Author Topic: Geekhack Handwriting Thread and Fountain Pen Thread  (Read 643332 times)
Re: Geekhack Handwriting Thread and Fountain Pen Thread
« Reply #1000 on: Thu, 30 July 2015, 09:23:04 »
FWIW, all of the nib tuning specialists I've talked to and work with use Waterman inks. Solid inks and safe for any pen. I don't like their color palette though. Needs more purples and pinks.
Offline azhdar
  • Praise the AZERTY god
« Reply #1001 on: Thu, 30 July 2015, 09:24:42 »
The purple you wrote Tactile Zine adress with was hella cool !
Azerty Propagandiste
« Reply #1002 on: Thu, 30 July 2015, 09:27:51 »
Thanks! That's Rohrer and Klinger Scabiosa. I love the purple and it's an iron gall ink. It should last as long as the paper does so even if it gets wet, the ink will stay on the paper. Really good for say, putting addresses on zine envelopes ;)
Offline azhdar
« Reply #1003 on: Thu, 30 July 2015, 09:29:58 »
Oh really? I'll wet it tonight to see.
Offline Larken
« Reply #1004 on: Thu, 30 July 2015, 09:48:02 »
Very much agreed on both points. I usually ink new pens up with waterman inks; if the pen doesn't work, my next action nis usually to figure out what's wrong with the pen. Still like Florida Blue, but overall their color range is a little too boring. I still have several bottles of them which are now being neglected because I have gotten prettier inks.
| Ergodox #1 | Ergodox #2 |
Offline Larken
« Reply #1005 on: Thu, 30 July 2015, 09:56:18 »
I would like to get back to you for underhand writing if necessary, thanks again.
http://www.nibs.com/Left-hand%20writers.htm
#1 on that page is probably the most common way to do it, but keep in mind that there's no hard and fast rules. I've tried that for a while but didn't enjoy having to tilt my head to keep in line with the page. Imo comfort is key.
I write keeping the paper straight and the pen angled to the southwest (assuming the top of the paper is north), which doesn't fit any of the methods listed on the link, but it works very well for me.
« Reply #1006 on: Thu, 30 July 2015, 10:57:19 »
I know a lot who swear by Diamine too.  I love their inks :3  Although R&K iron galls are amazing especially Scabiosa like you use on your zine.
« Reply #1007 on: Thu, 30 July 2015, 11:15:06 »
I swear by Diamine bro <3
Offline genkidama
« Reply #1008 on: Thu, 30 July 2015, 14:04:56 »
I agree with you and I'll just take the suggestions I find as hints and see where I go with it.
On that list I'm totally a #3 and many many years ago I was a #2.
My finger training is over 9000!!!!
Offline BIZ!
  • It's gonna be great!
« Reply #1009 on: Wed, 05 August 2015, 19:45:46 »
Lamy Safari with the ink converter and Noodler's Kingfisher Blue is the way to go.
Ducky Shine 3 |  IBM Model M  | Razer Orbweaver  | ErgoDox Infinity
« Reply #1010 on: Mon, 10 August 2015, 13:01:44 »
Did it just get sexy in here?
Offline BlueNalgene
« Reply #1011 on: Wed, 12 August 2015, 18:38:33 »
A while back, there was some discussion about pH of inks here (see
Just be careful if your pen uses an ink sac. The acidic nature of Noodler's inks can ruin them very quickly. Should be fine for most pens though.
Has this happened to you? Have you tried Noodler's in an ink sac? If so that's perfectly fine but there's a lot of misinformation about Noodler's imo. I have tried it in an ink sac. It's fine. The thing with Noodler's Ink is that the maker is crazy and makes all of these really odd inks. For example he's got a laser proof ink. His conventional inks are perfectly fine, even in vintage pens. It's when you start messing with his weird property inks that weird stuff happens to pens and then people complain.
I ran an experiment when I left Baystate Blue in a pen (Lamy Al Star) for 4 months without cleaning it. Works fine and it wasn't that stained. Didn't melt or anything as you would be led to believe by reading for the forums.
