Author Topic: which mx cherry is a similar feeling to this old keyboard  (Read 12865 times)
Offline dv8omega
« on: Mon, 07 July 2014, 22:43:10 »
wondering which mx cherry is most similar to the old dell keyboards. im just very use to it.
http://i.imgur.com/Cm99qHY.jpg
Re: which mx cherry is a similar feeling to this old keyboard
« Reply #1 on: Mon, 07 July 2014, 22:46:17 »
MX red, probably.  Linear, with not much resistance.
Offline jonathanyu
« Reply #2 on: Mon, 07 July 2014, 23:02:29 »
I have used this keyboard for few years before switching to mechanical keyboard.  And I think is similar to mx brown
« Reply #3 on: Mon, 07 July 2014, 23:04:13 »
Except there's no tactile feedback from the Dell - just a mushy thud as the key reaches the bottom of the stroke (we have the same keyboards at work here).
« Reply #4 on: Mon, 07 July 2014, 23:11:49 »
the only stand out to the dell board is the conforming convex space bar..
Offline FrostyToast
  • Litshoard
« Reply #5 on: Mon, 07 July 2014, 23:15:17 »
If that keyboard was a normal membrane, then I think the closest feeling switch would have to be MX clears. However, I have never owned one of those.
Quote from: elton5354
Offline Oobly
« Reply #6 on: Tue, 08 July 2014, 03:20:14 »
These Dell boards most certainly have tactile feedback, but it's at the top as the domes collapse. It's stronger than that of Browns.
Out of stock Cherry switches, I would say that Clears would feel the closest, but they have a harder bottom out than the Dell and the Dell keys feel just a little lighter. So ErgoClears would match best.
I have one of those on my desk at work next to my KBT Pure with 62g ErgoClears and can say that they do feel very similar, but the Dell is a little mushier. It's the best stock rubber dome board I have ever used.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline phoenix1234
« Reply #7 on: Tue, 08 July 2014, 03:39:09 »
It's quite hard to tell because it depends on many factors. Since I also have typed on that keyboard for awhile so I think the most similar to it is the Cherry MX Brown ( a little bit tactile ) but with 80g spring from Cherry MX Black because that Dell is quite heavy when the dome getting old. The bad thing on that keyboard is the inconsistency key feeling. It will only be smooth when we touch the centre, but if we hit into the corner, it is hard like hell (similar like most of the dome keyboards)
I like linear switches
Offline davkol
  •  Post Editing Timeout
« Reply #8 on: Tue, 08 July 2014, 06:26:53 »
Modern Cherry MY with the ****tiest ABS keycaps you can find.
Offline Quardah
    • DeliTech
« Reply #9 on: Tue, 08 July 2014, 07:42:45 »
I've been in the IT world for some times now and i would just like to point out that there's multiple revisions of this Dell keyboard (which in my opinion is one of the best modern rubber dome you get in the office sphere) and they feel somewhat different.
Some of them are stiffer than others and some of them are more linear than others. My friends familly all puchased their home computers from Dell and kept those keyboards (thus, he has two mighty Dell Quietkeys) and when you get to try them you can easily find differences between them.
So yeah, it's very hard to determine with a picture. In my opinion the best you could do is test it yourself with weights and determine the average actuation force require, then try to get an idea of the three major "feedback" families in MX switches (Linear, Tactile and clicky) and determine which switch you want.
That way you will get an optimal feel with your board.
Have a wonderful day.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline dv8omega
« Reply #10 on: Tue, 08 July 2014, 10:01:09 »
 cant decide between browns and blues. i want a clicky feeling and some sort of feedback, but im afraid blues might be to loud overtime
Offline Quardah
    • DeliTech
« Reply #11 on: Tue, 08 July 2014, 10:10:03 »
It's not really that clicky. If you think it's too much, get some o-rings, most probably the best mod when it comes to clicky switches, reduced the sound and reduced the bottom out distance.
It's just like adding an overpowered gem into an already overpowered weapon in Diable II.
Poker II - Brown MX
Offline dv8omega
« Reply #12 on: Tue, 08 July 2014, 10:26:30 »
i should opt for blues then? going to use it mainly for gaming and typing
« Reply #13 on: Tue, 08 July 2014, 10:34:47 »
I have had a few of these. One of them (probably the oldest and/or one not made in China) was not really too bad.
