Author Topic: Recruiting for scrub CS:GO team  (Read 285206 times)
Re: Recruiting for scrub CS:GO team
« Reply #400 on: Wed, 24 September 2014, 17:26:19 »
Absolute steal for people who haven't experienced the Half Life series and Valve multiplayer games. To think I just spent $5 on L4D2 alone the other day...
l4d2 is pretty dead.. sigh...
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #401 on: Wed, 24 September 2014, 17:29:02 »
Mfw I spent $5 on a dead game, you won't spend $5 for a game that is more alive than ever.
« Reply #402 on: Wed, 24 September 2014, 17:33:37 »
well, at dinner time it's still got some peeps..
The $5 CS-Go thing is completely a separate issue.. I just can't do it.. knowing that $5 is just round the corner.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #403 on: Wed, 24 September 2014, 17:38:13 »
...said Sifo.
Offline exitfire401
  • The Force is Re/\l
« Reply #404 on: Wed, 24 September 2014, 17:40:43 »
Played 2 MM games...first one I sucked, but we won because the other team sucked with CT on Dust, then the second one, got paired against one of my teammates from the first one who was a troll. He carried the hell out of the other team, then quit at the half and got a 30 day MM ban haha. Ended up winning that one as well
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #405 on: Thu, 25 September 2014, 23:04:08 »
*sigh*... my csgo has been acting up for the past 2 days...
The trend is usually:
1. First map loading since starting game results in game crashing with an error message. I can't read the message or see the error window but start bar shows "Engine Error"
2. Start up game again with problem no.1 not occuring anymore, but at any given random moment, the game will randomly just crash with no error message. However, mouse cursor on my primary display is invisible, my desktop resolution doesn't get fixed so everything is stretched on both my dual monitors (I play 1280x720), and explorer.exe eventually crashes.
Even after restarting explorer.exe through task manager, mouse cursor is still invisible, resolution is still messed up, and things in the background don't work. When I say background, I mean things like pressing Ctrl+Alt+Delete will result in a black screen (I can get back to desktop by pressing Esc), booting up the game again will result in a black screen (can't Alt-Tab out or Alt-F4), and I have to hard restart my PC...
Things I've tried to resolve the issue but to no avail:
1. Verifying game files through Steam.
2. Reinstalling GPU drivers.
3. Running the game in native resolution.
4. Deleting CFG folder, and having Steam reinstall it (I haven't tested this one yet. Will post update later).
I guess my next step is to just reinstall the game... Hopefully this will fix it.
« Reply #406 on: Thu, 25 September 2014, 23:06:17 »
Reformat  ?
I usually do mine around christmas..
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #407 on: Thu, 25 September 2014, 23:10:22 »
I'm the type that hordes files and have like 100's of software installed... reformatting would be quite the amount of work :P
I think once I change my HDD to SSD (yes... my HD is desk 7200 rpm :P ), I'll probably keep it clean, and have this hdd hooked up via external case.
« Reply #408 on: Thu, 25 September 2014, 23:30:12 »
y xternal laptop warrior ?
Offline domoaligato
« Reply #409 on: Fri, 26 September 2014, 14:50:18 »
vesper are you using launch options?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #410 on: Fri, 26 September 2014, 14:58:14 »
Lelwut
Good sir!
I'm currently using: -novid -console -high -thread4 -noborder
I forgot to mention, but I may have fixed the issue! The reinstall didn't work, so I got really annoyed and almost just gave up, but then I realized that maybe it was the EVGA Precision 16x (I use this to raise my fan speed), which was a recent update, right around when the problem started, and I went to the site to read that it was "recommended" from starting at the 600 series (I have a EVGA GTX 570). So I uninstalled that, and installed an older version again, and it didn't crash on me for the 2-3 games I tested afterwards!!! I didn't do any further testing after that because it was late but I'll have to give it another test today to be sure. Hold onto your butts!!!
Offline Lurch
« Reply #411 on: Fri, 26 September 2014, 15:03:06 »
Everyone should experience Ricochet in anticipation of Ricochet 2: Electric Boogaloo
not sure if post is serious, but i would be down to rock some ricochet.... if any servers are up :))
Quote from: Flyersfan1
Offline slickmamba
« Reply #412 on: Sat, 27 September 2014, 09:33:05 »
wheres everyone been? =/
Hi :)
Offline exitfire401
« Reply #413 on: Sat, 27 September 2014, 09:54:06 »
Gone for the weekend...my aim is gonna be **** on monday :-(
Offline esoomenona
  • Gnillort?