This has not happened to me but I have read a post on Greg Minuskin's website claiming that a certain Noodler's ink does this. He is a well recognized nibsmith and pen restoration expert who had a pen sent with a messed up ink sac and was told they used Noodler's.
Like it was mentioned before, inks are all made differently, even if they're the same kind; meaning not all Noodler's will do this. Just proceed with caution.
Thanks for citing your source.  I googled the name and Noodler's and came up with this.  I also found this to be a rather interesting read.
I cannot claim that I know what is going on in these instances, and I don't know what the components of the inks in question are.  Please take my observations with a grain of salt.  There might be something to the claims that this ink can damage the pens with ink sacs.  If so, I doubt it is due to pH.  Most modern ink sacs are made of latex or rubber.  Other materials may have been used in the older 'vintage' pens that Mr. Minuskin works with, but I would not know what they were.  Latex and rubber are quite resistant to somewhat extreme pH values.  That is why we use latex and rubber gloves so often in lab.  They are damaged by other things though.
Consider the following: A sleep deprived grad student named BlueNalgene is working in lab wearing gloves.  Over the course of his sloppy work, he spills three chemicals on the gloves.  The first spill is concentrated hydrochloric acid, the second spill is concentrated nitric acid, and the third spill is tetrahydrofuran.  After each spill, he rinses the gloves off and continues his work.  If we look at each of the spills we would see the following.  The first spill (HCl) would not be visible.  The second spill (HNO_3) would leave the glove slightly orange on that spot. The third spill (THF) would leave a hole in the glove.
The first instance is a strong acid.  Latex is resistant to this, and would not be noticeably affected.  The second one is a strong acid and a strong oxidizer.  The oxidizer would react with some of the latex polymers to, in this case, discolor them.  The third is an organic solvent which does not have a pH.  Latex dissolves readily in this solvent, so it would be expected that it would completely destroy the polymers in the glove.
The point of my little thought experiment is that the hydrogen ion concentration in the solution should not be damaging the sac.  There are other things that might damage it.  While Mr. Minuskin's observation may be right about Noodler's, pH probably has little to do with it.  The pH would be reasonable to have inflicted the damage that Mr. Binder observed in the second link I provided by pitting metals.
To reiterate: I'm not saying the observation was wrong, just saying their chemistry was wrong.
Here is a nice source for chemical resistance of polymers used in gloves. PDF warning
for some background).  During that discussion, I offered to test inks and CPTBadass offered to donate some samples for my tests (see
Bulletproof Polar Brown is my every day ink, and it is the only ink I use to write my notes in my lab notebook.   I could run a pH test on it tomorrow if anyone would be interested.
I'm extremely interested. In fact, if you don't mind, could I send you some other inks? My everyday is Noodler's North African Violet.
I'd be happy to.  PM if you need me to give you my address again.  Testing with a pH strip would be difficult since the analysis is based on color change.  I will do them all at once on the pH probe.  It gives more precise results (+/- .01 pH unit).  But I will need ~2 mL to do that test, whereas the pH strip would only require 4 drops.
for that discussion).  Today I received samples from our good CPT in the mail, and I went about running tests.  This post is the outcome of that work.
The Samples
Four samples were procured from CPTBadass and one was supplied by the author.
Noodler's Baystate Blue - a vibrant royal blue ink
Rohrer & Klingner Scabiosa - an iron gall ink
Noodler's North African Violet - an intense violet ink
Diamine Soft Mint - an ink that appeared turquoise or aqua in the bulk solution
Noodler's Polar Brown - a somewhat rust tinged brown ink
Upon receipt, the samples were transferred to 20mL plastic scintillation vials.  The original containers' opening was too small to accomodate the probe used in the pH experiments.
1. Shake Tests
Method
Samples in scintillation vials were given a quick shake and observed for fluid and surface characteristics.
