Author Topic: Cooler Master CM Storm QuickFire Rapid-I keyboard review video is up!  (Read 27825 times)
Re: Cooler Master CM Storm QuickFire Rapid-I keyboard review video is up!
« Reply #50 on: Sun, 15 June 2014, 04:39:51 »
HAHAHA.... wow why are all the Geekhackians on the offensive..   when did we take ourselves this seriously..
Don't feel bad Speakeazy....   you've just come in on an unlucky day...
But.. do remember,   if you're going to be pawning hardware using sex appeal,  you either do it shamelessly, or you don't do it at all..
this in-between thing falls between the uncanny valley and is confusing for the audience, making them think...   that's the last thing you want your audience to do...
Nothing against -Joanne- or you,  I'm sure you're good people..
Offline Speakeazy
« Reply #51 on: Sun, 15 June 2014, 04:43:44 »
Haha, thanks for the support. Well, I think she's doing pretty good. Almost 7,000 subscribers in 2 months. I think for the general tech community, she does provide informative and entertaining content.
What do you think about her Realforce Topre keyboard overview? We covered the 104UB, the 87U All-45g, and the 87U Silent
https://www.youtube.com/watch?v=kmP_oHcw_rM
Topre RealForce 104U dark grey caps on black | Corsair Vengeance K70 with MX Browns | (on the way) Keycool 108-keys keyboard with MX Clears and POM keys
« Reply #52 on: Mon, 16 June 2014, 22:42:37 »
I know you haven't been here long..   but... it's a general consensus that you do not ask TP4 about Topre...
Offline Speakeazy
« Reply #53 on: Tue, 17 June 2014, 03:06:46 »
Oh yikes! Well, that's good to know. Not one of his favorites, I suppose?
« Reply #54 on: Tue, 17 June 2014, 05:14:22 »
Not unless you ask him about an ErgoDox with Topre switches ;)
Offline timzen
    • http://www.mechanische-tastatur.de/
« Reply #55 on: Tue, 17 June 2014, 15:45:20 »
I would like to take this opportunity to shamelessly plug my german language Review of the Rapid-i.
http://mechanische-tastatur.de/cooler-master-quick-fire-rapid-i-test/
It also has some pictures and a video.
Thanks all for your attention.    ;D
Offline Sniping
« Reply #56 on: Tue, 17 June 2014, 16:26:25 »
Great review! I'm glad you guys took the time to make a lengthier video that covered everything. NCIX made an unboxing video on a Topre keyboard but everyone was complaining about the price in the comments because they didn't take the time to talk about the build quality, keycaps etc. and no one really understood why this keyboard is so expensive.
Offline JigsawSaint
« Reply #57 on: Sat, 05 July 2014, 22:35:37 »
First post, but not my first trip to the boards here.
I own about 22 different keyboards and about 40 difference mice.  I had been waiting for the QFR-i for a while.  I have 5 other CM keyboards and was looking forward to a tenkeyless keyboard from them with backlit keys.
The backlit is a nice addition and the obvious new feature, but the item that I didn't expect to change in their line-up and definitely didn't expect it to bother me as much as it has... the USB cable and plug-in location on the keyboard.
The normal location has been tucked away underneath the keyboard.  the new location is on the back of the lower assembly, right back corner centered beneath the 'scroll lock' key.
This wouldn't matter 'that much' if the cable that came with the keyboard had a 'straight' connector.  It doesn't.  It's a right angle connector that bends to the right.  In some scenarios, this cable can interfere with your mouse cable.  I would strongly recommend an aftermarket USB cable OR some nice cable mgmt.
If you are someone that uses any kind of keyboard tray or scenario such as a mobile cart, the way the new connector is situated may prevent you from using the device.  I really do with the connector was tucked away beneath, or at least centered on the back of the unit.
I did replace the keys with some nice white PBT keycaps.  The glow is brilliant (sorry no photos).  My only regret is that I haven't purchased buffer-rings yet.  I went with cherry mx brown switches for the workplace, and I tend to bottom them out.