« Reply #414 on: Sat, 27 September 2014, 13:36:09 »
« Last Edit: Mon, 21 September 2015, 11:17:14 by esoomenona »
Offline clacktalk
  • circa 2015
« Reply #415 on: Sat, 27 September 2014, 13:48:46 »
I was playing Competitive last night when this happened. I couldn't see anything.... Even more so when I started on T and CT was blending in with all the black. Did a little better when I could see T brown against it.
My condolences. I hope you weren't playing matchmaking
diary of a clacktalk
radio_killah: too much frank
« Reply #416 on: Sat, 27 September 2014, 13:51:41 »
dota 6.82 came out and i'm addicted to risk of rain
Offline esoomenona
  • Gnillort?
« Reply #417 on: Sat, 27 September 2014, 13:59:59 »
« Last Edit: Mon, 21 September 2015, 11:17:05 by esoomenona »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #418 on: Sat, 27 September 2014, 14:01:20 »
What is matchmaking, exactly?
It's when a man and a woman love each other very much and they do a special hug.
Offline esoomenona
  • Gnillort?
« Reply #419 on: Sat, 27 September 2014, 14:06:44 »
« Last Edit: Mon, 21 September 2015, 11:16:48 by esoomenona »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #420 on: Sat, 27 September 2014, 14:08:09 »
nvm
« Last Edit: Sat, 27 September 2014, 14:10:27 by epzy »
Offline domoaligato
« Reply #421 on: Tue, 30 September 2014, 14:06:03 »
are you playing on linux?
if so have a look around reddit csgo. this is one of the known issues right now.
Offline domoaligato
« Reply #422 on: Tue, 30 September 2014, 14:07:45 »
matchmaking is what valve calls a 5v5 competitive ranked match.
Offline esoomenona
  • Gnillort?
« Reply #423 on: Tue, 30 September 2014, 16:43:57 »
« Last Edit: Mon, 21 September 2015, 10:39:47 by esoomenona »
Offline Altis
« Reply #424 on: Tue, 30 September 2014, 17:35:46 »
I've been getting back into CSGO after two months off it... It kills me to see how many people use the AWP in deathmatch. If you're going to practice, use the SSG/Scout!
« Reply #425 on: Tue, 30 September 2014, 18:06:41 »
I've got a good feeling about the Thanksgiving/ Christmas sale.. Hopefully $5 will happen this time around?
Mayyybe we'd see columbus day sale, since that's the only national one in october.
Offline clacktalk
  • circa 2015
« Reply #426 on: Tue, 30 September 2014, 18:23:15 »
I don't know how much I agree with this. The scout is way more mobile than an AWP. I'd for sure like for more people to chime in on this topic
Offline SlotH42
  • one slow step for sloth
« Reply #427 on: Tue, 30 September 2014, 18:31:13 »
Then yes, I was playing matchmaking. And no, Windows 7.
If this happens again;
1. close CS:GO (dont exit from the game, you will get a ban)
2. open CS:GO files and delete a Map_Pak## file
3. verify The integrity of your game cache
4. wait for the deleted files to download
5. re-join your match
6. buy guns for your team for leaving them with a bot :thumb:
 This kind of thing happens when one of your map_pak files has gone corrupt. when this happens to me I have to close the game, go into the files and delete a map_pak file. A random one works, because when you go to re-verify the game cash it catches the issue, a lot of times if you just re-verify it wont catch the error. If you can pull that off, and the update after the corrupt files are found, in under 3 minutes you can make it back into theMatchmaking session. Got to be quick. Did your internet go out? or did your cs crash before the visual issue occurred? thats what usually causes it for me.
If none of the above helps you, you may want to check your GPU.
MP-GBL4 (red) Poker II (clears) Realforce R2TL 55g
Offline esoomenona
  • Gnillort?
