Author Topic: My blackwidow has a problem with the control key.  (Read 6830 times)
Offline Exothermic
« on: Thu, 30 January 2014, 18:40:59 »
I have a Razer Blackwidow Ultimate 2012, and the control key recently started to not work sometimes when I press it. I have no experience soldering things, and I want to know if there's a solution beyond replacing the switch within the keyboard. Thoughts?
Offline tricheboars
  • Keyboards are Important!
Re: My blackwidow has a problem with the control key.
« Reply #1 on: Thu, 30 January 2014, 18:47:15 »
does it feel funny when you push down on it? does it look funny if you take of the keycap? did you spill a little something maybe on your keyboard?
if there is a solution without soldering we need more info. you shouldnt be afraid of soldering though, it isnt very hard.  it just seems overwhelming when you first attempt to try it.
Offline Lu_e
« Reply #2 on: Thu, 30 January 2014, 18:50:53 »
Have the newest firmware? How long have you had it?
Its probably the switch but could be a circuit board trace as well. Both require taking it apart regardless... Being the keyboard it is, I would probably feel ok learning some things from it. Such as soldering switches, or trace repair if that is the case.
Then if you were to mess something up you could get a nicer keyboard :p
Just say NO to ABS keycaps
« Reply #3 on: Thu, 30 January 2014, 18:54:36 »
Solution to all Black Widow Problems:
Step 1:
Purchase Lighter Fluid
Step2:
Douse Black Widow in Lighter Fluid
Step3:
Light Match
Step4:
Incinerate.....
Step5:
Happiness !!!!
Step6:
Buy a new keyboard.
Offline Pacifist
  • on hiatus
« Reply #4 on: Thu, 30 January 2014, 19:13:03 »
Is it the left control? I remember seeing other people on reddit experiencing that problem. One guy just taped something between the ctrl and the last macro key and rebinded the macro to ctrl.
Other than that, open the board. Its either a dead switch (so just desolder and resolder new one) or the pcb may be damaged in an rare incident. But most likely the switch is dead
« Reply #5 on: Thu, 30 January 2014, 19:15:14 »
Don't you mean?
Step 1:
Step2:
Step3:
Light Match
Step4:
Incinerate.....
Step5:
Happiness !!!!
Step6:
Buy an ergo-dox
« Reply #6 on: Thu, 30 January 2014, 19:19:45 »
it's out of control?
Offline Exothermic
« Reply #7 on: Fri, 31 January 2014, 12:04:48 »
I did not spill anything on it, it is the left control, I have the latest firmware and drivers, it sounds normal, looks normal, feels normal. I did bind control to M5, but I didn't think about taping the keys together. I might try that. I have a friend that is pretty experienced in soldering, so if I need to, I've asked him to do it and he said he would.
Offline tricheboars
« Reply #8 on: Fri, 31 January 2014, 13:15:44 »
i vote you borrow that dudes soldering kit and do it yourself. learning to solder is a valuable skill in the world of geekhack. have him teach it to you at least when he works on it. and like others said if you mess up your black widow that is fine cause that board is ugly as sin.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #9 on: Fri, 31 January 2014, 22:23:55 »
Step 1:
Step2:
Step3:
Light Match
Step4:
Incinerate.....
Step5:
Happiness !!!!
Step6:
Buy a new keyboard.
I saw this coming when I clicked the title of this thread....
« Reply #10 on: Fri, 31 January 2014, 22:35:34 »
Don't you mean?
Step 1:
Step2:
Step3:
Light Match
Step4:
Incinerate.....
Step5:
Happiness !!!!
Step6:
Buy an ergo-dox
seems like ya'll r getting to know me...
Offline C5Allroad
« Reply #11 on: Fri, 31 January 2014, 22:53:22 »
Well, it's kind of known that you will throw away a board unless it was a ergo-dox.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Sat, 01 February 2014, 10:00:00 »
well.........at least you can use the other ctrl
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline C5Allroad
« Reply #13 on: Sat, 01 February 2014, 21:31:52 »
You can try pressing the switch housing to see if it will actuate.
Offline Exothermic
« Reply #14 on: Sat, 01 February 2014, 23:41:31 »
Well it does actuate sometimes. Just not every time. It's about 50/50, which is a serious problem when playing starcraft. Also I have a lot of things in wow bound to control+other stuff.
Offline C5Allroad
« Reply #15 on: Mon, 03 February 2014, 14:52:58 »
Drivers then?
Offline Exothermic
« Reply #16 on: Mon, 03 February 2014, 21:17:13 »
Drivers are all up to date and everything. As is the firmware.
Offline mapple
« Reply #17 on: Tue, 04 February 2014, 06:05:31 »
main problem with blackwidows  is with razer itself, they make them....
In God We Trust