Results
InkObservations
Noodler's Baystate BlueInk left a thin layer coating the wall that persisted for a long time.  This thin layer did not show any detail of the plastic surface.  It produced bubbles,
Rohrer & Klingner ScabiosaInk left a very thin layer coating the wall that persisted for some time.  The layer highlighted plastic imperfections of the bottle by contrast.  It produced bubbles.
Noodler's North African VioletInk left a very thin layer coating the wall that persisted for some time.  The layer highlighted some plastic imperfections of the bottle by contrast.  It produced bubbles.
Diamine Soft MintInk did not coat walls.  Preferred cohesion and formed small islands of liquid on the plastic surface.  It produced NO bubbles.
Noodler's Polar BrownInk left a very thin layer coating the wall that persisted for a long time.  The layer highlighted plastic imperfections of the bottle by contrast.  It produced many/large bubbles.  Bubbles appeared to grow over time.
Discussion
The surface coating indicates that there was interaction with the walls of the container.  Since the plastic was either polyethylene or polypropylene, we expect the walls to be hydrophobic.  The inks which wetted the surface well interacted with the plastic surface.  Since bubbles were formed, we can assume that the interaction with the wall was due to surfactant in the ink reducing the surface energy allowing this prolonged contact.  The lack of coating in the Diamine sample suggests that it is highly hydrophilic.  The lack of bubbles suggests that no surfactant was added to the ink during manufacturing.
2. pH Test
Method
Samples were tested for hydrogen ion concentration using a Vernier pH probe connected to a computer running the logging software.  The probe was calibrated immediately before the experiment with a pH 4.00 buffer standard (Fisher - methyl alcohol, formaldehyde, and potassium hydrogen phthalate) and a pH 10.00 buffer standard (Fisher - disodium EDTA dihydrate, potassium carbonate, potassium borate, potassium hydroxide).  The lab temperature was 25C, and the standard pH did not need adjusted from the label value based on this temperature.
Results
InkpH
Noodler's Baystate Blue3.97
Rohrer & Klingner Scabiosa2.33*
Noodler's North African Violet4.60
Diamine Soft Mint4.00
Noodler's Polar Brown8.78
Discussion
The majority of the inks were slightly acidic in nature, and the Polar Brown ink was slightly basic.  The iron gall based ink was quite acidic.  This ink pH is marked with an asterisk(*) since the pH was not stable.  The value continually drifted downward, trending toward acidity.  The value used here was the observed pH value after 15 minutes of attempted stabilization.  After the experiments were complete, the pH probe was observed to be slightly discolored.  To determine how this effected the results, the standards were measured with the discolored probe.  The 4.00 buffer measured 3.74, and the 10.00 buffer measured 9.88.  This indicates that the results are probably skewed downward by ~0.25 pH units.  The results were not corrected for this error, since it would be difficult to quantify the error without much experimentation.  The probe was cleaned by soaking in 2% nitric acid for 30 minutes.  After this time, the probe was deemed 'clean' and returned to storage.
The results of this experiment should clear up a few misconceptions.  Notably, none of the inks in this less than comprehensive test were pH neutral.  Some sources discussed previously make claims based on the acid or base nature of inks based on brand.  Clearly, this is not a wise assessment.  The brand with three different inks in the test (Noodler's) showed a wide range of pH values.  Some outside sources suggest that acidic inks may damage pens.  Most of the inks tested were acidic.  No metal based tests were performed in this experiment, but this author believes that the correlation between metal pitting and acid content of an ink may be spurious.
3. Solvent Tests
Method
In this test, a small quantity of ink was deposited onto a strip of printer paper (Staples Brand) and partially submerged in solvent.  The ink was applied to the paper by smearing one or two drops from a disposable plastic pipette on the paper.  All labels on the samples were written in pencil.  The ink was allowed to dry then tested.  Most strips were folded so they would stand and set in a petri dish with the testing solution for five minutes. These tests were broken up into aqueous, organic, and chlorinated solvent groups to prevent unwanted reactions.
The wet papers were then taped to a rail in the hood to dry.
One strip was tested under a 18.4 W long wave UV lamp for one hour.  One strip was left as a control.
