Author Topic: Key Only Registering At Bottom  (Read 1977 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Mon, 23 June 2014, 16:57:54 »
ok............you smart guys-- i need a little help
why are a couple of my keys only registering when i press near the bottom of the keycap and no where else?
i tried pressing down or squaring the [alps] switch if you will, but nothing.
i don't want to break anything as it is n older board.
i took apart and the solder looks good?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Kagusaki Wolf
Re: Key Only Registering At Bottom
« Reply #1 on: Mon, 23 June 2014, 17:29:03 »
What happens if you press the middle part all the way down and slide your finger towards you slowly?
SIIG Suntouch K101 | Northgate Omnikey Ultra T | NMB RT8255C+ | Cherry G84-4100 | Cherry G84-4420 X2 | IBM Model M | Laser Brand Keyboard | Monterey K 108 X2 |
Offline jacobolus
« Reply #2 on: Mon, 23 June 2014, 17:37:02 »
If you open the switch you might be able to figure it out. My guess is that by bending the leaf attached to the switchplate to have a slightly sharper 'kink' in it, you’ll be able to fix it. It has probably just slowly bent into a straighter-than-original shape with age and use. As a result, when the slider goes straight up and down it doesn’t sufficiently push the bump in that actuator leaf into the little metal foil contacts.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Mon, 23 June 2014, 18:17:43 »
aaaaaaaaaaaaaa
dddddddddddddddddddd
it registers
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Mon, 23 June 2014, 18:19:02 »
makes sense............
will have to remember that
« Reply #5 on: Mon, 23 June 2014, 18:21:09 »
report back after you've broken it in...
10,000 key presses per affected key...
ready. set. go...
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Mon, 23 June 2014, 19:48:31 »
ready. set. go...
ha!
u ain't right