Similarly, the first-gen Quietkeys were really nice, but later variants aren't.
- D Trump 2026-10-24
Offline Quardah
    • DeliTech
« Reply #14 on: Tue, 08 July 2014, 11:24:36 »
Yes, but rubber dome speaking, i'd say pretty much all of Dell boards i got to try were above average. It's pretty sad they never went into mechanical cause they could easily afford them considering their volume and even if they would mostly low grade mechs it would still be better than the current boards they bundle up with their home computers.
Poker II - Brown MX
Offline davkol
« Reply #15 on: Tue, 08 July 2014, 11:35:14 »
Like AT101?
Offline Quardah
    • DeliTech
« Reply #16 on: Tue, 08 July 2014, 14:23:36 »
Like AT101?
Isn't AT101 mechanical Alps? Because if you are talking about old Dell (too lazy to Google) then yes, they should have never left their mecanical greatness for puny rubberdomep00pness.
Poker II - Brown MX
Offline davkol
« Reply #17 on: Tue, 08 July 2014, 14:48:45 »
Dell AT101(W) and QuietKey were made at the same time.
Offline dv8omega
« Reply #18 on: Tue, 08 July 2014, 15:18:34 »
would mx brown or blues be the closest experience?
Offline davkol
« Reply #19 on: Tue, 08 July 2014, 15:48:45 »
Closest? Maybe. Close enough? Hopefully not. It's like asking what sports car is the closest to a minivan. Well, they're different. If you want a rubber dome feel, get a rubber dome keyboard. Maybe even Topre.
That being said, I don't think clicky Cherry MX are anything like rubber domes. Maybe a bit like scissor switches, when used with dampeners or modded to jailhouse blues.
« Reply #20 on: Tue, 08 July 2014, 15:56:14 »
I did not realize that. I got an AT101W with a Dell system in the mid-1990s, and I don't remember paying extra for a keyboard upgrade.
Offline davkol
« Reply #21 on: Tue, 08 July 2014, 16:02:49 »
I don't have the oldest quietkeys (GYUR10SK being one of them) anymore, but I'm quite sure they were older then my current GYUM90SK. I mean, just look at the FCC ID.
It sounds quite plausible that Dell could start to distribute quietkeys just like IBM made rubber-dome "Model Ms" for quiet office environments, while still selling buckling-spring keyboards.
« Last Edit: Tue, 08 July 2014, 16:09:21 by davkol »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #22 on: Tue, 08 July 2014, 16:04:09 »
My question would be, why do you want to have a similar feeling?
IMO the whole point in mech boards is to feel something different. I haven't got two boards with the same switches because I want to experience all the different facets of mechanical switches.
I would recommend getting something completely different, but that's just me.
Offline dv8omega
« Reply #23 on: Tue, 08 July 2014, 16:05:30 »
cant decide between browns n blues
Offline katushkin
  • Just the guy
« Reply #24 on: Tue, 08 July 2014, 16:08:44 »
Browwwwwwns
Offline davkol
« Reply #25 on: Tue, 08 July 2014, 16:09:42 »
Why not both?
Offline dv8omega
« Reply #26 on: Tue, 08 July 2014, 16:12:47 »
dont have $ for both. already dropped 1k for a new pc
Offline Oobly
« Reply #27 on: Tue, 08 July 2014, 16:16:12 »
Browns would be closer than Blues.
Offline phoenix1234
« Reply #28 on: Tue, 08 July 2014, 21:39:15 »
This is Dell SK-8135. It is cheap and the key feeling is inconsistency. It is nothing like the premium Dell QuietKey (the one using NMB Japan-made dome) and AT-101.  Some even said the NMB Dell QuietKey is even comparable to Topre 45g. I owned both and feel otherwise. Topre 45s has more consistent and solid key feeling, the tactile bump from Topre is also more consistent. Indeed, I need to admit the Japan-made dome delivers the top quality on the market, no matter it is on the Dell QuietKey or Topre.
« Last Edit: Tue, 08 July 2014, 21:44:17 by phoenix1234 »
Offline Quardah
    • DeliTech
« Reply #29 on: Wed, 09 July 2014, 07:24:45 »
Indeed the tactile feedback rather than clicky feedback is somewhat closer to rubberdome silliness.
Poker II - Brown MX