Results
Control
The numbers represent the inks Noodler's Baystate Blue, Rohrer & Klingner Scabiosa, Noodler's North African Violet, Diamine Soft Mint, and Noodler's Polar Brown respectively.  The inks were not applied evenly, and some spreading, especially in samples 3-5 was due to large drops.  The Polar Brown ink naturally feathers a great deal on this paper, and the Scabiosa and North African Violet inks showed some feathering.  The Soft Mint ink naturally spread, but did not show feathering.
Water
12345
minimal featheringfeatheringfeatheringspread and lossNo Change (NC)
Ethanol
12345
upward driftsome upward spreadupward driftupward driftedge reddening
Acetone
12345
some spreadNCfeatheringupward driftNC
Isopropanol
12345
upward driftsome featheringsome feathering/driftsome driftNC
Toluene
12345
upward driftNCminor driftNCedge reddening
Nitric Acid (~4%)
12345
gone, yellow edgealmost gone, blue edgealmost gone, green edgegoneNC
Hydrochloric Acid (~4%)
12345
gone, yellow edgealmost gone, blue edgealmost gone, green edgegone/upward driftedge reddening
Dichloromethane
12345
upward driftfeatheringupward drift/featheringminor upward driftyellow color separation
UV Exposure
12345
NCNCNCNCNC
Discussion
There is a great deal of information to be learned from these tests.  What we are looking at is actually a very rudimentary form of thin layer chromotography.  The paper acts as a stationary phase and the solvent as a mobile phase.  The mobile phase moves our eluent along the capillaries within the paper fiber matrix.  If we let this go for a long time, we would see the individual components separate from each other.  There are better methods to perform that experiment though, and it was not in the scope of this one.  The goal of the test was to determine the stability of the ink when in contact with the solvents.  In doing this, we can learn something about the character of the ink.
Different solvents have different polarities.  The polarity of a molecule being the concentration of electrons on one side of an atom and exposed protons on the other side.  We can relate these by a polarity index:
Since "like dissolves like" if something is moved or dissolved by more polar solvents, then the material must be polar.  So we can see that the Diamine ink is more polar than the quite nonpolar Baystate Blue based on what different solvents do to it.
The Polar Brown ink interestingly slightly drifts in both polar and nonpolar solvents.  If you look closely (probably not visible in pictures), you can see a yellow component separate out in nonpolar solvents and a red component separate out in polar solvents.  These colors moving out of the bulk drop only slightly affect a color change in the brown.
I chose the two acids to test here on purpose.  We would expect the HCl to react mostly as an acid, whereas the HNO3 would react as both an acid and a strong oxidizer.  Since both of the acids had similar effects on the inks, we can see that none of the inks oxidize easily - which speaks well for the permanence of these inks.
Future tests would include solvents with polarity index of 0.
The lack of change due to UV light is good, though this author would like to point out that this was not a very strong source.  Future tests should attempt to use more powerful sources such as a laser.
A. Errata
All solvents were obtained from Pharmaco Aaper with purity >99.5% except the nitric acid, which was obtained from Fisher.
All water used in the experiments was reagent grade, purified by reverse osmosis to resistance of >18Mohms.
I would like to thank CPTBadass again for his donations and my advisor for being out of town this week so I could do silly experiments like this without getting yelled at.
Thank you for reading, I would be happy to address any questions or comments you may have about this work.
« Reply #1012 on: Wed, 12 August 2015, 19:08:04 »
I approve and think these findings are highly interesting.  :thumb:
« Reply #1013 on: Wed, 12 August 2015, 21:09:17 »
Ok, with the inclusion of science, NOW it got sexy in this thread.
Offline VinnyCordeiro
« Reply #1014 on: Thu, 13 August 2015, 09:56:25 »
And the "pH neutral" myth of Noodler's inks is now shattered. Of course, the test should be made with many other inks, in special Noodler's Black. Other than that, it is good to see that BSB, which is sold as an "slightly alcaline" ink is, in fact, quite acidic.
