Author Topic: What Linux Distro do the Linux users of GH use?  (Read 1148253 times)
Offline esko997
  • Linux Lover
« on: Sat, 29 March 2014, 22:51:02 »
I'm using Arch at home and Ubuntu at work.
Whats the general GH Linux concensus?
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Re: What Linux Distro do the Linux users of GH use?
« Reply #1 on: Sat, 29 March 2014, 22:59:00 »
I primarily use Ubuntu with Gnome classic at home. At work I'm forced to use Windows. :(
I've tried most distros, and keep coming back to 'buntu, because I'm very familiar with it.
Offline Vibex
  • Love y'all
« Reply #2 on: Sat, 29 March 2014, 23:01:49 »
I use funtoo, and it was my first linux distro. I'm planning on trying arch some time soon on one of my spare computers though.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Sat, 29 March 2014, 23:06:43 »
Redhat at work, Windows at home.  If I did serious coding at home I would definitely have a linux install, but for browsing and chatting Windows does just fine.  In the past I've done dual boot setups at home with Windows + Ubuntu or Fedora, and ended up never booting into linux.
Offline esko997
  • Linux Lover
« Reply #4 on: Sat, 29 March 2014, 23:07:25 »
Cant go wrong with Ubuntu, was my first Distro and still use it daily.
Been meaning to try funtoo, whats the longest you've had an install for?
« Reply #5 on: Sat, 29 March 2014, 23:08:20 »
Ubuntu at the moment, but all new servers are created with CentOS and I'm trying to find excuses (and time0 to upgrade Ubuntu servers to CentOS.
Offline esko997
  • Linux Lover
« Reply #6 on: Sat, 29 March 2014, 23:08:48 »
Redhat at work, Windows at home.  If I did serious coding at home I would definitely have a linux install, but for browsing and chatting Windows does just fine.  In the past I've done dual boot setups with Ubuntu and Fedora at home and ended up never booting them.
Do you like Redhat? I could never get into it -- the way everything is organized in the file system has always really bugged me.
Offline esko997
  • Linux Lover
« Reply #7 on: Sat, 29 March 2014, 23:10:04 »
Do you like CentOS. Have a few servers at work that use it but it drives me up a wall.
Offline Vibex
  • Love y'all
« Reply #8 on: Sat, 29 March 2014, 23:12:13 »
I only just jumped on the linux bandwagon, so I've been using it for about 4 months. Haven't really run into any problems. It's definitely worth a try, but if you don't have the time/patience to compile everything, then it's a horrible choice.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9 on: Sat, 29 March 2014, 23:12:47 »
Using Arch on my RasPi. Ubuntu at work when I have the choice. We have a lot of CentOS running in production at work, so I spend a lot of time with it. I want to spend some time with Linux Mint when I have a chance.
« Reply #10 on: Sat, 29 March 2014, 23:13:05 »
So far, yes.
So far I have one physical server running it, mostly just a file server.  And one VM with a few dev tools that I use for about 25% of my programming work.
What is it that drives you up the wall with CentOS?
« Reply #11 on: Sat, 29 March 2014, 23:13:14 »
Oh yeah, forgot to mention that my droplet on DigitalOcean is Ubuntu Server. :D
I tried CentOS, but again the familiarity pulled me back.
Offline hashbaz
  • Grand Ancient One
« Reply #12 on: Sat, 29 March 2014, 23:15:04 »
I'm ambivalent I suppose, as an end-user.  The systems folks manage everything so I can't speak to that end of it.  Mainly I love the vim + terminal workflow and tiling window managers, which will work on any distro.
Offline esko997
  • Linux Lover
« Reply #13 on: Sat, 29 March 2014, 23:17:06 »
So far, yes.
One example of my annoyence with CentOS is how they handle the network interfaces. I really like the /etc/network/interfaces file in Ubuntu. Everything in one place. In CentOS you have to go into that net-cfg folder, I think, something like that (network-scripts maybe?) and edit the different IPs, netmasks, etc for the interfaces. You then have to go to a seperate file and edit the gateway, broadcast. Like, I just dont understand why they did that, why not consolidate it all in one file? Its things like that that irritate me about CentOS. Just like, the whole file layout/hierarchy.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #14 on: Sat, 29 March 2014, 23:20:14 »
What distro are you using that you have to compile everything? Most linux distro have better package managers than "modern" OSes.