« Reply #428 on: Tue, 30 September 2014, 18:44:01 »
« Last Edit: Mon, 21 September 2015, 10:39:34 by esoomenona »
Offline slickmamba
« Reply #429 on: Tue, 30 September 2014, 19:07:46 »
but if you practice with the scout, you get used to the increased mobility, which could hurt you in game.  Honeslty, it is DM treat it like practice and don't get bothered by what others are doing, or play in a community dm where there are only 2 awps per side
Hi :)
Offline Altis
« Reply #430 on: Tue, 30 September 2014, 19:29:49 »
It's a valid point, except that mobility only really matters in comp... you aren't going to be rotating or anything in DM. I suppose if you're used to the scoped mobility, that would make a difference. It's just my two cents worth, but the Scout is actually a very useful weapon if the skills are developed. If you practice with it, you'll become much better with it and those skills will almost entirely transfer to the AWP.
Here's a great video on the various CSGO sniper rifles (this guy's videos are very detailed, I recommend them).. 3kliksphilip and WarOwl are my favorite.
http://youtu.be/iFB2MhR0__0?list=UUmu9PVIZBk-ZCi-Sk2F2utA
« Last Edit: Tue, 30 September 2014, 19:34:49 by Altis »
Offline esoomenona
  • Gnillort?
« Reply #431 on: Tue, 30 September 2014, 19:55:55 »
« Last Edit: Mon, 21 September 2015, 10:38:07 by esoomenona »
Offline slickmamba
« Reply #432 on: Tue, 30 September 2014, 22:54:20 »
Come out, moose and I are about to play MM
Hi :)
Offline clacktalk
  • circa 2015
« Reply #433 on: Tue, 30 September 2014, 22:58:14 »
watching u guys. impress me bbs
Offline billnye
  • ability man
« Reply #434 on: Thu, 02 October 2014, 19:35:04 »
Gonna play a comp if anyone wants to hop on!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #435 on: Thu, 02 October 2014, 19:44:12 »
oooo~
Offline Lingj
« Reply #436 on: Thu, 02 October 2014, 19:46:44 »
I haven't played for in like a month but I'm down for a match
Offline esoomenona
  • Gnillort?
« Reply #437 on: Thu, 02 October 2014, 19:47:45 »
« Last Edit: Fri, 04 September 2015, 18:08:20 by esoomenona »
Offline billnye
  • ability man
« Reply #438 on: Thu, 02 October 2014, 20:25:05 »
Offline billnye
  • ability man
« Reply #439 on: Thu, 02 October 2014, 21:50:10 »
rip CS servers
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #440 on: Thu, 02 October 2014, 21:58:39 »
resurrection
« Last Edit: Thu, 02 October 2014, 22:41:57 by VesperSAINT »
Offline domoaligato
Offline Altis
« Reply #442 on: Thu, 02 October 2014, 22:40:25 »
Who's up for some CS this weekend?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #443 on: Thu, 02 October 2014, 22:42:01 »
It's been awhile since we played as the GH crew~ Was fun~ We should do it more often~
Last game (I forgot to take a screenshot when we had more players :( ):
I'm ashamed of my troll comment *blush*
Offline billnye
  • ability man
« Reply #444 on: Thu, 02 October 2014, 22:42:19 »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #445 on: Thu, 02 October 2014, 22:43:28 »
resurrection
bill mvp
That you were. You buying me awp 3 times that match literally lead us to win it. I won't lie... Near the end, I wanted to win pretty bad. #tryhardftw
BILL MVP!
That and, in a tiny degree, Blue music in the background :P
I'd be down, as long as I'm home/in-town.
« Last Edit: Thu, 02 October 2014, 23:08:58 by VesperSAINT »
Offline clacktalk
  • circa 2015
« Reply #446 on: Thu, 02 October 2014, 23:23:49 »
resurrection
bill mvp
BILL MVP!
HOW MANY AWPS DID YOU FREELOAD THAT GAME ?????
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #447 on: Thu, 02 October 2014, 23:25:47 »
Like 3 :)) w00t w00t! Hooray for rich teammates!
... I should really stop rushing and being point man with an AWP... Dying too much...
... YOLO!.. wait...
« Last Edit: Thu, 02 October 2014, 23:30:59 by VesperSAINT »
Offline peachesenregalia
« Reply #448 on: Fri, 10 October 2014, 22:51:46 »
Anyone still playing, I'm pretty active lately.
http://steamcommunity.com/id/peachesenregalia
Good feeling of oneness.
Offline slickmamba
« Reply #449 on: Sat, 11 October 2014, 02:05:53 »
I'm going to try to get some games in tomorrow.  Who is down?
Hi :)