Offline BlueNalgene
« Reply #1015 on: Thu, 13 August 2015, 12:16:50 »
Do you think the fountain pen network people would like this?  I don't have an account there and I don't know their culture.  People are welcome to crosspost this info there if they'd like.
« Reply #1016 on: Thu, 13 August 2015, 13:39:53 »
I think that this kind of post, strictly to the facts, would be welcome there. But I'm not as active there as I'm here, so I could be wrong.
« Reply #1017 on: Thu, 13 August 2015, 20:14:30 »
Just posted the testing on FPN, I hope they will like it there. If anyone wants to read the discussion there, here is the link: http://www.fountainpennetwork.com/forum/topic/295309-testing-ink-samples-on-a-laboratory/
Offline BlueNalgene
« Reply #1018 on: Thu, 13 August 2015, 21:11:00 »
Neato, it seems like a receptive audience.
« Reply #1019 on: Thu, 13 August 2015, 21:36:36 »
I loved you before it was cool BlueNalgene
Offline Dihedral
  • Mostly Harmless
« Reply #1020 on: Fri, 14 August 2015, 02:32:08 »
Your post confused me when I found a geekhack link in /r/fountainpens :)
Offline Nai_Calus
  • CLACK
« Reply #1021 on: Fri, 14 August 2015, 17:57:03 »
Pens with MX switches?
Also dat sexy science. Hnnnngh.
I keep being drawn to this kind of stuff because ink is pretty, but my handwriting is terrible, I never actually need to write anything but address labels, and my drawing sucks anyway. Also it seems like an even bigger money sink than keyboards what with the cost of pens and all.
But still so pretty.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline BlueNalgene
« Reply #1022 on: Fri, 14 August 2015, 18:26:44 »
I have awful handwriting, though if I put my mind to it I can do some competent calligraphy.  I use fountain pens because I require inks with resistance to many things I encounter in my work so my notebooks don't get damaged (see the solvent tests).  Having to learn how to work with a nib has actually improved my handwriting.  I would encourage you to try some of the cheaper options without thinking you are going to dive into another wallet sink, like I have done.
« Reply #1023 on: Sat, 15 August 2015, 14:52:02 »
People on /r/fountainpens started to test their inks, inspired on the previous post: https://www.reddit.com/r/fountainpens/comments/3h494k/ph_testing_of_various_noodlers_waterman_and/ :D
Offline BlueNalgene
« Reply #1024 on: Sat, 15 August 2015, 16:41:15 »
Holy crap.  My first peer review.  I wonder if I can put this on my CV.  Would Geekhack count as an academic journal?
Offline THSdrummer
  • HKP hunter. Need moar.
« Reply #1025 on: Sat, 15 August 2015, 16:50:52 »
Good to see other fountain pen people! I don't have any pictures of my handwriting, unfortunately. I use a TWSBI Vac700 medium for my every day note taking and at work. Currently it is loaded with Noodler's AirCorp. I absolutely adore black/blues. It's like their formal, but like to party. I'm running low on ink though. I'll probably ink it up with a BungBox ink next (whenever they show up...).
Also use:
-Noodler's Forest
-Pilot Metropolitan (medium)
I want to pick up another demonstrator whenever I start my full-time job. I'll probably load it up with a red, in which case it'll be used VERY frequently. Which demonstrator I get is up in the air. Considered the Pilot Custom 92 for a while. I might go with a TWSBI ECO, but I'd really like to try a Pelikan, Sailor, or higher end Pilot. One thing is for certain: it has to be a demonstrator.
Leopold FC660m  CM Stealth TKL
WTB: ^^ (O-Zone Bro V2), Drunk Skull, Oktoberfest, Laser/Poison/Woodland HKPs, G1 HKP Gas Masks
MY CLASSIFIEDS THREAD
Offline FrostyToast
  • Litshoard
« Reply #1026 on: Sat, 15 August 2015, 17:28:56 »
Just bought another fountain pen....
I couldn't help it, I saw a keyhole...  :-[
I can see some odd skips on the flexing but I'm pretty sure this was because it was just dip tested.
