Author Topic: Need Help with New SSD Drive  (Read 2953 times)
Offline Lastpilot
  • Power stance
« on: Fri, 25 April 2014, 20:27:09 »
Okay hi everyone.
I purchased a 840 Evo 250gb Drive and I've successfully cloned it using the Samsung software provided. I am running it now as my C drive and its working perfectly.
Running Windows 8.1
Problems:
-2 New drives also popped up
   -"System Reserved" Drive
   -"Data" Drive
How do I make these part of my new C drive?
Offline Frenir
  • HHKB Viking
Re: Need Help with New SSD Drive
« Reply #1 on: Fri, 25 April 2014, 20:49:38 »
Have you tried to defrag/trim the drive?
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Fri, 25 April 2014, 20:53:22 »
Shouldn't defrag an SSD.
Offline smknjoe
« Reply #3 on: Fri, 25 April 2014, 20:53:23 »
It depends on the partition structure, but if they are logical and sequentially "after" C (it looks like they may be) then you should be able to blow them away under Disk Management and then add the free space to your drive.
SSKs for everyone!
Offline smknjoe
« Reply #4 on: Fri, 25 April 2014, 20:55:35 »
Otherwise, I would boot off of a Linux distro with Gparted and modify the partitions that way.
...or leave them alone if you aren't comfortable doing it. It's not that much wasted space.
SSKs for everyone!
Offline Frenir
  • HHKB Viking
« Reply #5 on: Fri, 25 April 2014, 20:57:30 »
Thus why i put /trim after since it might be possible that he put an ssd and hdd in raid (although that would be stupid)
Offline smknjoe
« Reply #6 on: Fri, 25 April 2014, 20:57:46 »
...also make sure "System Reserved" doesn't contain your boot manager! :)
SSKs for everyone!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Fri, 25 April 2014, 20:57:55 »
System reserved contains the boot and recovery files, and should be left alone. Typically Windows does not assign this a drive letter so just remove the drive letter assignment in disk management. Not sure what is data, could be an EFI partition... if so this should also be left alone as it is essentially the disk file table. I would just remove the drive letter assignment on that and leave it as well.
Edit - brought up my server which I have EFI disk on and it matches in size so...
62484-0
« Last Edit: Fri, 25 April 2014, 21:03:54 by IvanIvanovich »
Offline smknjoe
« Reply #8 on: Fri, 25 April 2014, 21:08:26 »
I didn't notice that "data" was 100MB. I thought it was 1000MB. Ivan is probably right. Don't erase them. 100MB probably contains the MFT and 350MB is the default size for the boot manager since Win7.
SSKs for everyone!
Offline Lastpilot
  • Power stance
« Reply #10 on: Fri, 25 April 2014, 22:09:31 »
Alright thank you, I've went ahead and removed the drive assignment on the additional drives and everything is still fine.
Also, yeah for those that were curious, I am not running anything in RAID. Just using the SSD as a main drive and the other for storage.
I think that's a fix. I just wanted to make sure that having a "System Reserved" and "Data" drive wasn't something that needed my urgent attention. Since, of course searching "data drive" on google wasn't very helpful, lol.
Thank you everyone for your input!
Offline eth0s
  • Peace & Love
« Reply #11 on: Fri, 25 April 2014, 22:16:00 »
well, you resolved it, but I was going to say to ignore it.  Windows 8 always partitions off that ~348 MB of space for itself.  Some kind of glitch caused it to give drive names to the partitions though.  Must have to do with device driver.  Or MS hates Samsung.  W/e, the "geniuses" at Microsoft will eventually come up with a fix/ patch for this.  So don't do anything was going to be my advice.