Offline esko997
  • Linux Lover
« Reply #15 on: Sat, 29 March 2014, 23:22:17 »
He's using funtoo -- yay compiling and c-flags!
Offline Vibex
  • Love y'all
« Reply #16 on: Sat, 29 March 2014, 23:22:39 »
Funtoo, it's a derivative of gentoo. It allows for optimized performance by only compiling the features of a program that you will actually use.
Offline oluf
  • formerly olaph
« Reply #17 on: Sat, 29 March 2014, 23:25:41 »
I used Red Hat from ~96 to 2002.. Debian ever since. Personally, not a fan of all the 'extra' stuff (...and their dependencies) many distros install.
Offline esko997
  • Linux Lover
« Reply #18 on: Sat, 29 March 2014, 23:28:30 »
A man after my own heart. dpkg master race reporting in.
Offline daerid
    • Rossipedia
« Reply #19 on: Sat, 29 March 2014, 23:34:14 »
Xubuntu here. I'm not a big fan of all the eye-candy that you get with K?ubuntu by default. I would use CentOS (I've got a VM because we have CentOS servers in production and gotta make sure stuff's compatible), but I tend to stay on the bleeding edge, and CentOS's packages are usually quite out of date (as they prioritize stability over having the latest features).
My main box is Win 8, run my *nix boxes under VirtualBox.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #20 on: Sat, 29 March 2014, 23:35:00 »
So far, yes.
CentOS is often considered to be the best for production machines. This is mainly because it is much slower to pick up recent software changes. This makes it more long term stable, but not having recent versions of software can sometimes be annoying. Eg: Python defaults to version 2.6 and yum depends on that version, so you can't upgrade the default python version or yum will break. There are ways around this, but this is the type of thing you have to deal with when using CentOS.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #21 on: Sat, 29 March 2014, 23:37:11 »
I thought I was crazy for using arch.  Thats Loco. :P
« Last Edit: Sat, 29 March 2014, 23:40:09 by swill »
Offline daerid
    • Rossipedia
« Reply #22 on: Sat, 29 March 2014, 23:51:04 »
Gentoo? psssshhh....
Offline esko997
  • Linux Lover
« Reply #23 on: Sat, 29 March 2014, 23:52:29 »
Lol, great strip. In all seriousness though, vim masterrace reporting in.
« Reply #24 on: Sat, 29 March 2014, 23:54:26 »
So far, yes.
I haven't had to worry about that yet.  As long as you remember to check "initialise interfaces at startup" or something, LAN connectivity is enabled at boot time (it is strange that it is not enabled by default).
Guess I'll cross that bridge when I come to it.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #25 on: Sat, 29 March 2014, 23:56:24 »
In the terminal vim is king. I usually use sublime text otherwise (but that's off topic)
Offline hashbaz
  • Grand Ancient One
« Reply #26 on: Sat, 29 March 2014, 23:58:12 »
I had this very strip hanging outside my office for a year or two.  One of the best xkcds ever, and that's saying a lot. :)
Offline Leslieann
« Reply #27 on: Sun, 30 March 2014, 01:35:12 »
I prefer Debian with Cinnamon, which Mint now offers.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #28 on: Sun, 30 March 2014, 01:58:21 »
I use Manjaro.
I also use i3 as my window manager.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline esko997
  • Linux Lover
« Reply #29 on: Sun, 30 March 2014, 11:30:12 »
I use Manjaro.
I'm really impressed with Manjaro. Been using Arch for ages, but I really like how they package it, still need to check it out.
Offline nuclearsandwich
« Reply #30 on: Sun, 30 March 2014, 11:32:31 »
Archlinux since 2008 and before that Slackware. Linux is only fun when it's hard and nothing works.
Offline esko997
  • Linux Lover
« Reply #31 on: Sun, 30 March 2014, 11:41:33 »
Love Arch, just wondering, why did you switch from Slackware?
Offline eddie
« Reply #32 on: Sun, 30 March 2014, 11:45:30 »
debian with gnome
« Reply #33 on: Sun, 30 March 2014, 12:13:37 »
It got to the point where having a package manager during daily operation was actually quite nice. Slackware's package manager only exists at install time. After that it's make && make install all the way.
Offline Smasher816
  • HHKB Master
« Reply #34 on: Sun, 30 March 2014, 12:18:29 »
Arch Linux!
Offline tipo33
  • "Ski"
« Reply #35 on: Sun, 30 March 2014, 12:26:20 »
I use debian, though I have considered trying arch as a learning experience.