Quote from: elton5354
« Reply #1027 on: Sat, 15 August 2015, 18:09:38 »
That is great writing my friend :) consider me cosmic jelly on toast.
Offline FrostyToast
  • Litshoard
« Reply #1028 on: Sat, 15 August 2015, 18:20:32 »
Oops. Not my writing. When I say I just bought it I mean I just bought it. That is the work of someone else.
However, I will not disappoint you when I get the pen.
I've much improved on my writing myself.
That type of writing is close to my style except that I put a lot more accentuation and expression on capital letters and have a more extreme slant.
You can see my actual writing here:
****ty photo but it gets the point across.
I still need work on my flourish as my curves need lots of work. Also a shame that I didn't have a flex nib to show off true calligraphy.
« Last Edit: Sat, 15 August 2015, 18:27:36 by FrostyToast »
« Reply #1029 on: Mon, 17 August 2015, 23:45:12 »
You aren't bad man :) keep it up!
« Reply #1030 on: Tue, 18 August 2015, 08:07:44 »
Also use:
-Noodler's Forest
I've been really curious about the BungBox ink but I'm also trying not to buy anymore ink until I use what I have. I really like my Pilot 92 and 74 demonstrators. But I've fallen in love with Pelikan demonstrators :D.
Totally counts ;)
Offline THSdrummer
« Reply #1031 on: Tue, 18 August 2015, 10:19:40 »
Also use:
-Noodler's Forest
I have about 4 inks right now. I think it's time I get a second good pen. First time branching out from Noodler's ink with the BungBox inks (I started the Massdrop BungBox buy - I'm so proud of that).
I'll probably pick up the Pilot 92 first, and then buy a Pelikan down the line. I want the M805 so bad, but I just can't pull that off at this time.
« Reply #1032 on: Tue, 18 August 2015, 10:21:22 »
Congrats on getting the buy together! I was thinking about joining it but like I said I've got more than I can use.
I'm really into the M2XX demonstrators but I have a M605 Marine Blue that's lovely as well. Pelikan <3
Offline THSdrummer
« Reply #1033 on: Tue, 18 August 2015, 11:35:47 »
Thank you! It was such a surprise to see it made the buy. I have seen a handful of group buys over at /r/fountainpens, but I always seem to miss them.
The M2XX stuff looks great too. I was thinking one of those would be more appropriate for me. I think the M805 demonstrator is my grail pen at the moment.
Noodler's is changing their 3 oz. bottles from glass to plastic
« Reply #1034 on: Wed, 19 August 2015, 14:08:40 »
Long story short: the glass bottles are not as available now than before and to avoid increasing prices Nathan Tardiff changed to plastic temporarily.
I don't agree with the political and economical beliefs of Mr. Tardiff, but I must applaud his commitment to his beliefs. You can hear himself speaking about them on this video:
It seems that the 1 oz. & 4.5 oz. bottles will still be made of glass, if what Brian Rachel Goulet says is true: http://blog.gouletpens.com/2015/08/plastic-noodlers-bottles-yes-for-now.html
« Last Edit: Wed, 19 August 2015, 14:10:11 by VinnyCordeiro »
« Reply #1035 on: Wed, 19 August 2015, 14:49:26 »
It's really not like they were that nice of bottles to begin with..
I don't see how this matters.
« Reply #1036 on: Wed, 19 August 2015, 16:55:00 »
Plastic is porous (even it being microscopic pores, but still porous) and allows more ink evaporation than glass bottles (only the cap is a factor, instead of the whole bottle).
I agree with you, Noodler's bottles aren't that nice, just get the job done. In a matter of fact, the bottles should be amber colored to protect the ink from UV light, but that's me nitpicking.
Offline BlueNalgene
« Reply #1037 on: Wed, 19 August 2015, 17:02:52 »
Edit: small mistake, please disregard
« Last Edit: Wed, 19 August 2015, 17:09:59 by BlueNalgene »
Offline SL89
« Reply #1038 on: Sat, 29 August 2015, 08:45:54 »
Just ordered some new inks and a couple pens for the first time in a while.
