Stepped caps lock is alternative without stabs :-X
i think so MX 1.75 need stabs,quite wooble :))
http://farm7.static.flickr.com/6175/6143967636_e425854552_b.jpg
unfortunately hhkb no stabs on 1.75
http://farm9.staticflickr.com/8044/8103019712_bc9fa4b3ee_h.jpg
Offline AuRinBei
« Reply #47 on: Sat, 22 February 2014, 16:08:34 »
I don't have much experience with Costar. I tried them on a Blackwidow one time, but I liked them. I much preferred them to the cherry stabilizers I had at the time, which were on a Ducky Shine and were very mushy when bottoming out. My current MX keyboard has much better Cherry stabilizers though. I don't know if they are as good as Costar, but they are not very mushy at all. They feel almost like the other keys.
Topre stabilizers are the best though, no question. They almost feel better than the regular keys.
87u || Poker 2
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #48 on: Sat, 22 February 2014, 17:58:33 »
PCB mount cherry stabs...
The best feel, easy cap switching, low noise, low wobble.
A Ghost From The Past
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #49 on: Sat, 22 February 2014, 18:01:12 »
The last two boards I've built have been my first foray into PCB mount stabilizers. I do like how easy it is to change caps, and the feel is fine if you clip them, but I've had a different experience regarding noise: they're quite loud and clicky, both on the way down and back up. I've fixed it by lubing in the right places, but if you had a plate that unfortunately can't be easily done once switches are all soldered.