KM4COL    R.I.P.  SmallFry
Offline wyatt8740
  • Machine code enthusiast
« Reply #36 on: Sun, 30 March 2014, 12:56:52 »
Arch on my iMac and Linuxmint (debian based) on my homebuilt computer. I use mint for my games mostly, because it's already got most of what games need. I use arch for programming. I use MATE (a GNOME 2 fork that is actually being maintained and developed) for both of them.
« Last Edit: Sun, 30 March 2014, 12:58:57 by wyatt8740 »
I don't usually collect things, but when I do, they're from the 70's, 80's, and 90's. My typing speed: 79 WPM
IBM Model M 1386303, 1987 / IBM Model M 1391401, 1993 / IBM Model M 59G7980, 1993 / Unicomp "Mini M" UT40E7A (modded), 2021 / Dell AT101W, 1994 (Black Alps) / Apple Extended Keyboard (Orange Alps), 1987 / Sun Type 5, unknown year (Rubber Dome)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #37 on: Sun, 30 March 2014, 13:02:38 »
This is a great thread. Love all the quality input and experience.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #38 on: Sun, 30 March 2014, 13:12:09 »
Kubuntu dual booted with Windows 7 on desktop.
Offline dante
« Reply #39 on: Sun, 30 March 2014, 16:00:52 »
Mint/XFCE
Offline CJNE
« Reply #40 on: Sun, 30 March 2014, 16:12:45 »
I use Arch Linux with awesome wm on the laptop, at work we have a mix of Ubuntu and CentOS on the servers.
OS X for my main workstations but i'm getting tempted now and then to run Linux on there as well, i really like Awesome and there are nothing quite as good for OS X.
HHKBP2 black and blank - HHKBP2-S white - Filco TKL Majestouch, MX brown - ErgoDox classic MX blue - ErgoDox Czarek case, MX clear and brown
Offline blackbox
« Reply #41 on: Sun, 30 March 2014, 16:15:57 »
Linux mint 16 with cinnamon here. Previously used fedora, aptosid, sidux, ubuntu and debian on my main pc.
The LAN table!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #42 on: Sun, 30 March 2014, 16:24:53 »
This is what I want to try.  Are you enjoying this setup?
Offline Protato_Tubby
  • people enthusiast
« Reply #43 on: Sun, 30 March 2014, 17:49:44 »
At home I dual-boot With Debian with Gnome 3 and Windows (Windows for most games, Debian for everything else). At school I'm forced to use Windows, despite my computing course demanding that we should have experience with more than one OS (Which consisted of us using a raspberry pi  with Raspbian for one hour Ughhhh - such a waste of time) which of course has been no problem for me, but for the majority of people in my Class has been difficult. First used Ubuntu at the age of 11 on an old laptop that was given to me by a relative. I think it's the reason that I'm so into computers now.
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #44 on: Sun, 30 March 2014, 23:17:57 »
I've been using Funtoo for the past 3 years. My current installs are both two years old, and still running excellent. I really enjoy Funtoo. Lately, I've been giving i3 a shot as my window manager. I'm really enjoying it, but it is taking some time to get away from my e17 workflow.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline blackbox
« Reply #45 on: Mon, 31 March 2014, 02:11:33 »
Absolutley. Works very smootly on this rugged laptop:
http://geekhack.org/index.php?topic=48024.msg1261952#msg1261952
The LAN table!
Offline sth
  • 2 girls 1 cuprubber
« Reply #46 on: Mon, 31 March 2014, 02:15:36 »
the only thing you learn by installing arch is arch... which is nice if you want to learn arch i suppose.
i use crunchbang for workstations and debian for servers... i like openbox and crunchbang comes out of the box with a decent font config so... that's pretty much my criteria right there. always preferred .deb distros for no particular reason but i'm mostly agnostic. use what you like, use what works... it's the beauty of linux.
Offline avtar
« Reply #47 on: Mon, 31 March 2014, 02:38:16 »
I use CentOS for servers. I've been trying Arch and i3 for my own computer at work but I'm probably going to go back to Debian Testing.
Offline jdeblese
« Reply #48 on: Mon, 31 March 2014, 04:23:28 »
Another vote for Slackware! Been using it for the past ten years and wouldn't dream of switching. I use enough odd software that I prefer that make && make install is the standard method.
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #49 on: Mon, 31 March 2014, 05:47:21 »
I used LinuxMint for my desktop