« Reply #1039 on: Sat, 29 August 2015, 08:54:02 »
What did you pick up?
Offline SL89
« Reply #1040 on: Sat, 29 August 2015, 09:03:56 »
The New TWSBI Eco (Black)
Noodles Nikita red (with free pen, i think its an ahab)
Noodlers Nib Creaper rollerball (also piston, like the eco)
Diamine Sherwood green
Noodlers Borealis Black (with another free pen of some sort)
It was all on a belated gift I didn't even know was sent to me.
If one of the freebies ends up being an Ahab, I'm gonna convert it to an eyedropper conversion.
Offline SL89
« Reply #1041 on: Mon, 31 August 2015, 11:25:17 »
So I ended up getting the Nikita early, (ordered Saturday, recieved it on Monday morning) and it came with not one, but two free pens, one of which is the 'Charlie' pen, and the other being a different Noodler's eyedropper (not the ahab like i was expecting) of some other model I'm not sure the name of.
I filled up the Charlie and its pretty small in the hand, with a rather fine nib, but I quite like it, no tuning needed to get it working off the bat. The Nikita red is also a very enjoyable color and dries pretty well.
I'll upload a picture when I'm done playing around with it.
Offline keshley
    • Blog n stuff
« Reply #1042 on: Mon, 31 August 2015, 11:37:42 »
This thread makes me want to write more  :D
I really like the Diamine inks personally. Think I'm using their copper red in my TWSBI Mini. It doesn't get used very often, so I'd have to find the bottle to verify.
My TWSBI 540 has some Pelikan black variation in it. Its not bad either, very black.
And my GF's Parker 51 knockoff has some home-made ink in it, of the blue variety.
No recollection what my Mont Blanc has in it because I don't like the pen. It's sitting in a box somewhere collecting dust.
I only use ultra-fine nibs as I write pretty small. I'll try to see if I have some examples of the Diamine - it looks kind of like dried blood, pretty unique color.
HHKB Pro 2       Pok3r
Offline SL89
« Reply #1043 on: Mon, 31 August 2015, 19:00:10 »
This is my first outing for Diamine and Twsbi, but I am excited to use both. These are all the first outing for non cartridge based Pens and Inks for me.
« Reply #1044 on: Wed, 02 September 2015, 10:18:34 »
I attend a monthly fountain pen club meeting in Cincinnati. It's pretty fun. There's a few repair people who attend too. A co-worker and myself were talking about fountain pens and he told me about his parent's fountain pens that he had found. An Esterbrook, a Wahl-Eversharp, and a Pick fountain pen (made in Cincinnati). I had the repairman fix up the pens and today my co-worker and I tried out the Esterbrook. It's a J (I think) in Rootbeer with a 9886 nib (Fine, stiff, steel nib). It wrote so nicely and the pen was re-sacced and polished.
Felt really cool to see someone kinda remember a part of their parents' history through the pen.
Offline Booper
    • omniclectic.com
« Reply #1045 on: Wed, 02 September 2015, 19:27:40 »
But no photos!?   :'(   :'(
Don't you know I have to experience fancy pens vicariously through you guys!
boop!
« Reply #1046 on: Wed, 02 September 2015, 21:27:21 »
I'll try and grab a photo tomorrow. Not supposed to take pics at work. Esterbrooks are actually a good intro to vintage pens! Very affordable.
Offline Booper
    • omniclectic.com
« Reply #1047 on: Thu, 03 September 2015, 11:23:09 »
New ink! J. Herbin Emerald of Chivor
The shimmer is awesome, but I really love how the same color ink looks red or blue depending on how thick it goes down! It's a lot of fun to draw/stipple with.
« Last Edit: Thu, 03 September 2015, 11:42:55 by Booper »
boop!
« Reply #1048 on: Thu, 03 September 2015, 15:15:06 »
^ wow!
« Reply #1049 on: Thu, 03 September 2015, 15:24:27 »
When I grow up, I wanna write and draw like booper
