Author Topic: VitaFIX.....Black-dust Defect alleviated.... ??  (Read 44456 times)
Re: Vitamix fatal design flaw??
« Reply #50 on: Tue, 07 April 2015, 21:24:07 »
what an obscure necro
Just comes to show that Tp4's vision is transcendentally unbound by even time...
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #51 on: Tue, 07 April 2015, 21:31:49 »
« Reply #52 on: Wed, 08 April 2015, 00:26:32 »
From every comparison review I've seen Vitamix > Blendtec every single time. Although their design is ugly as sin, apparently Vitamix is the blender that nutritionists, doctors, and chefs recommend.
I still think your crazy for spending that kinda dough on a blender when you can get BOGO blenders at Big Lots 2x for $14.99.
« Reply #53 on: Wed, 08 April 2015, 00:51:40 »
Well the main difference is particle size..
The high speed makes smoother blends.
I peraonally think blending is stupid. But there was no other way for me to make soy milk at home.  The particle size was too large coming out of the budget blender. It made to texture gritty
Offline Novus
  • Mondai nothing~
« Reply #54 on: Wed, 08 April 2015, 01:02:54 »
Just drink store bought soy milk or almond milk or milk milk
« Reply #55 on: Wed, 08 April 2015, 01:06:20 »
why u try kill Tp4 with processed foods 1wofl
« Reply #56 on: Wed, 08 April 2015, 02:05:54 »
LOL if you're worried about processed foods I've got some bad news for you about the FDAs definition of what qualifies as 'organic.' :))
« Reply #57 on: Wed, 08 April 2015, 02:38:30 »
Nawh.. I'm Jking.. I dont' give a damn..
I think "eating simply"  is probably more conducive to health than the "processed / unprocessed" "organic/ inorganic" debate..
« Reply #58 on: Wed, 08 April 2015, 02:46:32 »
Yeah totally. After reading about how 'organic' labels basically mean nothing in the US it was like waking up from the matrix or something. That **** should be illegal, but farming lobbies would never allow that to happen.
« Reply #59 on: Wed, 08 April 2015, 03:42:08 »
Organic is fashionable.. and profitable.. The story begins and ends there..
---it doesn't matter that it's unsustainable and unreasonably expensive
High heels are fashionable.. and profitable..
---it doesn't matter that it physically hurts women and it's unreasonably expensive for shoes that make you walk funny.
Update June 9, 2015
If your Vitamix is within Warranty period, they will supply you with the Revised Container..
No known Retail Vitamixes comes with the Revised Container, so you will still have to call them if you purchase from a brick-n-mortar.
Ok.. So.. Way back in April of 2014, it was discovered that Vitamix blending blade-hubs shed black teflon particles INTO the mix.
97% of online users who saw the major threads over @ slickdeals reported black-dust-positive.
Today, I've received 2 replacement containers from Vitamix, under the promise that they are "FIXed" and black dust free.
I am happy to report that, this is INDEED the case.
If you take a look at the pictures below..   The black seal ring is now made of a SOFT-er rubber material, and the central post makes direct contact with it.
The seal between the central post and the black ring, is done via what Vitamix will tell you is a FOOD-SAFE lubricant.
As you can see, this lubricant (white stuff around the ring) will get into your food, albeit, in small amounts.
There's no way to make this type of seal work without the lube, so, that's always how it's gonna be.
Originally there were 2 issues with the old hub.. the Original black cap was of a hard material, and would disintegrate upon use.
This was what caused the black specs to enter the blend.
The second issue was, the original blade hub, also allowed SOME lubricant to get into the mix. in the previous case, the lubricant was (black) and was visible during prolonged blends.
The new lubricant seems to be all White, which, means even if it got into your blend, it will be invisible.
With this new hub, Vitamix has rectified the Teflon-Black-dust situation, and took care of the aesthetic Black-lubricant situation.
Re: VitaFIX...............Call Vitamix, they fixed the Black Dust.... ??
« Reply #61 on: Tue, 09 June 2015, 20:46:48 »
So do you have to periodically relube?
Offline heedpantsnow
  • Old enough to know better
« Reply #63 on: Tue, 09 June 2015, 21:25:39 »
So you have gone from having visible black dust to invisible white lube (or dust?). Are you satisfied with that?
I'm back.
« Reply #64 on: Tue, 09 June 2015, 21:29:57 »
There will always be some lube going into blended foods..
